On Topic! Is my bike just too neutral?
Discussion in 'UK Motorcycles' started by Gyp, Sep 4, 2009.
  1. Gyp
    Gyp Guest
    I'm still trying to build up a rapport with the Bumblebus and it's still
    proving to be a troublesome courtship. However, I do intend to persevere
    before deciding whether or not to Nige it out in the Spring.
    One "feature" is that I'm getting lower back pain while riding. Having
    thought about it for a while, I'm wondering if the riding position is
    too "neutral".
    On the RT, I'm sat upright, so my back is straight and my arms sort of
    flop forward to the bars. On the RS, I lean forward and the weight is
    spread betwixt my wrists and my arse.
    But on the Bumblebus, I'm leant slightly forward. But not enough to put
    weight on my wrists. The BMW screen works absolutely brilliantly, but to
    the extent that I get no pressure either on my front of my back. So it
    feels that I'm using my lower back to hold myself in place.
    That make sense?
    I'm going to take the screen off tomorrow and see if that helps.
    Gyp, Sep 4, 2009
  2. Gyp
    Nige Guest
    I have always found sportsbikes more comfy than uprights, the pan didn't cut
    it comfort wise.
    Buy a k1200s mate.
    Nige, Sep 4, 2009
  3. Gyp
    Gyp Guest
    Well earned
    Already? You've only owned it for a few hours.
    Gyp, Sep 4, 2009
  4. Gyp
    Sort of. Err, what is the Bumblebus? Faired? If so, is the screen
    adjustable? Often there's a vortex that pushes forward too [1].
    [1] I was reminded of this recently when I didn't put the rear seat
    pad on properly on the Tuono: about a mile up the road, it flipped up
    and stuck pressed to the small of my back.
    Pip Luscher, Sep 4, 2009
  5. Gyp
    Nige Guest
    On my old pan did this, the jacket used to fly up my back with the big
    screen on, the normal screen was fine.
    Nige, Sep 4, 2009
  6. Gyp
    <fx: looks round, whispers>
    that looks quite nice.
    </fx>
  7. Gyp
    Problem on the RS is the footrests are too far forward. You need the rearset
    kit that moves them back about 4 inches. Also slightly wider bars help a
    lot. The RT and LT's all give me lower back pain.
    Hog, Sep 4, 2009
  8. Gyp
    Nige Guest
    I LIKE that!
    Nige, Sep 4, 2009
  9. Gyp
    Gyp Guest
    Oooh! A bidding war...
    Thing is, I've wanted an R1150R for years. With ABS, in Dakar/Ferro,
    with a screen, panniers, hand guards and heated grips.
    Then I found one.
    And so far it's not quite what I expected.
    Gyp, Sep 4, 2009
  10. Gyp
    DozynSleepy Guest
    I managed to resist one last bid on a yellow R1150GS this afternoon on
    ebay. Decided I might as well use the ST4s for the Elefant and if I do
    go sledging with it to put the money to something when I get back.
    Obviously not quite convinced myself yet, went along to the local BMW
    dealer this afternoon when the auction finished and had a look at the
    R1200GS, felt a lot lighter than I was expecting.
    DozynSleepy, Sep 4, 2009
  11. Gyp
    Gyp Guest
    AVOID!
    Seems to be the standard response
    Gyp, Sep 4, 2009
  12. Gyp
    You're learning. Now all you have to do is apply that to the entire
    output of all BMW bike factories over the last 80 odd years.
    Lozzo, Sep 4, 2009
  13. Gyp
    Nige Guest
    2nd'd
    Nige, Sep 4, 2009
  14. Gyp
    Nige Guest
    you have my number.
    Nige, Sep 4, 2009
  15. Gyp
    Nige Guest
    07790771836, now you do.
    Nige, Sep 4, 2009
  16. Gyp
    ...and I've just re-read your original post. properly. Gah.
  17. Gyp
    Alex Ferrier Guest
    Sit ups.
    Alex Ferrier, Sep 5, 2009
  18. Gyp
    Gyp Guest
    Agreed if I was pushing on, but the problem occurs when I'm just
    pottering or holding a steady speed, and that shouldn't require
    significant levels of fitness
    Actually the problem is less prevalent when I'm getting a move on on
    back roads as then there's always an acceleration or braking force for
    my arms to deal with and I'm constantly moving about.
    Time to get the spanners out of the dishwasher and wave them at the
    bike.
    Gyp, Sep 5, 2009
  19. Gyp
    Tim Guest
    Hmmm I liked the ones I had (R80RT, K1 and K75RT). I really miss the K1
    apart from its lack of luggage capacity.
    Tim, Sep 5, 2009
  20. Gyp
    Eddie Guest
    I think he means that you need more abdominal strength, rather than
    general fitness.
    Eddie, Sep 5, 2009
