Old Bikes... BSA A65
Discussion in 'Classic Motorbikes' started by deadmail, Feb 16, 2004.
  1. deadmail
    deadmail Guest
    If I was interested in one of these what should I know?
    OK, they leak oil and will feel really underbraked but apart from that
    what are the downsides?
    Naturally it's only a toy I'm looking for and something to feed my
    looming mid-life crisis...
  2. deadmail
    Geoff Berrow Guest
    You probably need to know what I'd like to know.
    Where you can get a complete one, in reasonable nick, that you can
    afford.
    Those seem to be my biggest problems. :)
    Geoff Berrow, Feb 16, 2004
  3. deadmail
    mubbueth Guest
    I am no expert, but my 2d is: don't pay a premium for any special flavours
    or other BS; try to pay pay less, because either it's fake, therefore
    dodgy, or it will cost more to get the rest of the old POS back to original
    and keep it running. Try and buy a dirty one.
    mubbueth, Feb 16, 2004
  4. deadmail
    Geoff Berrow Guest
  5. deadmail
    deadmail Guest
  6. deadmail
    was seen penning the following ode to ... whatever:
    British build quality and electrics by the Prince of Darkness,
    mainly. Get one that's been rebuilt by someone who knows.
    Timo Geusch, Feb 16, 2004
  7. deadmail
    deadmail Guest
    Tch! that means spending real money... I'd rather buy one cheap and pay
    twice as much (in the long run) fixing it myself.
  8. deadmail
    Salad Dodger Guest
    How is the H1, by the way? :)
    | ___ Salad Dodger
    |_\_____/_| ..62743../..14719.../..3157./.19406
    \|^|/ ANORAK#17
    Salad Dodger, Feb 16, 2004
  9. deadmail
    .... and in the process, aquire a machine shop to rival Mr Eaton's.
  10. deadmail
    deadmail Guest
    Oh, the last time I used it it was fine. Mind you that was about two
    years ago.
    When did I ever try to stop you buying toys? What did I do to deserve
    this unwarranted and unwanted interjection of good sense? Tch!
  11. I've heard that the A50s are more reliable (understressed), cheaper (less
    glamorous), yet deliver the same kicks, albeit with slightly less
    performance. Bear in mind that none of these will greatly out-perform your
    CB250RS.
    pseudoplatypus, Feb 16, 2004
  12. deadmail
    deadmail Guest
    You say that as if it's a bad thing.
  13. deadmail
    Previously on ukrm, pseudoplatypus said...
    Probably would outperform mine. 172,000 miles now. I'm itching to get it
    over 200,000.
    Lozzo, Feb 16, 2004
  14. deadmail
    deadmail Guest
    I'd not thought of an A50 (or an A7). It has to be an A10 or A65
    really.
    And re the performance, well whilst the top end might be more I doubt
    I'd want to experience it often. Anyhow, where did I say I wanted to
    ride it?
    deadmail, Feb 17, 2004
  15. Badge it, then. No **** will be able to tell. Didn't Ged show up at an
    EOSM on an A65 one year? You'll be smelling of wee next.
    An ornament. Good decision.
    pseudoplatypus, Feb 17, 2004
  16. deadmail
    deadmail Guest
    EOSM on an A65 one year? You'll be smelling of wee next.[/QUOTE]
    Yes, he did.
    And what's this 'next' business? I've smelt of wee for years. Or do
    you mean my own since that would be a novel experience.
    Garage Jewelry.
  17. Yes, he did.
    you mean my own since that would be a novel experience.[/QUOTE]
    Well, I was thinking Ged's.
    Will you be able to fit it in?
  18. deadmail
    deadmail Guest
    Once I either:
    a) sell the decrepit K100 - No fairing, brakes need attention, rear
    shock gone but engine good (rebuilt recently)
    b) build a garage extension
    Yes.
  19. I recall a couple of acquaintances having A65 and the earlier A10.
    They both ended up changing main bearings and having the crankshaft
    ground. This of course may have been more a symptom of shite
    maintenance than an inherent fault. Mine dew IIRC the oil filtering on
    most Brit Bikes of that era is quite crude so regular changes are
    needed - although it's possible with some too convert to take a
    cartridge filter.
    650 Bonneville?
    Boots Blakeley, Feb 17, 2004
  20. deadmail
    Using a high detergent oil to keep the crap in suspension when its
    changed.
    That's why, IIRC, diesel oil is the lubricant of choice for non T4
    aircooled VWs.
    sweller, Feb 17, 2004
