Oily air filter
Discussion in 'UK Motorcycles' started by Whinging Courier, Sep 4, 2005.
  1. Whinging Courier
    Ginge Guest
    Hint: FILTER.
    What do you think it's supposed to do?
    Ginge, Sep 4, 2005
  2. Whinging Courier
    Eiron Guest
    Eiron, Sep 5, 2005
  3. Whinging Courier
    You'll need to jet the carbs and have them set up properly to get the
    engine to run right with those fitted. If you don't you might melt a
    piston by running too weak. Seperate K&Ns are infamously crap in the
    rain, too - give an effect much like running on choke, for a bit -
    then you come to a stop and stay there until the road dries out.
    Pip, Sep 5, 2005
  4. Whinging Courier
    Bellmouths. The only real solution.
    sweller, Sep 5, 2005
  5. Whinging Courier
    I'm sure that some sort of bracket can be made to support them, and a
    sort of cover, to stop them getting wet in the rain. Although in true
    rat style, a cover can be bade out of old plastic drink bottles or
    something.
    Muck, Sep 5, 2005
  6. As muck says, a bracket can be made, but you often see the carbs
    without.
    Related stuff...as you were thinking K&N...
    http://www.bobistheoilguy.com/airfilter/airtest1.htm
    Grimly Curmudgeon, Sep 5, 2005
  7. Whinging Courier
    Interesting, that seems to say. Keep your air box and standard air
    filter. I'd argue then, that the main reasons to go to individual K&N
    filters on a road bike are;
    Increase intake noise[1].
    **** up the fuleing.
    Cause problems with riding in the rain.
    Decrease filtering.
    Increase servicing complexity[2].
    Give your money to K&N because someone told you all on the above was
    actually good.
    [1]Coz everyone loves a noisy bike.
    [2]You need to wash / re-oil them individually, as opposed to junking
    your old filter and fitting a new one (easy peasy).
    Muck, Sep 5, 2005
  8. That's the only reason I've ever used K&N (or equiv); to cut down on
    long term servicing costs, or in an unusual application.
    Fwiw, the GSs filter is washable and reuseable as standard; or it was,
    until it got junked, along with the carbs.
  9. Whinging Courier
    My CG has a washable filter too, seems to be the way of older designs it
    does. What happened to those fangled electrostatic filters, are those
    better?
    Muck, Sep 5, 2005
  10. Dunno; I've never encountered one on a car or bike. I've come across
    them on other stuff and they certainly seem to work, but as to whether
    they work better or worse than conventional filters I couldn't say.
  11. In uk.rec.motorcycles, Pip amazed us all with this pearl of wisdom:
    The same thing happened on my 50 when I put a big bore kit on it. I used
    the oil tank for two stroke but pre-mixed the petrol just for good
    measure and after a night wiv me burd, it did just that, ran like a
    lepur and then konked out completely.
    Whinging Courier, Sep 6, 2005
  12. In uk.rec.motorcycles, Grimly Curmudgeon amazed us all with this pearl
    of wisdom:
    I read that this morning. Very interesting and not quite the results I'd
    have expected.
