OIL: The continuing mission to decide - 5w/40 or 10w/50
Discussion in 'UK Motorcycles' started by Nidge, Oct 16, 2004.
  1. Nidge
    Nidge Guest
    So I've got as far as 'I should get fully synth'.
    Now I have the problem Kawasaki say use 10w/50
    Castrol say if that's what Kawasaki recommend they *ought* to be right
    But on the shelves it all seems to be 5w/40 and asking for 10w/50 I get told
    by the bloke trying to sell the stuff 5w/40's better.
    Yeah well, better for them to sell something is obvious. But beyond that
    why? I thought 10w/50 would be better for protecting a hot motor. OK 5w
    will give a bit more protection from cold but being a wuss and hating salt I
    don't usually ride when its *really* cold, beside it lives in the garage.
    So why's 5w/40 so popular and recommended grade isn't?
    Nidge
    ZX6R J2 Stunning in zit yellow. KX 125 MX 'I'm snot green -fly ME'. A few
    bits of CB500S in Norwegian Parrot blue. BOTAFOT#63 BOMB#5
    'Just because I don't care doesn't mean I don't understand'.
    Homer (Simpson).
    Nidge, Oct 16, 2004
  2. Nidge
    dwb Guest
    Does your manual not give you a breakdown of when to use what?
    In the GSX-R manual it lists the grade to use based on ambient temperature.
    ARAIR, using 10w or 5w will be fine.
    dwb, Oct 16, 2004
  3. Nidge
    Andy Hewitt Guest
    You'll also find that there's a large overlap too.
    Personally I like using 10w/40.
    Having said that, the FJ owners club recommend 10w/40 for the winter and
    20w/50 for the summer.
    Andy Hewitt, Oct 16, 2004
  4. Nidge
    OH- Guest
    How much hotter does a water cooled engine get in the summer ?
    All this about different oil for different climates makes a lot more
    sense for air cooled engines.
    At the cold end, both 5W and 10W are fine as long as you don't
    do cold starts in true arctic temperatures.
    OH-, Oct 17, 2004
  5. Nidge
    Andy Hewitt Guest
    It does a little, certainly nothing like the air cooled lump does
    though.
    Yes, as a rule I'd just stick to a 10w/40, it's the best sompromise, and
    I doubt you'll ever find out the difference anyway.
    You only really need to worry about viscosity if you are going to use
    the machine in extreme conditions - such as racing or arctic.
    Andy Hewitt, Oct 17, 2004
