Oh feck - entitlement expires
Discussion in 'UK Motorcycles' started by The Older Gentleman, Jun 8, 2005.
  1. Just had a letter from the DVLA. Truck entitlement expires on 24 July
    unless I renew my medical.
    WC, the eyesight test you did in TW: is it the old-fashioned
    read-the-chart thing still, or have they got the new random image
    generator kit?
    I can wing the one but not the other.....
  2. In uk.rec.motorcycles, The Older Gentleman amazed us all with this pearl
    of wisdom:
    You're bloody lucky I saw this post[1]. There I was, trying to get some
    shuteye and it just seems sick to go to bed when the sun's still shining
    even though I have to be up at the crack of dawn (fnarrr).
    OK. When I did the eyetest in TW, it was the standard "stand a certain
    distance from the chart with an eyepatch" job.
    [1] Realises the irony in this statement.
    Whinging Courier, Jun 8, 2005
  3. The Older Gentleman
    Ginge Guest
    I'm pissed off, I can no longer do the bottom line with my left eye,
    wearing glasses.
    But I think it's mostly a symptom of a lazy eye.
    Ginge, Jun 8, 2005
  4. The Older Gentleman
    Did I mention that my eyes have mysteriously improved since I last had
    a test? Seems that neither of them is short-sighted any more, so I've
    binned the specs and replaced the Rx lenses in my Oakleys with the
    pristine originals. Which is nice.
    Still got a bit of astygmatism, though, which made the bottom line a
    bit fuzzy with one eye, but was fine with them both together.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jun 8, 2005
  5. The Older Gentleman
    Ginge Guest
    That happens to me every 5 or so years.. with luck I'll not need glasses
    as I hit 50.
    Astigmatism is a PITA.
    Ginge, Jun 8, 2005
  6. Brilliant. I've still got his chart memorised, so it should be a piece
    of piss.
  7. The Older Gentleman
    Old age and presbyopia. You'll be reading the newspaper at arm's length.
    platypus, Jun 8, 2005
  8. The Older Gentleman
    frag Guest
    The Older Gentleman scribbled:
    Don't they have about 4 or 5 charts, all different?
    frag, Jun 8, 2005
  9. In uk.rec.motorcycles, The Older Gentleman amazed us all with this pearl
    of wisdom:
    Heh
  10. More than that. I had the first three or four lines of all of them
    memorised last time (I thought), and then this doctor had one I'd never
    seen before.
    Had to have a shufti when I thought he wasn't looking and do some quick
    memorising.
    AOEHLANTCO
    I doubt he's changed it since.
    The Older Gentleman, Jun 9, 2005
  11. The Older Gentleman
    mines only .75 in one eye, .25 in the other, so not really noticeable
    in most situations. Not changed for about ten years either.
    _______
    Ace, Jun 9, 2005
  12. The Older Gentleman
    Well yes, close vision becomes more of an issue as one ages, but isn't
    that usually a result of muscle function, rather than a change in
    eyeball shape such as would be required for the correction that's
    occurred?
    _______
    Ace, Jun 9, 2005
  13. The Older Gentleman
    tallbloke Guest
    I hope you've got all the road junctions I use memorised too.
    tallbloke, Jun 9, 2005
  14. The Older Gentleman
    flash Guest
    Will you be memorising all the roads and traffic before you set off in you
    truck?
    flash, Jun 9, 2005
  15. AKA "short arm disease".
    Phil
    Phil Launchbury, Jun 9, 2005
