OK, we're stuck :-/
Discussion in 'UK Motorcycles' started by Ginge, Dec 21, 2003.
  1. Ginge
    christofire Guest
    Just be carafe-ul when ordering, eh?
    christofire, Dec 22, 2003
    #41
  2. Ginge
    Donegal Paul Guest
    "Dr Ivan D. Reid" said to Donegal Paul who said
    Ah, yes, that would explain those big round things on top of the carbs :)
    Ive not opened them up that far but guess I prolly should to make sure said
    diaphragms are not split.
    Donegal Paul, Dec 22, 2003
    #42
  3. Ginge
    Mark Olson Guest
    NB: Some older Honda CV carbs (the sort with vacuum operated slides) use
    an actual metal piston rather than a rubber diaphragm to lift the
    cylindrical slides... but your bike is prolly new enough to have the
    rubber diaphragm type. If you do have the metal piston type, make sure
    all the bits are all squeaky clean and burr-free.
    Mark Olson, Dec 23, 2003
    #43
  4. Good point. The 250 and 400 Super Dream versions of that engine used the
    metal type, but I dunno about the 350. O'd expect it to be metal as
    well.
    The Older Gentleman, Dec 23, 2003
    #44
  5. Ginge
    Donegal Paul Guest
    Cheers guys, will do.
    Donegal Paul, Dec 23, 2003
    #45
  6. Ginge
    Donegal Paul Guest
    Guess what? Nope to the metal bits, its rubber diaphramed connected to the
    tops of the pistons :-/
    http://www.thepilgrimssc.co.uk/images/cb/carbdiaphragm01.jpg
    http://www.thepilgrimssc.co.uk/images/cb/carbdiaphragm02.jpg
    One of the pistons looks nice and shiny the other -->
    http://www.thepilgrimssc.co.uk/images/cb/carbpiston01.jpg does look a little
    black in places round it, not sure what that's indicative of though.
    On saying that everything seems pretty clean internally which is reassuring
    but I do have reservations about what I believe is the air cut off valve
    which has a diaphragm which looks a bit dirty and even a little rust on the
    inner of it.
    http://www.thepilgrimssc.co.uk/images/cb/aircutoff01.jpg
    http://www.thepilgrimssc.co.uk/images/cb/aircutoff02.jpg
    http://www.thepilgrimssc.co.uk/images/cb/aircutoff03.jpg
    #46
  7. Ginge
    mb Guest
    Eew, them's some nasty looking carbs...
    The 'aircutoff02' looks like an accelerator pump, to provide a bit of
    extra fuel when you open the throttle.
    All those rubber bits need to be whole, with no holes or splits in them.
    mb, Dec 23, 2003
    #47
  8. Coo! They are rubber!
    The main carb diaphragms look OK, but you need to remove them and hold
    them up to the light to be sure.
    Those little air bleed diaphragms are a right PITA.
    #48
  9. Ginge
    Donegal Paul Guest
    "mb" said to "Donegal Paul" wrote in message
    Yeabut the internals seem pretty clean.
    All appear to be on first inspection.
    #49
  10. pseudoplatypus, Dec 23, 2003
    #50
  11. Ginge
    Donegal Paul Guest
    Cheers TOG, Ill do that tomorrow, as for the little diaphragms, I can only
    get at one, as the other is inside the other carb and I haven't split them
    yet, I suppose I have to if I want to be sure :-/
    #51
