oil leak help
Discussion in 'Australian Motorcycles' started by ryan scott, Aug 19, 2006.
  1. ryan scott
    ryan scott Guest
    anyone know what part this is? (see pic attached). the bike only leaks if
    leaning on the kick stand. if i keep the bike vertical it doesnt leak.
    any suggestions
    thanks
    http://i8.tinypic.com/24yczdz.jpg
  2. ryan scott
    Nev.. Guest
    That's probably the gear selector shaft leaking.
    Nev..
    '04 CBR1100XX
    Nev.., Aug 19, 2006
  3. ryan scott
    Fwoar Guest
    I concur
    Fwoar, Aug 19, 2006
  4. ryan scott
    ryan scott Guest
    gear selector. is that easy to repair? should i take it in to get fixed?
  5. ryan scott
    Fwoar Guest
    by looking at the pic - I would say it isn't a super hard job if you have
    some mechanical knowledge.
    take the gear selector off
    take the clutch slave cyl off - leaving it on the clutch line to save you
    rebleeding it later
    take the sprocket cover off.
    then you should be able to see the seal.
    then you have a couple of options.
    pick the seal out & replace like it is - being careful over the shaft (
    making sure there are no burs or built up grease on it that can sour the
    seal)... or
    pull it all apart & do it as per the honda service manual
    Fwoar, Aug 19, 2006
  6. ryan scott
    Biggus Guest
    Unless its like the FZ750, which was a split the cases job (or was
    that countershaft seal) :(
    Biggus, Aug 19, 2006
  7. AND there's usually a size on the seal which means you DONT have to
    buy a genuine Honda part. If you cant see any numbers and the seal isnt
    too damaged take it to a bearing shop. They can measure it.
    Isaac.
    isaac_the_blind, Aug 20, 2006
