Oil, filters...
Discussion in 'Australian Motorcycles' started by GB, Dec 29, 2003.
  1. GB
    GB Guest
    First service time (in a few days, anyhoo). What's
    the good oil for a ZZR250? Anyone know where on
    Sydney's north shore that will sell me a filter
    (that isn't Sydney City Motorcycles, of course!).
    TIA,
    G
    GB, Dec 29, 2003
  2. GB
    Johnnie5 Guest
    you could order it from www.maw.com.au
    and not have to go anywhere
    or if you wish to go somewhere google for mechanics and there is a couple of
    guys on the northside that could help you out
    also could head into the city to MCA on wentworth ave ? or actions
    Johnnie5, Dec 29, 2003
  3. Steer clear of Northside tho...
    google will reveal why, if you care...
    Yeah, MCA in town (or in Parra) will have what you want.
    As for oil, I'm using (and am very happy with) Motul 5100 - you can
    usually pick up a 4L container of it for just under $40 from MCA.
    If I remember rightly, you're still running that thing in, aren't you?
    Lots of people recommend steering clear of synthetic oils until 5,000km
    or so, on the grounds that they lubricate _too_ well, and don't let the
    run in process work properly, so a cheap mineral oil might be better
    (I'm not too sure of the truth in this claim though...)
    big
    Iain Chalmers, Dec 29, 2003
  4. GB
    Johno Guest
    Iain Chalmers wrote:
    Snip heaps...
    Iain, Why have you changed to the fully synthetic oil? Do you race the
    bike?
    Mineral oil will lubricate just the same as synthetic oil (at normal
    operating conditions) - I can't see the value of spending shit loads
    more on oil when the bike is used for normal road use - I do not
    believe that the the likes of Honda, Yamaha, Suzuki, Kawasaki and the
    multitudes of other bike makers recommending that a mineral oil of
    either SF or SG grade will suffice in their motors only to have a bike
    shop say you need synthetic oil?
    Definately not a cheap mineral oil... but a recognised grade (SF min)
    cheers
    Johno
    Johno, Dec 29, 2003
  5. In aus.motorcycles on Mon, 29 Dec 2003 19:09:52 +1030
    The main advantage of synthetic is that it survives being cut up by the
    gearbox longer.
    For a high mileage bike under a reasonable load - which describes the
    Spada pretty well - this is a Good Thing.
    The factories aren't that interested in having your bike survive for
    100,000+ km and many years. You may be.
    Zebee
    - who uses cheapish dino oil in the Guzzi because it has a separate
    gearbox. The Yam will probably stay on dino oil cos it's changed
    more often for time reasons than mileage. The Ducati eats straight 50,
    I don't think they make that in synthetic.
    Zebee Johnstone, Dec 29, 2003
  6. GB
    Johno Guest
    This may well be the case, however, I believe that if the mineral oil
    is changed regularly (ie, bike makers recommended milage) then there
    will always be fresh oil in the gearbox.
    Are you implying that the spada would not be in the same condition if
    it was run purely on mineral oil and all servicing was done by the
    book?
    Should be easily achievable on mineral oil - again, as long as the
    service is done by the book.
    which I assume will do the intended jod :)
    and that will go for ages ;)
    Johno, Dec 29, 2003
  7. GB
    atec77 Guest
    Do you have Fuches down your way ?. they do make a 50 weight in pure
    synth , hard to get but available.
    atec77, Dec 29, 2003
  8. GB
    Marty H Guest
    I have to laugh sometime about people wont use some shop for a $15 item
    "oh they are crooks"
    "oh they did a bad service on a mate's, brother's girlfriend's ex roommates
    cousin's gay lover's Vespa"
    if you cant get one closer, just buy it off them...its an oil filter ffs
    who is it really inconvenienced? the dealer, cos you don't buy a $15 part of
    them or you for running around Sydney wasting your time and money???
    for servicing or buying a bike...then chose the dealer
    mh
    Marty H, Dec 29, 2003
  9. Nah, the 5100 is not full synth, its "Semi-synthetic" accorting to
    Motul... from:
    <http://www.motul.co.jp/eg/product_line_up/4stroke/4stroke11.html>
    "Specially developed for engines that require simultaneous lubrication
    with its transmission applications, 5100 ESTER 10W-40 maintains
    stability and ensures less friction even at extreme temperatures or
    under heavy loads. With its extreme pressure additives, gear shifts are
    enhanced. 5100 ESTER 10W-40 guarantees efficient wet clutch performance
    as well as gearbox longevity."
    I mainly use it because it was recommended by a mechanic I trust (who,
    unfortnately, is no longer in the business). I used to use Aral fully
    synthetic, but its become less easy to get hold of, where just about
    every bike shop stock Motul.
    I'm not sure how much I believe the "this oil is specially developed for
    use in motorcycles" marketing blurb that all the oil companies use to
    convince you to spend twice as much as their similarly graded "car
    oils", but it does seem to me that combined motor/gearbox lubrication
    and wet clutches do throw additional challenges at motorcycle oils, and
    the marginal extra cost of the Motul oil is small enough that I'm happy
    to buy it for even some possibly fictitious "extra motorcycle
    protection" (especially since the Spada takes less than 2L on an oil
    change).
    I don't race the bike, but I do thrash it occasionally (trackdays only,
    of course, officer!), and I do quite a lot of km (its up around
    180,000km now).
    big (besides, buying bike oil is an excuse to go to the bikeshop! ;-)
  10. GB
    Johno Guest
    snip again...
    Yes, agreed, the cost per oil change would not be that noticable.
    would be interesting to see a comparison between the syn and min oil
    over the same time / milage :)
    We *need an excuse to go to the bike shop? ;)
    Johmo
    Johno, Dec 29, 2003
  11. I'm pretty sure thats true... It gets new (semi synth) oil and a new
    filter[1] every 5,000km - the "book" say it only needs oil and filters
    at 10,000km. I'm convinced that the good oil and frequent changes
    contributes to its longevity. And even if it doesn't, all its costing me
    is maybe an extra $40 or so[2] per 10,000km, thats not exactly going to
    break the bank...
    I work this bike pretty hard - a trackday every couple of months, a
    2,000+km trip a few times a year, and an occasional long trip too[3], as
    well as commuting 80km a day and zooming around on it most weekends...
    Most people don't expect a 250cc bike to last 100,000km - I'm heading
    for 200,000km on this one...
    I should admit though, I killed the first motor at 120,000km by
    downshifting _way_ to early on the way into turn 9 at Eastern Creek a
    couple of years back - did the big ends, and replaced the whole motor
    with a 10,000km old one from the wreckers. The new motor has 70,000km on
    it now, and apart from the rattly cam chain (the first motor had the cam
    chain and tensioners replaced at 70,000km too), its still running strong.
    big
    [1] OK, I'll admit, it occasionally doesn't get a new filter if I don't
    happen to have one handy, but I make sure I never skip replacing the
    filter twice in a row, so it _always_ get a new filter at least every
    10,000.
    [2] I use $40 worth of oil and $16 worth of filterts per 10,000km, I
    _could_ use maybe $10 of oil and $8 of filters if I used "cheap" oil and
    only 1 filter change per 10,000 like the "book" says - pretty cheap
    piece of mind, even if it doesn't help ;-)
    [3] 6,300km Sydney to Lyndhurst and back about a year ago:
    http://www.mightymedia.com.au/~bigiain/bug_collecting/eclipse/
  12. OK, find me a Spada with 180,000km on it thats always used dinosaur oil
    big (yeah yeah, I'm cheating, make it a 120,000km Spada ;-)
  13. GB
    GB Guest
    OK. If you care to give pointers in that regard, my email
    address is a real one.
    I am... *yawn* :)
    Yup, Kath warned me off synthetic oils earlier today for much the
    same reason. Also cited potential for strange and non-desirable
    behaviour from wet clutches.
    The book says 10W-40, and that's it. Not a lot to go on there.
    It sounds like a reasonable claim to me. I don't know much about
    bikes, but i'm pretty familiar with most other things with
    injuns in them, and the same principle holds true elsewhere:
    overlubricate at run-in time is a Bad Thing (tm).
    G
    GB, Dec 29, 2003
  14. GB
    Biggus Guest
    Then if you have your mind made up, why bother asking?
    Biggus, Dec 29, 2003
  15. GB
    GB Guest
    You got that right! It's a principle thing. Sydney City Motorcycles
    at Lane Cove tried to screw me once, they got caught, and now they've
    lost me as a customer, in all contexts, for life. Simple really.
    G
    GB, Dec 29, 2003
  16. Oil is designed to lubricate for ever! Why change it?
    Hammo
    Hamish Alker-Jones, Dec 29, 2003
  17. On 29/12/03 8:38 PM, in article
    "I'm pretty sure that¹s true". Convincing argument. How do you know that
    the oil you are using is any better because it claims to be semi-synthetic?
    I'm more convinced that a bike that does lots of [constant] mileage will
    outlast one that does short stop start stuff. I'm convinced that
    contaminated oil is no better if it is synthetic, synth fortified, or
    mineral.
    If you are changing it it so frequently why not buy it buy the 44? I also
    have so snake oil for you try.....
    Hammo (hmm, must be optimax time too....)
  18. GB
    Johnnie5 Guest
    where is BTH when you need him ??
    go for a google and you will find that your bike will do 100K using cheap
    crap valvoline car oil
    no need for that fancy schmancy bike oil
  19. I use a shell semi-synthetic bike oil in the GPX engine (and
    co-incidentally, the same one in the ZX10 engine). Cost is about $30 for a
    4L? (From what my morning-fuzzed memory says.)
    Filter is $10, and I do it every 2nd change. (I change the oil every 5000km
    though.)
    Both from Motorcycle Accessories in Parra. (They are also in Sydney though.)
    I also always replace the drain bolt washer every second change these days
    (you only make that mistake once). Add another $1? Seeing as I use less than
    half the 4L in an oil change, it averages out at just over $20 per 5000km.
    If I was a cheapskate, and followed the service manual exactly, then I
    wouldn't ever replace the washer (service manual doesn't say to, what's up
    with that?) and would only do the oil and filter every 10,000km with the
    cheapest oil of the appropriate spec available. Would cost me about $15
    every 10000km. Seeing as the ZX10 is up to 130,000km, and still doesn't even
    need a new cam-chain yet (and based on the measurements, won't for another
    50000km odd) I'm pretty happy with the results.
    James Mayfield, Dec 29, 2003
  20. GB
    Theo Bekkers Guest
    "Hamish Alker-Jones" wrote
    I used commercially recycled oil in my first car.
    1949 Morris 8 van, and no, I didn't buy it new.
    Theo
    Theo Bekkers, Dec 29, 2003
