Ohlins and Brembo Update...
Discussion in 'Bay Area Bikers' started by Larry xlax Lovisone, Apr 3, 2005.
  1. Pretty cool idea.
    Yep... not to mention it lowers the parts count which is the paramount reason
    for the single disc idea...
    Larry L
    94 RC45 #2
    Have a wheelie NICE day...
    Lean & Mean it in every corner of your life...
    If it wasn't for us the fast lane would rust...
    V4'S are music to the seat of my pants...
    1952 De Havilland Chipmunk...
    Yank and bank your brains loose...
    http://members.ebay.com/aboutme/-xlax-/
    http://home.comcast.net/~netters2/
    http://www.fox302.com/index.pl?s=vg&user=netters2
    Larry xlax Lovisone, Apr 4, 2005
  2. Larry xlax Lovisone
    Rob Guest
    A Google search for "aluminum axle" +motorcycle turns up 201 results but
    most of those are for aluminum axle spacers. I could only find one
    reference in the first 50 or so results that actually mention using an
    aluminum axle on a motorcycle. I can see using an oversized tubular piece
    of aluminum for an axle, but not a same size as steel replacement. If you
    have any links to specific information about this, I would like to read it.
    I was just thinking off the top of my head in the previous post, I'm not a
    metallurgist nor do I have much experience with aluminum except in bicycle
    parts and frames. I did find some links to oversize aluminum axles on
    bicycles. I will try to do some more research.
    Rob
    Rob, Apr 4, 2005
  3. Larry xlax Lovisone
    Andy Burnett Guest
    To the rim itself.
    The application I was thinking of was a motorcycle brake. What application
    are you thinking of?
    ab
    Andy Burnett, Apr 4, 2005
  4. Larry xlax Lovisone
    Phil Scott Guest
    stock...
    Thats getting to be one of the worlds sweetest motorcycles...a
    hand built special, now you need a CF fairing. does CF
    require extensive equipment.. it would be neat if you could
    make it yourself using the originals to create the molds.
    Phil Scott
    Phil Scott, Apr 4, 2005
  5. Larry xlax Lovisone
    Jason Guest
    Hey, free is a hell of a price. I like free. How come nobody told me about
    the open house? And I'm calling YOU an old timer. I'm always going to be a
    good 20+ years younger than you! In all seriousness, I don't mind growing
    old chronologically. I just don't want to get old upstairs and turn into a
    grumpy old bastard like some of the walking dead I see in the office every
    day. Only 22 years until I am eligible for my pension!
    Jason W
    Jason, Apr 4, 2005
  6. Larry xlax Lovisone
    Phil Scott Guest
    Fortal is not yer ordinary aluminumiumum.
  7. Larry xlax Lovisone
    Phil Scott Guest
    Larry is a good example of how the elderly can ride, even
    if very slowly.
    I myself still ride but I need a walker and a step stool to
    get a leg over the flat tracker, thankfully it has electric
    start.
    Senility avoidance is an exciting study.. by the time you
    need a solution there will be one. Sport riding will also
    stave off disaster and keep you sharp of wit until then.... as
    will learning about digestive enzymes... its the partial
    protiens leaking from the gut to the blood stream... from
    processed food .... that create an overload of plaques that
    pervade the nervous system and brain, inside the cells and
    out....stiflin' yer brain function, crimpin the neurons so
    they die... and that also cuts nerve flow to organs by
    mechanical choking off axons and microcapillary blood and
    lymph vessels...... thus that near dead look at the office you
    refer to.
    If alzheimers or various dementia is in your family, you need
    to pay attention...if its not at all in your family you
    probably will not have the problem before there is routine
    prevention available (5 to 10 years...our govt may want to
    put this development off until 50 million or so baby boomers
    die off, no way in hell can we afford the social security if
    these all live to 95).
    Phil Scott. age 98 worlds oldest flat tracker.
  8. .. If you
    Aircraft have been using aluminum axles since WW2... and they typically weight a
    lot more than a motorcycle and get slammed hard on the runway when the pilot
    goofs and falls out of the sky...
    http://www.groveaircraft.com/axles.html
    I'd only make a hollow titanium axles for use on a bicycle...
    Larry L
    94 RC45 #2
  9. I thought you joined DFR??? that's where I leanred about it...
    Not ME... I don't hold my farts in... old people do... and it's dangerous
    because farts travel up your spine and enter your brain and that's where shitty
    ideas come from... just look at old Phil... I don't think he's farted in the
    pass ten years...
    Larry L
    94 RC45 #2
  10. Larry xlax Lovisone
    Phil Scott Guest
  11. Larry xlax Lovisone
    Phil Scott Guest
    When you are flat tracking at age 98 then you can go on about
    old farts..... in the meantime... if you take yer enzymes you
    don't have the problem.. you just keep getting smarter and
    better looking.
    Phil Scott
  12. Larry xlax Lovisone
    notbob Guest
    I figured as much. It's not like the bearing surfaces are directly on
    the aluminum shaft, although Honda is quite familiar with the concept.
    nb
    notbob, Apr 4, 2005
  13. Larry xlax Lovisone
    hacktastic Guest
    Larry,
    That's just pure, unfettered alloy pr0n.
    -Beth
    hacktastic, Apr 4, 2005
  14. Larry xlax Lovisone
    Ari Rankum Guest
    Try leaving off +motorcycle. My search turned up two extensive
    motorcycle racing sites on the first page of results.
    Ari Rankum, Apr 4, 2005
  15. Marchesini magnesium tried rim brakes back in the 80's... but they failed to
    find favor with the racers... large diameter dics were deemed too heavy and ran
    too hot buried behind the wheel and so they longer make them... but you can
    still find them on Ebay... perfect for a Buell though...
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=89463&item=4540753145&rd=1
    Larry L
    94 RC45 #2
  16. Larry xlax Lovisone wrote:
    Godammit, Larry, you didn't make enough for *everyone*?!?!?!
    Very nice. I've been debating where to go with forks, and have
    decided on the interim Shohlins approach -- add Ohlins internals
    to the Showa fork, along with the Brembo radial caliper kit.
    I notice you use the cast, rather than billet, calipers -- I
    couldn't see spending thousands instead of hundreds, for
    what is the same performance, essentially. BrakeTech ductile
    iron rotors? Very nice. You use organic pads?
    Michael Sierchio, Apr 4, 2005
  17. Larry xlax Lovisone
    notbob Guest
    Hadn't seen one of those. Nifty!
    nb
    notbob, Apr 4, 2005
  18. Thanks Steve...Your compliment means a lot to me because you have first hand
    experience and know what you go through to make a part solely by hand eye
    coordination... I can't cry about it because I use to make parts by Jig Saw...
    Band Saw... Drill Press and hand files... like these rear sets...
    http://www.fox302.com/userdata/netters2/files/ShopPics/Belt_O_Ceptor.JPG
    Oh I wish...
    Larry L
    94 RC45 #2
  19. You should be on build or bust instead of these muldoons they keep kicking
    off the show.
    I want to see a harris framed V4 with all kinds of trick bits. I doubt the
    guy from exile cycles would go for it though.
    entropy_magnet, Apr 4, 2005
  20. That's always a problem around here...
    .. BrakeTech ductile
    Yes.. they are Brake Tech's 6 button superlites ductile iron rotors... and No...
    I'm using the stock Brembo copper backed sinistered pads that came with the
    calipers...
    Larry L
    94 RC45 #2
