On a roll
Discussion in 'Australian Motorcycles' started by Don & Cheryle Smith, Mar 4, 2008.
  1. Seeing I'm monopolising this forum at the moment I thought I'd slip another
    quick one in.
    I'm thinking of fitting those visual tyre pressure indicator caps on the
    bike. As with most bikes these days it is difficult to check/inflate with
    servo air lines and you lose a bit of pressure each time you check them at
    home.
    Has anyone had any feedback on whether they are worth while?
    Thanks
  2. Don & Cheryle Smith
    Yeebers Guest
    I think they're worth threefiddy .. and some change :)
    I'd be more concerned if I was on the road but I reckon there's room for
    complacency re tyre pressures if a quick peek was all it took to check
    them - they may stick, and you not realise, depending how they work.
    That's me though, and you're not me so you may treat them differently to
    how I would.. dunno.
    That enough of a disclaimer ? :)
    Yeebers, Mar 4, 2008
  3. Don & Cheryle Smith
    John Dwyer Guest
    I cannot comment of the visual tyre pressure indicator caps. At home I
    inflate the tyres with a bicycle track pump and check them with an
    electronic pressure gauge.
    John Dwyer.
    John Dwyer, Mar 4, 2008
  4. Don & Cheryle Smith
    Grump Guest
    Had them on the 'bird for over a year & now on the K1200...no probs.
    G.
    Grump, Mar 4, 2008
  5. Don & Cheryle Smith
    CrazyCam Guest
    Well, over on the U.C. forum, those things were actually discussed.
    (Probably a newbie there who thought something to do with motorcycles
    was acceptable.)
    It seems that if those caps fail, they fail by letting all the air out. :-|
    I'd honestly suggest that, next time you are getting new tyres, fit an
    angled valve in each wheel. Makes it much easier to do the tyre checking.
    regards,
    CrazyCam
    CrazyCam, Mar 4, 2008
  6. Don & Cheryle Smith
    will_s Guest
    You can buy an extensiuon thats angled which does the same job
    will_s, Mar 4, 2008
  7. I wouldn't fit them. Too much of a risk of them leaking, plus the extra
    weight hanging off the valve stem can't be good. By all means, use them
    to pump and check the tyre, but don't leave them on.
    Actually, I'm with Cam. Fit the proper angled valve at the first
    opportunity, coz the angled extensions are a bitch to use anyway.
    Peter Cremasco, Mar 5, 2008
  8. Don & Cheryle Smith
    Nev.. Guest
    If you think that the amount of air which leaks while you're quickly
    removing the gauge is going to make that much difference you probably
    should be filling your tyres with hydrogen instead.
    Nev..
    '07 XB12X
    Nev.., Mar 5, 2008
  9. Don & Cheryle Smith
    CrazyCam Guest
    You can indeed, and I had one of those fitted to the back tyre of my
    Suzi cruiser, since it was a tubed tyre and the tube had the valve
    attached.
    I covered about 80,000 kms, with the angled extension fitted without a
    problem, but, for a tubeless tyre/wheel, I'd prefer the neater option of
    the angled valve.
    regards,
    CrazyCam
    CrazyCam, Mar 5, 2008
