Oi TOG, a word about XS650's
Discussion in 'Classic Motorbikes' started by 'Hog, Mar 9, 2006.
  1. 'Hog
    'Hog Guest
    When a cam end oilseal on an XS650 starts leaking, look closely.
    I had the old one out today having been supplied with a superior double lip
    item by the local Bearing Factor. I had a few choice words about you when I
    saw the state of the old one:
    "JHC I know he's not a pro mechanic but WTF did he put this seal in with, a
    lump hammer?"
    Having a suspicious mind I started to look more closely, I suspect *even
    you* couldn't be that ham fisted ;o)
    Yup, the cam end ball bearing is well and truly Kerry Packered, 2mm vertical
    play in the race. Easy job thinks me, split the head, new bearing, might not
    even have to break the cam chain, SHIT **** PISS **** SHIT
    OK XS650 experts, do you have to take the engine right out of the frame to
    remove the cylinder head??
    Yes the crash bars were a **** to remove. Yes the exhaust is also a ****, no
    chance of the link pipe separating without breaking. If the dreaded answer
    is YES then I suppose I'm doing the chrome and frame paint reconditioning a
    year early.
    I had a nice new rear Bridgestone fitted this morning ready for the weekend
    run to Dublin.....
    I suppose I need to find a complete fucking gasket set somewhere now too.
    'Hog, Mar 9, 2006
  2. 'Hog
    Ken Guest
    Dont think any of the "classic" bike fans on here should be termed as
    "experts".......... unless you were asking about buying overpriced
    shitters from Ebay of course..............lol
    k
    Ken, Mar 10, 2006
  3. Erk. Mine dew, for a bike with a nadgered head bearing, it was running
    remarkably quietly.
    Yes, you do. It's actually a simple job. The camchain is secured by a
    soft link, which makes head removal nice and easy.
    On the positive side, you should have the new silencers by now - I send
    them over with Richard because he's attending his Grandma's funeral.
    They're easily available. But you shouldn't need one because you're not
    removing the head, are you? Just the cam cover. The bearings - there are
    four- two perside - simply slide easily onto the cam.
    I suppose the box of bits I posted has never shown up either? I'll send
    a cheque back to you. Fukkit. The one time I send a parcel by ordinary
    uninsured post and it goes AWOL.
    The Older Gentleman, Mar 10, 2006
  4. Oh, and the new rear brake shoes are stuffed inside one of the boxes.
  5. 'Hog
    The Older Gentleman said...
    I've never had to break a camchain yet to remove the head. Surely you
    just unbolt the cam sprocket from the cam and out it comes leaving the
    head clear for removal. Cable-tie the sprocket and the chain before you
    start to ensure it's properly timed up on reassembly and away you go.
    Lozzo, Mar 10, 2006
  6. 'Hog
    TOG Guest
    Camshaft sprocket is integral with the cam on the XS650, so this won't
    work.
    That said, I'm sure there's enough clearance to remove the nearings if
    you just slacken off the tensioner. That'll allow the cam some play and
    you can just pull the bearings off the ends of the cam. You certainly
    don't need to remove the head.
    TOG, Mar 10, 2006
  7. 'Hog
    'Hog Guest
    Is there no base gasket though? bound to be disturbed when the head
    studs are loosened?
    The rocker covers could do with new o-rings and I see there are o-rings
    on the studs too
    'Hog, Mar 10, 2006
  8. 'Hog
    TOG Guest
    The head and base gaskets tend to form quite a tight seal to barrel and
    cases and shouldn't leak unless you actually disturb them. They've been
    there for 25 years, after all.
    There are rubber washers on the studs, yes, IIRC. And I'd replace
    these. If you're careful when removing the cam cover, you shouldn't
    need to replace head and base gaskets. If you want to be 100% sure then
    yes, go ahead. As it's only a parallel twin it's a piece of piss to do.
    Has Richard called you re the silencers? I think the funeral is today,
    so he's prolly got other things on his mind.
    TOG, Mar 10, 2006
  9. 'Hog
    Ken Guest
    There is no need whatsoever to split the chain to remove the head on
    one of these motors! Just another example of someone who hasnt a clue
    as to what he is doing, posting nonsense that really should be ignored!
    k
    Ken, Mar 10, 2006
  10. 'Hog
    TOG Guest
    I'm 99% sure you can remove the cam bearings without splitting the
    chain. The last three XS650s I worked on, I was reboring them so I had
    to remove the head anyway, and I was also replacing the camchain.
    Once you've got the cam bearings off, there will be enough clearance to
    allow you to wiggle the cam out.
    If you want to replace the camchain, like I said, it's a soft link
    jobbie and you simply attach the new chain to the old and roll it on.
    It's a piece of piss.
    In addition to the main cylinder head bolts, there are some others that
    hold the head to the barrels (three, IIRC) and these don't need to be
    disturbed unless you want to remove the barrels. Thus you should be OK
    in not having to change head and base gaskets.
    TOG, Mar 10, 2006
  11. 'Hog
    Ken Guest
    When will you lot finally realise the obvious fact that TOG dont know
    WTF he is talking about......................lol
    k
    Ken, Mar 10, 2006
  12. 'Hog
    Ken Guest
    This job is made a lot easier if you remove engine mounting bolts which
    allow the engine to sit a little lower in the chassis, which makes it
    far easier to remove and replace the rocker cover. The advice from TOG
    concerning needing to spilt the cam chain is complete bollocks and
    should be ignored!
    k
    Ken, Mar 10, 2006
  13. 'Hog
    TOG Guest
    Champ wrote:
    They are. The XS runs its camshaft in four separate ball races, two per
    end. Like I say, the ball races can be removed with chain in situ.
    <Googles>
    Yup, I'm absolutely right and what I posted earlier was accurate too
    http://www.bikerworld.co.uk/tech/XS650engine/stripdown/index.html
    and
    http://www.bikerworld.co.uk/tech/XS650engine/stripdown/page3.html
    TOG, Mar 10, 2006
  14. 'Hog
    TOG Guest
    It depends - if the oil leak was really bad before I got it (the
    previous owner had sealed the points housing/cover joint with gunge to
    disguise it, then who knows how long it had been running with not
    enough lube getting to the bearings? I didn't check the bearing because
    I know the seals have a reputation for failing and so I just bunged a
    new one in. But obviously, if the end of the cam is wobbling in the
    bearing, it'll destroy a new seal fairly quickly.
    Fair comment.
    TOG, Mar 10, 2006
  15. re-arrnange the following words into a well-known phrase or saying:
    "smartarse, a, loves, nobody"
    Austin Shackles, Mar 10, 2006
  16. 'Hog
    TOG Guest
    Austin Shackles wrote:
    "Everyone thinks Ken's a twat?"
    TOG, Mar 10, 2006
  17. 'Hog
    Ken Guest
    Maybe the person who posts utter bollocks in response to a pretty
    reasonable question from the OP of this thread, is rather more of a
    twat than I.........................lol
    k
    Ken, Mar 10, 2006
  18. 'Hog
    Buzby Guest
    You're getting very tedious.
    Buzby, Mar 10, 2006
  19. 'Hog
    ® 619 ® Guest
    your using far too many letters there.
    ® 619 ®, Mar 10, 2006
  20. 'Hog
    Ken Guest
    Interesting and slightly amusing that TOG who sets himself up as some
    sort of authority (lol), has so little knowledge about bikes he thinks
    you need to split the cam chain to remove the cam from an XS650!
    Seems to me there are a few knowledgable posters on here, but they have
    to play secong fiddle to pricks like TOG and Wegg, who seemingly know
    only how to sign cheques in payment for others working on their dubious
    collection of "classic" bikes.........................lol
    k
    Ken, Mar 10, 2006
