OK, we're stuck :-/
Discussion in 'UK Motorcycles' started by Ginge, Dec 21, 2003.
  1. Donegal Paul wrote
    You could also try a can of easy start up the air intake, if it don't go
    then, then it don't go.
    steve auvache, Dec 21, 2003
  2. Ginge
    tallbloke Guest
    Put yer cig out first.
    tallbloke, Dec 21, 2003
  3. ^..^ Lone Wolf, Dec 22, 2003
  4. Ginge
    Donegal Paul Guest
    "^..^ Lone Wolf" ---> "Donegal Paul"
    Cheers all, well just spent a half hour or so draining the tank and
    refilling with fresh fuel, but still no joy :-(
    Me thinks the carbs are gonna have to come off today :-/
    Donegal Paul, Dec 22, 2003
  5. Ginge
    Even better, buy a new set, they're not expensive.
    As others have said make sure the points gap (if it has points) is
    correct and the timing is set correctly. If the timing is far enough
    out, or the points aren't opening corretly, it won't even cough.
    If you have fuel and sparks it's normally timing or plugs (they fail
    under compression when cold).
    Another trick is to pour a small amount (teaspoon) of petrol down the
    plug holes then screw plugs back in and try again.
    Does the choke work? Is the air filter choked with twigs and dead
    animals?
    How fucked is the battery?
    sweller, Dec 22, 2003
  6. Ginge
    The ones in my race bike are £120 quid a set.
    No, I didn't buy them :)
    Champ, Dec 22, 2003
  7. Ginge
    If the petrol tank smells of gloss paint you *will* have to clean the
    carbs. It's gone off and gummed up the works.
    Use cellouse paint thinners, it's cheaper than carb cleaner, or just use
    a aerosol carb cleaner. Knock yourself out.
  8. Ginge
    I'll apologise if your race bike is a CB350 ...
  9. Ginge
    No apology necessary!
    I did a quick web search, but couldn't find the prices of NGK racing
    plugs listed anywhere.
    Champ, Dec 22, 2003
  10. Ginge
    Quite. The 'new' race ZX7R I picked up recently refused to start this
    weekend - it had been standing since August. I took the float bowls
    off and found that 3 of the 4 pilot jets were blocked. Remove, blow
    through, replace, re-fit carbs - started instantly.
    Champ, Dec 22, 2003
  11. Ginge
    Petel Guest
    Concentrate on the pilot jets and the floats/float valve needles first. An
    overnight soak in carb cleaner might be nesseccary.
    If it`s running CV`s check for splits in the diaphrams, this won`t affect
    the starting but you might as well look while you`re there.
    Petel .
    02 M2 Buell.
    C90-ZZR.
    http://homepage.ntlworld.com/peteh1/website/index.html
    Petel, Dec 22, 2003
  12. Ginge
    Donegal Paul Guest
    Might do that once ive stripped and cleaned out the carb as necessary
    Dunno if its points or not yet, not delved into it that deep today. But Ill
    check.
    Was gonna try that, but ummmmmmm didnt
    Choke works, air filter is a little dirty but actually looks pretty good.
    Was fine, prolly fucked now though with my trying to continually start it.
  13. Ginge
    Donegal Paul Guest
    Carbs are off and once ive fitted a new dining room light and put up the
    crimbo tree tonight, ill be in my shed stripping le carb
    It didnt but ive already drained it and put in fresh fuel anyway.
  14. Ginge
    Donegal Paul Guest
    "Petel" said to "Donegal Paul" who said
    Will do, but <numpty mode on> CV's???? Wossat? </nmo>
  15. Ginge
    SteveH Guest
    *thud*
    That almost puts Alfa Romeo to shame..... I'm sure Andy Hewitt will be
    able to give us the cost of replacing OEM plugs on a twin-spark engine.
    SteveH, Dec 22, 2003
  16. Ginge
    Golden Lodge, sir? Recommend a mortgage, sir.
    Pip, Dec 22, 2003
  17. Ginge
    SteveH Guest
    Heh.
    ISTR a single, platinum tipped Golden Lodge is £20. So that's £240 a
    set.
    They are specified to last 60k miles, though.
    Good job mine accepts a cheaper alternative (£24 a set)
  18. Ginge
    flashgorman Guest
    He means does it have some sort of resume of its career so far?
    flashgorman, Dec 22, 2003
  19. Ginge
    Donegal Paul Guest
    "flashgorman" said to "Donegal Paul" who said
    Not a jot :)
    Moving on though.
    This evening, ive managed to work on the carbs and so far ive determined
    that the floats are intact, the float needles are fine and the jets appear
    clean. The throttle is definitely working and the choke lever is moving up
    and down properly.
    What I do wonder though, looking inside the carbs, there's the two pistons
    yeah? Do they not, or should they not move up and down. I don't mean in the
    way engine pistons do, im not that thick, but surely these must move up
    somehow when applying the throttle to allow more fuel / air through and
    hence speed??
  20. Ginge
    SteveH Guest
