Oil Change
Discussion in 'Bay Area Bikers' started by JB, Feb 11, 2005.
  1. JB
    JB Guest
    Here's a Silly Simple Question (Which will no doubt cause a bar fight to
    break out)
    How often do you change your oil ... and why?
    Some context: my BMW R1100GS manual recommends oil changes every 6K
    miles ... I'm thinking that doing my own
    change every 3K (I mean, in between regular service) would be money well
    spent. ANy comments?
    JB, Feb 11, 2005
  2. Every 8,000 miles because that's when my Honda shop manual recommends it...
    You'll be the darling of the oil companies for sure...
    Larry L
    94 RC45 #2
    Have a wheelie NICE day...
    Lean & Mean it in every corner of your life...
    If it wasn't for us the fast lane would rust...
    V4'S are music to the seat of my pants...
    1952 De Havilland Chipmunk...
    Yank and bank your brains loose...
    http://members.ebay.com/aboutme/-xlax-/
    http://home.comcast.net/~netters2/
    http://www.fox302.com/index.pl?s=vg&user=netters2
    Larry xlax Lovisone, Feb 11, 2005
  3. Every 4K. Because that's what my mechanic recommends, and that's what I
    pay him for.
    FWIW, we discussed using synthetic oil the last time, (I had a similar
    discussion with my auto mechanic and concluded that it made sense for
    the car to pay twice as much for the oil change and need to change it
    1/3 as often) and determined that there really would be no savings.
    I'm a very hands-off person, but assuming that you are competent to
    change your oil and that doing this yourself would give you a better
    feel for your bike's condition, I'd suggest that you do it once. If the
    oil you're removing looks clean, there's probably not much if anything
    to be gained by making the changes more frequently. If it appears dirty
    or otherwise broken-down, you might want to tell your mechanic and make
    a practice of more frequent oil changes.
    YMMV
    Rich, Urban Biker
    Rich, Urban Biker, Feb 11, 2005
  4. JB
    muddycat Guest
    Roughly every 3K. I don't know why, I just do. Maybe I was inspired to
    pick this value by some urban myth.
    muddycat, Feb 11, 2005
  5. JB
    notbob Guest
    So much depends on both your bike and how you ride it that no
    pre-determined "factory recommendation" (FR) can really do your bike
    justice. At best, I'd say the FR is strictly a "Please, for God's
    sake..." kinda spec.
    First off, today's motorcycle engine is a much more highly stressed
    piece of machinery. Some of these suckers are putting out some
    insanely serious power. We all know the old adage, the faster it
    goes, the sooner it dies. Here's a little comparison chart I whipped
    up based on horsepower output per cubic inch displacement of older and
    newer car and bike engines. (250cc = 15cid (approx))
    motor disp stdhp/cid
    '84 Camaro Z28 305cid .5
    H-D 74 74cid .7
    Ford Mustang 5.0 5.0L 1.0
    '87 Honda Civic 1600cc 1.1
    Suzuki GSXR1000 1000cc 2.9
    Kawasaki KX125 125cc 4.5
    Obviously, the more highly stressed, the more wear and tear and more
    little bits and pieces of engine that are wearing and shaking
    themselves free to float around in the oil supply. This contamination
    is no good for your engine and the only way it can be removed is to
    change the oil. For decades, the gold standard was 1 stdhp per 1 cid.
    Anyone remember those mythical Chevy 425hp 396cid Malibu's? Well,
    motorcycles and the Japanese blew that away years ago. It doesn't
    take a rocket scientist to realize a KX125 is going to need more oil
    changes than an old Chevy V8. How about once every 45 mins!
    Besides the basic stresses your particular bike engine design may
    produce, there are other factors. How do you ride it? WFO all the
    time? Never sees redline? Track days? Short trips to the
    supermarket (produces corrosives)? Riding two-up up a long Sierra
    grade on a 100+ deg day? Don't forget those mods. Performance air
    filters? Performance exhaust? Opening up the breathing is opening up
    the motor to more abrasive crud, no matter the sales hype.
    All these factors have an impact on engine life. You need to take
    them into account in determining how often you change your oil. The
    more often you change your oil, the longer you bike engine will last.
    It's a simple undeniable fact. Oh sure, there's a point of
    diminishing returns, but in light of the possble abuses a rider can
    heap upon his ride beyond its inherent design, just doing the FR may
    actually be shortening the life of your bike.
    nb
    notbob, Feb 11, 2005
  6. JB
    JB Guest
    Good points. In fact, your line of reasoning is why I am considering
    changing my M/C oil as often
    as I change my car oil: more STPHP/CC, and I ride it a lot closer to
    the red line than I drive my car.
    JB, Feb 11, 2005
  7. JB
    notbob Guest
    I've had this discussion dozens of times. The bottom line is,
    synthetics is better for motorcycle engines. Why? It doesn't build
    up carbon deposits like regular carbon based oils. "Synthetic is much
    less prone to coking, and less prone to varnish than conventional
    oil".[1] IOW, those hard black carbon deposits that, over time,
    collect on combustion chambers, pistons crowns, and valve faces and
    create hot spots which contribute to pre-detonation (pinging), do not
    occur as readily or with such severity with syns. This is desirable
    in high compression motorcycle engines. If you are tearing down your
    bike every race or every season, this is not an issue. But, if you
    want to get some serious miles between rebuilds, syns are the better
    bet. BTW, buying syns in bulk or six-paks can save as much as $2 per
    qt.
    [1]http://www.allpar.com/eek/synthetic.html
    nb
  8. JB
    jacksf Guest
    On my 2 1982 bikes I change every 3k. On my '03 Connie every 4k.
    As an aside, does anyone else smell their used oil?
    jacksf, Feb 11, 2005
  9. JB
    JB Guest
    Ummmm. When it comes out right by my face into a pan it is hard not to
    catch a whiff ... I can usually tell the difference between 'burnt' and
    just 'used'. Why do you ask?
    JB, Feb 11, 2005
  10. 6000 miles on a R1100 for average use is fine if you use quality 20W50
    oil. if your bike spends a lot of time in low speed stop and go and
    average sub-10-mile trips, then 3000 miles might be appropriate.
    the r1100 engine holds like 4 quarts, thats a lot of oil for a small
    engine.
    John R Pierce, Feb 11, 2005
  11. uh, "synthetic" oil is still carbon based. in fact, its made from
    petroleum, same as regular motor oil, its just made differently.
  12. JB
    Mas Rapido! Guest
    When it looks icky, and I have the time to change it. This usually occurs
    around 3-5 thousand miles or so.
    Mobil 1 15-50 in all my children.
    Jim Stinnett
    VTR1000
    R1100RS
    YZF R1
    http://moto-rama.com
    Mas Rapido!, Feb 12, 2005
  13. JB
    jacksf Guest
    I just wondered if I was strange for doing it. Guess not. Reason I do
    it is to see if there is a odor that would be "abnormal" which could
    indicate there is something wrong...gas in the oil for instance. Just
    some smell that would be other than used oil smell.
    jacksf, Feb 12, 2005
  14. JB
    JB Guest
    So... can you smell the difference between oil which has been 'burnt' as
    opposed to just use? I pick up a bit of the same smell when
    electronics (wire insulation) over-heats.
    JB, Feb 12, 2005
  15. JB
    jacksf Guest
    I think what I would notice would be more like gas mixed in with the
    oil, maybe anti-freeze...its really hard to explain.
    Course it could be my smeller is gone thanks to my youth :)
    jacksf, Feb 13, 2005
  16. the 20W50 or 15W50 that I put in my BMW turns dark after a few 100
    miles... but it still 'feels' like good oil for many 1000s of miles. at
    around 6000 miles, I figure its due for a change as thats when the factory
    suggested. If I'm doing lots of short commute trips, I might change it
    at 3000 miles.
    John R Pierce, Feb 13, 2005
  17. JB
    Roger T. Guest
    As far as I know, the high grade synthetics are not made from petroleum, but
    from lab-produced chemicals.
    Roger T., Feb 14, 2005
  18. JB
    Guest Guest
    Once a year, whether it needs it or not, which turns out to be about 3k
    mi. I would go up to 7.5k, but not more than a year.
    BMW K75, Mobil Delvac 1 5w-40 synthetic fleet oil. Separate gear oil,
    dry clutch, water-cooled, and I ride almost every day. 6 mo is too soon.
    -tc
    Guest, Feb 17, 2005
  19. JB
    Guest Guest
    Smell it?!
    I rub it on my chest and grunt!
    -tc
    Guest, Feb 17, 2005
  20. JB
    JB Guest
    Ugh Ugh Ugh!
    JB, Feb 18, 2005
