Oil temperature gauge
Discussion in 'UK Motorcycles' started by Dan L, Dec 21, 2004.
  1. Dan L
    Dan L Guest
    I have just treated myself to one of those oil temp gauges that screw in
    where the oil filler goes. A very handsome bit of kit, with a luvverly
    knurled ring (ooh er missus) and an oil filled analogue display.
    I have been looking for one for ages, but no one in the UK seems to stock
    much in the way of aftermarket bits for Zephyrs, so I ordered it online from
    www.louis.de in the fatherland. It only took 10 days to arrive, and was 26
    euros, which does not seem to be a bad price at all.
    Anyway, having eagerly fitted it and left the bike running in the shed [1]
    for half an hour or so it seems to have settled at around 80°C. It'll be
    interesting to see what it gets up to on a run, with the added bonus of
    giving me another thing to fret about [2].
    [1] with both sets of doors open, of course
    [2] along with brakes and tyres.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R
    Spare Bike 1990 Suzuki TS50X
    BOTAFOT #140, DIAABTCOD #26, BOMB#18 (slow)
    Dan L, Dec 21, 2004
  2. Dan L
    I'd like one of these for my Bandit, and a pressure gauge, being an air
    / oil cooled engine, oil temp is quite important. The FZR, I'd like to
    keep tabs on both pressure and temperature too.
    Shame the web shite seems to be in German. :/
    Muck, Dec 21, 2004
  3. Dan L
    Dan L Guest
    <snip>
    Well, yes *and* no.
    I am always concerned about the oil temperature, particularly as after a
    good run, it sort of ticks when you switch it off, which prompts comments
    such as "you've given that a good thrashing then". Anyone who has ridden out
    with me will know this is not the case, as the Zephyr and I are still
    deciding who's boss. At least now I have the gauge I'll know it's just
    normal engine cooling down noises [1].
    [1] or not, if the thing goes into the red (in which case I think I'll just
    send it back)
    Dan L (Oldbloke)
    Dan L, Dec 22, 2004
  4. Dan L
    Martin Guest
    Martin, Dec 22, 2004
  5. Dan L
    Besides, for techie types that know about engines, an oil temp gauge can
    tell you about engine / oil health. An oil warning light won't tell you
    that the pressure has been falling off for the last few hundred miles.
    The only thing a pressure warning light is good for, is telling you that
    you just caused dammage to your engine.
    Muck, Dec 22, 2004
  6. We had great fun with filling out the online order form. My youngest's
    faint grasp of German, and Google's online translator helped.
    oldbloke at work, Dec 22, 2004
  7. Dan L
    I've now got an offer of help with the web site from a friend. Should I
    suddenly come into possession of money, I'll be ordering a temp and
    pressure gauge for my Bandit, after I've ordered the valve shims for my FZR.
    Muck, Dec 22, 2004
  8. Dan L
    Eiron Guest
    It tells you to change from 10W40 to 20W50 and either flog it on ebay
    or run it for another couple of years until it needs a new engine. :)
    Eiron, Dec 22, 2004
  9. Dan L
    Not really, you just knew your car. It's like any car / bike you own,
    you just get to understand the way it's talking to you, and what it's
    saying. :)
    My brother thought that the light was an oil level light on his Fiat
    Panda. When it started to flash on and off, he used to top the oil up.
    *yikes*
    Muck, Dec 22, 2004
  10. Dan L
    Heh, not my style.
    Muck, Dec 22, 2004
  11. Dan L
    Dan L Guest
    Hmm, well the jury is currently out. The Zephyr seems to peak at around
    50°C on a run, which just doesn't seem right.
    After the next run I'll inser my trusty digital thermomenter probe deep into
    the engine to ascertain the true temperature of the oil, and confirm the
    outcome.
    Dan L (Oldbloke)
    Dan L, Jan 2, 2005
  12. Dan L
    50 Deg C does sound a little on the low side. Where is the oil temp
    sender located? After the oil cooler, before or else where?
    Muck, Jan 3, 2005
  13. Dan L
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Muck
    Not the way Dan rides.
    Nigel Eaton, Jan 3, 2005
  14. Dan L
    Hmm... <fx: thinks>
    I think we were joint last on the BOMB run. :)
    Muck, Jan 3, 2005
  15. Dan L
    Dan L Guest
    Harsh
    (But true)
    Dan L (Oldbloke)
    Dan L, Jan 3, 2005
  16. Dan L
    Dan L Guest
    It screws in in place of the oil filler cap. The probe is built into the
    bottom of the gauge and I don't think it's actually immersed in the oil, but
    receives a spray of it from the rotating clutch parts.
    I'll keep you posted.
    Dan L (Oldbloke)
    Dan L, Jan 3, 2005
  17. Dan L
    I remember that now... A bit of a strange location for the sensor,
    sounds more like a crank case temp guage. :/
    Muck, Jan 3, 2005
