On spooge and silicone
Discussion in 'Motorbike Technical Discussion' started by Andrew Szafran, Jul 18, 2004.
  1. Nope. This post isn't about kinky sex with enhanced supermodels. Nor is
    it about increasing your diameter....
    Anyway, last weekend, I noticed that the leftmost carb of my Nighthawk 550
    was leaking from the seam between the carb itself and the float bowl.
    Monday night, I went to Schlep Boys and bought a tube of silicone sealant
    that was supposed to be gasoline-resistant, and sealed the float bowl
    seams of all four carbs with a *very thin* smear of sealant. Well, today,
    I took the bike for a 100-mile trip. On the way back, I noticed that the
    bike had very poor acceleration and was running rough.
    After I got home, I stuck a wet rag on each exhaust pipe in turn. The
    three left pipes sizzled as expected. The rightmost pipe hissed weakly.
    I checked for spark, and all four cylinders were sparking strongly. Ok, I
    thought, so the problem must be the carbs. I whipped off the carb rack
    and found that some silicone had gotten into the float bowls and was
    turned into a gelatinous mess by the gas. A small blob of jelly was
    blocking the main jet of the right carb completely. I cleaned out the
    bottoms of all the jets with a pin, and I think that I've removed most of
    the spooge that was causing the problem. The jelly in the float bowls
    themselves just wiped off with a rag. Now, I just need to find the
    correct O-rings to seal the bowls to get rid of the initial leakage
    problem. I'll either order the Honda parts, or I'll order rings of the
    right thickness and diameter from McMaster-Carr if the Honda parts turn
    out to be unreasonably dear.
    Moral of the story: silicone sealant + gasoline = bad things
    Oh, and does anyone know of a solvent that will dissolve any lingering
    remnants of silly-cone? Removing and reinstalling the carbs is an
    annoying task, and I hope not to have to repeat it.
    Thanks,
    Andrew
  2. Andrew Szafran
    Pete Guest
    I'm not sure you're blaming the right thing.
    My understanding is that the RTV silicon out of a tube cures in the presence
    of water, like with the humidity in the air. I think Krazy Glue works this
    way also.
    Once I went on a web quest to find a solvent which would dissolve cured RTV
    silicon. Some of the solvents, if I remember this right, was stuff that's
    just not practical to work with at home, like ether. And they don't dissolve
    it, just soften it up.
    I've seen that jelly krap in carbs, when I've seen it it's come from letting
    old gas evaporate from the bowls.
    RTV silicon and gasoline are probably perfectly compatable, once it's cured.
    Don't know about in between.
    D.
    Pete, Jul 18, 2004
  3. Nope, the bowls were clean last week when I tore down the carb bank. The
    nasty spooge was mainly around the float-bowl/carb interface, making me
    pretty damn sure that the silicone was in fact the problem. Hopefully, I
    good soaking in carb cleaner will get rid of any lingering pieces of
    silicone, and after I find appropriate o-rinds, I can go back to riding :)
    -Andrew
  4. Andrew Szafran
    Paul Calman Guest
    I don't know of any silicone product that is actually fuel proof, regardless
    of salemen's claims. I soak siliconed parts in gas to remove it. The ethanol
    or alcohol present in modern gas prevents using the old standbys like
    permatex too. The only fuel proof sealant than I know of, that is also
    alcohol proof is Hylomar.
    Paul Calman, Jul 18, 2004
  5. Andrew Szafran
    XS11E Guest
    Well, dang it, you got my hopes all up!
    XS11E, Jul 18, 2004
  6. Andrew Szafran
    Polarhound Guest
    JB Weld is fuel proof :)
    Well, it is for at least 4 years as that's how long I've had a slab of
    it patching up the gas tank of my cage..
    Polarhound, Jul 18, 2004
  7. sounds as though you didn't let the silicone cure properly first before
    refitting and allowing the cards to fill or you applied to much silicone
    steve robinson, Jul 18, 2004
  8. Andrew Szafran
    bowman Guest
    Methylene chloride swells and softens it, causing it to lose adhesion. It's
    not a solvent and you'll still have to remove the RTV mechanically.
    bowman, Jul 18, 2004
  9. Andrew Szafran
    Lee Guest
    Permatex Motoseal is supposed to be the best for gasoline resistance.
    I used an anaerobic gasket maker a couple of years ago on my Honda
    nighthawk carb float bowls because they were leaking and I would have
    had to buy a complete rebuild kit (4)just to get the gaskets. 18 k
    later, still no leaks. Lee
    Lee, Jul 18, 2004
  10. Andrew Szafran
    bowman Guest
    Thiokol polysulphide adhesive sealant. They were trying to brew up a better
    synthetic rubber when they found it also made a hell of a rocket fuel. The
    solvents will attack some plastics, but it is a great metal to metal bond.
    bowman, Jul 19, 2004
