One for Des
Discussion in 'UK Motorcycles' started by Hog, Dec 11, 2003.
  1. Ethiopia
    The Older Gentleman, Jan 1, 2004
  2. Hog
    Salad Dodger Guest
    Ethiopia[/QUOTE]
    Ah.
    Salad Dodger, Jan 1, 2004
  3. Hog
    deadmail Guest
    Is it a false memory or were the French supplying exocet parts or
    support during the Falklands Conflict? It's lodged in the back of my
    mind but I find it hard to believe.
    deadmail, Jan 1, 2004
  4. Hog
    deadmail Guest
    I do, what's your point?
    You said the sub-comms were compromised, are you sure about that? What
    band were they using? What equipment were they transmitting through?
  5. Hog
    deadmail Guest
    I think you've missed Tallbloke's point. He's claiming that diplomatic
    pressure was applied to Argentina to drop the claim that we sunk the
    Belgrano illegally.
  6. wrote
    Extremely low frequency radio underwater innit?
    steve auvache, Jan 1, 2004
  7. Oops. OK, right. Apologies.
  8. Hog
    tallbloke Guest
    (The Older Gentleman) spouted the
    following in
    I deplore all violent loss of life TOG. However, I do have some
    understanding of 'Jus in Bello' Having studied ethics. I also have a
    sense of perpective and proportianate response, unlike Margaret. The
    following URL (wrapped, sorry) has a good and balanced discussion of the
    whole Falklands issue:
    http://www.waikato.ac.nz/wfass/subjects/history/waimilhist/1999/falkland
    s
    ..htm
    "There were, in fact, only a handful of soldiers killed or injured, [In
    the initial invasion], almost all of them Argentine."
    contrast with:
    http://www.parliament.the-stationery-
    office.co.uk/pa/cm200102/cmselect/cm
    pubacc/759/2041003.htm
    "Since 1982 we have had two conflicts where this is relevant: the
    Falklands where we had eight people killed from fratricide and 22
    wounded through friendly fire incidents,"
    Over a 1000 lives were lost in all.
    Now if the maintainence of British sovereignty over a windswept sheep
    pasture is really that important, it must be because of it's potential
    strategic importance, say as a refuelling depot on the way to and from
    Antarctica, or because there is a percieved possibility of deriving
    valuable mineral rights (Oil again!), because otherwise, we have plenty
    of empty croft land which we could maintain for the islanders in the
    outer hebrides at a lot less expense to the taxpayer.
    If you bother to read the history, you will find that the Argentinians
    actually have a better claim to the Islands than we do anyway, because
    the British renounced all rights to any lands in or around South America
    a long long time ago.
    tallbloke, Jan 1, 2004
  9. Hog
    tallbloke Guest
    following in
    <Big Snip>
    Sorry TOG, have to stop you there. Take another look at the date in
    Dodgers post. 1994...
    You are into a whole different argument about the lead up to the
    conflict, rather than the ecnomic aftermath.
  10. Hog
    tallbloke Guest
    following in
    Ta :)
  11. Hog
    Cab Guest
    Yes. Furthermore, the French wouldn't give the 'Friend or Foe' codes
    (whatever they're called) for the missiles. With these codes, the
    British forces could have made sure that the missiles would not have
    hit their targets, IIRC.
    I suppose one could argue that if the codes were given, then the
    conflict would have been shorter and with fewer deaths on either side.
    Cab, Jan 1, 2004
  12. Hog
    deadmail Guest
    Well, yes. They tow antenna sometimes hundreds of metres long IIRC.
  13. Hog
    tallbloke Guest
    I disagree. The key phrase is this one I think:
    "if necessary, we had to be prepared to attack"
    Subtext:
    "Though we knew we'd get the shit kicked out of us if we did."
  14. Hog
    tallbloke Guest
    spouted the following in
    I didn't say anything of the kind.
    You don't have to be able to decode comms to be aware that they are
    being made.
  15. Hog
    tallbloke Guest
    steve auvache <> spouted the following in
    Do you have a reference or source for that?
  16. Could just buy another one on ebay.
    GS 850 x2 / SE 6a
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Jan 1, 2004
  17. Hog
    "..your world could end not
    with a bang but a wimpy."
    Which I've always liked
    sweller, Jan 1, 2004
  18. Hog
    Ben Blaney Guest
    I'm sure I recall something along those lines from the Clark diaries.
    I'll have a look.
    Ben Blaney, Jan 1, 2004
  19. Hog
    tallbloke Guest
    LOL!
    "Here give us a grand for this computer. Ta, you can't have a manual tho"
    Get real.
    The Sheffield was hit 2 days after the Belgrano was sunk. Did the French
    fly over there and help 'em bolt the launchers onto the planes during that
    48 hour period?
  20. Hog
    Dan White Guest
    You only have to be aware of a transmission to get a bearing, triangulate
    and get range. Which is exactly why sub commanders run silent and listen,
    *not* transmit when in close formation and preparing for a possible strike.
    Dan White, Jan 1, 2004
