Oh happy day
Discussion in 'UK Motorcycles' started by Pip Luscher, Aug 5, 2007.
  1. Pip Luscher
    My Guzzi gearbox problem turned out to be a loose linkage. Tokk
    slightly longer to fix that expected: I had to unbolt the starter
    motor to get at the screw.
    Next job: the bike's steering had been getting a bit... odd, and it
    dawned on me that I've no recollection of ever greasing that
    particular bike's head bearings. Whoops. Got the steering apart and
    they were indeed dry and the bottom rollers were beginning to corrode.
    I just caught it in time. All well now.
    It's funny how these jobs seem to come in batches: I've only recently
    done the R1 because I needed to adjust the bearings; as this entails
    taking the top yoke off I figured it would be daft not to grease them
    at the same time.
    And Off Topic: I'd managed to crash both my model helicopters last
    week. The indoor Sabre had lost a rotor-head bearing when I crashed it
    in the garden: it suddenly spun 180 degrees and rolled and I got
    disorientated. The other, an Eco-8, suffered a bent tailboom because I
    was trying to teach myself to hover it nose-in and let it drift too
    close to the shed. I fixed both today. I might start using a tether
    and anchor plate while I get the nose-in hover sorted.
  2. Pip Luscher
    Well, doing it on simpler shite old bikes in one's yoof gives one the
    experience and the confidence, though any experienced mechanic would
    do the jobs in a third of the time it takes me to do them. I resorted
    to the HBoL for the exact procedure for the R1, in case there were any
    surprises, it being a new toy and all.
    As for the Guzzi, I just put a jack under the engine and undid stuff.
    Only problem was the fact that after removing the top yoke and
    adjuster ring, the steering stem steadfastly refused to drop out of
    the top bearing. My puller just slipped off, so after making sure I
    hadn't missed anything I resorted to placing a short bit of mild steel
    bar on the end of the stem and hitting it with a hammer. Sorted.
  3. Pip Luscher
    Roger Hunt Guest
    Des wrote
    It takes several instances of dropping all the bearings on a gritty
    floor, while rushing a job before the light goes, and then having a
    forkless bike fall off its stand just as everything has been found, and
    having to start all over again.
    Roger Hunt, Aug 5, 2007
  4. Pip Luscher
    deadmail Guest
    I think it's a consequence for many of us of having had bikes as a sole
    means of transport when money was too tight to afford garages.
    Haynes manuals (or similar) are your friend if you want to do this
    stuff.
    It's fiddly on the K fair enough but it shouldn't take more than 10
    minutes once you've worked out how the bulb is secured.
    deadmail, Aug 5, 2007
  5. Pip Luscher
    ....and pretty shit bikes at that.
    Oh, how things change with age, money and experience.
    sweller, Aug 5, 2007
  6. Pip Luscher
    Kinell. <mops brow>
    platypus, Aug 5, 2007
  7. Pip Luscher
    If it helps, I did bung the bar into the lathe and face off the end
    that bore against the stem.
    It just needed... persuading.
    Mwahahahah!
  8. Pip Luscher
    Talking of which, when I was checking the Guzzi's clutch cable out on
    the drive, I heard the unwelcome 'clunk' of something falling onto the
    gravel.
    Couldn't immediately see them, so I waved a magnetic parts tray over
    the ground and as if by magic, 'kerlunk' as the bits attached
    themselves to the bottom of the tray.
  9. Pip Luscher
    Roger Hunt Guest
    Pip Luscher wrote
    Nice one. Old hard drive magnets are useful too, for that.
  10. Pip Luscher
    Beav Guest
    If you do, you'll be buying more parts. Believe me, tethering ISN'T the way
    to go. Think "inverted pendulum" with extra bits.
    What you need is a bloody good simulator. RealFlight G3 or Phoenix.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 6, 2007
  11. Pip Luscher
    I get what you're saying, but it actually works OK. Been doing it for
    years. This kind of indicates my progress!
    Trouble is, they are rather expensive. I could buy quite a few tail
    booms for the price of a simulator. Instead, I've got 'RC stunt
    copter' for my old Playstation. Not a true simulator but has helped a
    bit. I switch to 'fixed camera' view and fly the heli around in free
    flight stunt mode.
    Pip Luscher, Aug 6, 2007
  12. Pip Luscher
    Beav Guest
    And the efficiency of the method. Get the heli in the air, turn it round and
    fly the fucking thing. It only takes a few minutes anyway before nose-in
    flying becomes 2nd nature.
    "Penny wise pound foolish" sound familiar?
    For 100 quid you get a great sim and as many crashes as you could ever
    handle. It's not just the cost of replacing a tail boom, it's the time it
    takes plus the necessity to set the heli up again properly (if it was ever
    done in the first place)
    Not as much as you think. You may THINK it's helped a lot, but after flying
    every sim on the market (including RC **** copter) plus having had an RC
    heli school for 15 years, take it from me, **** copter does **** all but
    throw up wrong muscle memories.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 6, 2007
  13. Pip Luscher
    Yeah, lack of practice. The last garden was too small really and I
    couldn't be arsed to lug it all out to a flying site. Then the heli
    lost lift and got consigned to a cupboard. It's only the recent
    purchase of an indoor flyer that rekindled my interest and I finally
    got round to sorting the problem.
    It's my life motto.
  14. Pip Luscher
    Beav Guest
    I've got a lovely Robbe Futura with a YS 90 going begging.
    Snap :)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 6, 2007
  15. Pip Luscher
    Hum. I did consider IC but I'll prolly stick to electric for now. I'm
    also a little short of spare cash ATM.
  16. Pip Luscher
    Speaking of which, I'd best mail you.
    Done.
    Pip, Aug 7, 2007
  17. Pip Luscher
    And bounced.
    De-mung it for me please, Pip - my addy in my headers works.
    Pip, Aug 7, 2007
  18. Pip Luscher
    Beav Guest
    I've dabbled in leccies over the years, but they don't really "do it" for me
    like the methanol heli's do. I like the smoke, the stink, the grief and the
    NOISE of glo engined heli's.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 7, 2007
  19. Pip Luscher
    I love strokers and especially the smell of methanol/castor oil in the
    morning. But electric models can be flown in the garden and my
    'private flying site' has a house and horses nearby, though to be fair
    they don't seem to be bothered by an Allen scythe.
    Pip Luscher, Aug 7, 2007
  20. Pip Luscher
    Ahem. There was a cunning security typo in my user profile in Agent;
    now fixed.
