oil level
Discussion in 'Australian Motorcycles' started by Jessie James, Aug 15, 2003.
  1. Jessie James
    Jessie James Guest
    Can someone please tell me whether the dipstick has to screwed in all the
    way, or just sat in the top to check the oil level on a 1992 honda cbr900rr
    TIA Reg
  2. Jessie James
    Theo Bekkers Guest
    "Jessie James" wrote
    cbr900rr
    This has been argued here before with many opinions and quotes from
    handbooks.
    The truth is, it really makes ****-all difference.
    Theo
    Theo Bekkers, Aug 15, 2003
  3. Jessie James
    Normally with Fireblades the dipstick sits on the seat (or on a seat nearby bullshitting about how many track
    days he's done).
    .....hope that helps....
    Knobdoodle, Aug 15, 2003
  4. Jessie James
    Moike Guest
    Well, on my bike, it needs to be measured with the dipstick not screwed in.
    If I screwed it in, then I would be putting about a litre less oil in it. I
    suspect that might make a difference.
    Moike
    Moike, Aug 15, 2003
  5. Jessie James
    sharkey Guest
    Damn! Beaten to it by those damn Dohertys again!
    -----sharks
    sharkey, Aug 15, 2003
  6. Jessie James
    TB Guest
    Cue theme music
    TB, Aug 15, 2003
  7. Jessie James
    Theo Bekkers Guest
    "Moike" wrote
    And what would the difference be?
    Theo
  8. Jessie James
    sharkey Guest
    Speaking of which, are you in Melbourne yet?
    Also, I think your surname is disappointingly short, considering.
    'T' had better stand for something pretty amazing, given that
    you informed me at Karuah that you were called TB because your
    full name was 1023 syllables long ...
    -----sharks (I could have got away with it if it wasn't for
    those damn kids^WDohertys^Wbeers!)
    sharkey, Aug 16, 2003
  9. Jessie James
    "T" is short for "Thousandandnineteensyllables".
    Knobdoodle, Aug 16, 2003
  10. Jessie James
    conehead Guest
    about 0.8kg?
    conehead, Aug 16, 2003
  11. Jessie James
    Moike Guest
    When I've topped it up, the equivalent of riding with the oil at the bottom
    of the recommended range. If it gets much lower? I'd rather not find out.
    I just assume there is some reason for those recommended oil levels.
    Something to do with adequate cooling and lubrication perhaps?
    Moike
    Moike, Aug 16, 2003
  12. Jessie James
    Theo Bekkers Guest
    The difference in the Guzzi, which holds 3.5 litres, is less than half
    a litre. Helen's bike only holds 2 litres.
    Interestingly, in the early '80's Moto Guzzi decided to do something
    about the oil cooling and fitted a deeper sump (added a sump spacer
    actually) but continued to use the same dipstick so had more oil in
    the sump. This caused some foaming (of the oil, and subsequently the
    rider) resulting in blowing it out the rear (breather). They fixed
    this problem by remarking the dipstick about a litre lower.
    As long as there is oil in the sump and it is above the pump pick-up
    point there is no real problem. I would suggest there would be less
    than a half litre in the sump at that point and indication would be
    off the bottom of the dipstick.
    I don't feel the need to be anal about the oil level being within 5 or
    10 mm of an arbitrary point.
    Theo
    Theo Bekkers, Aug 16, 2003
  13. Jessie James
    sharkey Guest
    "Do not screw them in when making this check."
    -- Honda XLV750R workshop manual.
    -----sharks
  14. Jessie James
    Theo Bekkers Guest
    "sharkey" wrote
    How many are there?
    Theo
  15. Jessie James
    John Littler Guest
    ....snip
    With all due respect, while that may be true of Guzzis it very much will vary
    bike to bike. Depending on whether it's wet sump or dry sump, the design of the
    pickup points the level in a flat shallow container varying a couple of mm is a
    lot more crucial than the level in a narrow deep container.....big difference in
    liquid volume, whether that delta in volume matters depends of course.
    JL
    John Littler, Aug 16, 2003
  16. Jessie James
    conehead Guest
    Do they screw in from above or below?
  17. Jessie James
    sharkey Guest
    Depends on which way up the bike is.
    -----sharks (five, if you count sump drain plugs ... and hey, if
    the sump plug is dry, you _really_ need oil ...)
  18. Jessie James
    sharkey Guest
    Yeah, dry sump. One in the top of the frame oil tank, and another
    in the sump. God only knows why. The level in the engine never
    changes, and the level in the tank varies so wildly you just can't
    tell.
    -----sharks
  19. Jessie James
    TB Guest
    Been in Melbourne for a while now, since late July. Haven't got the bike yet
    though. Called up to arrange transport for it and seems it wont happen till
    next week and I can't afford to fly up and ride done...
    TB
    '99 GSXR600
    '88 CBR250R
    They called me Basnayake Wasala Mudiyanselage Tharanga Basnayake, but I
    think TB's easier...
    TB, Aug 18, 2003
  20. Jessie James
    Steve Strik Guest
    The ZX-6R is like that. On the side stand, no oil, eeeeek. Try and
    hold bike vertical while looking in window, oil appears (yay). Put
    bike up on centrestand, no oil in window. How level the group is and
    how steady you can hold the bike up has a big influence on the level
    showing in the window (at least on my bike).
    Regards
    Steve
    Steve Strik, Aug 18, 2003
