Old BSAs
Discussion in 'UK Motorcycles' started by muddy, May 20, 2006.
  1. muddy
    muddy Guest
    Did BSA manufacture bikes with the shift on the right side and rear
    brake on the left?
    muddy, May 20, 2006
  2. Er, yes, as did every other Brit and quite a few Italian
    manufacturers....
    And?
    The Older Gentleman, May 20, 2006
  3. muddy
    SD Guest
    manufacturers....
    And?[/QUOTE]
    ... some Japanese manufacturers, too.
    | ___ Salad Dodger
    |_\_____/_| ..79553../..21469.../..31308.
    '^' RBR'06 Points: 75 Miles: 317
    SD, May 20, 2006
  4. muddy
    muddy Guest
    Just curious. Someone mentioned this to be the case. I did have a 1960s
    something BSA single (250?) but I couldn't remember.
    muddy, May 20, 2006
  5. ... some Japanese manufacturers, too.[/QUOTE]
    And Suzuki did both - on the same bike....
  6. muddy
    Guzzi did too.
    sweller, May 20, 2006
  7. T500 and a couple of other early twins. They could be swapped from
    right-foot to left-foot shift and vice versa.
  8. That I didn't know.
  9. muddy
    V7s, 750S and the last convertible one was the 850T - IIRC what Gary
    (Wesson's mechanic) told me years ago.
  10. muddy
    SD Guest
    right-foot to left-foot shift and vice versa.[/QUOTE]
    As could the H1.
    | ___ Salad Dodger
    SD, May 20, 2006
  11. As could the H1.[/QUOTE]
    Yes, I'd forgotten that.
  12. muddy
    muddy Guest
    <writes in book>
    muddy, May 20, 2006
  13. muddy
    Beav Guest
    Yes.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 20, 2006
  14. They were built that way. However, they were designed so that you could
    pull out the gear shift shaft, and stick it through the right-hand
    casing, and the left-hand side of the frame had mounts for the brake
    pedal and linkage.
    Some people did the swap because they were brought up on right-hand gear
    changes. The other group that did it was racers.
    The Older Gentleman, May 21, 2006
  15. ISTR one bike (Ducati?) that at the time of the introduction of the
    US mandate for LH gearshift ran a gearshift shaft completely through the
    gearbox, with a splined end available both sides.
    Dr Ivan D. Reid, May 22, 2006
