Oh bugger.
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Jun 5, 2005.
  1. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    Well, these fuckers are.
    I really hope so. The good news (there's good news?) is that that nice
    Ginger Gentleman had made noises about patching the exhaust before it
    rots through. I declined on the principle that I didn't want to remove
    the exhaust. So now he gets his Big Chance! Woo-hoo!
    Good. It was you and that **** Hog that talked me into this. I blame the
    pair of you.
    and Ducati Race Engineer.
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Gyp
    <adds another name to The List>
  3. Wicked Uncle Nigel
    Salad Dodger Guest
    Oh, dear. I feel your pain.
    | ___ Salad Dodger
    |_\_____/_| ..75805../..18781.../..3196./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 24 Pts: 400 Miles: 1589
    Salad Dodger, Jun 5, 2005
  4. Wicked Uncle Nigel
    TMack Guest
    Aaahh, that brings back memories. About 35 years ago I spent a couple of
    hours holding a BSA Bantam engine upside down and shaking it to try to get a
    washer out of it that had dropped in. Having spent a couple of days very
    carefully stripping and rebuilding it I was damned if I was going to tear it
    apart again. I finally succeeded but my arms ached for a day or two
    afterwards. Wouldn't fancy trying it with a Z1300 but perhaps you could
    hold an engine-shaking party. With, say, 6 people it would only be about
    70lbs each.................
    Tony
    TMack, Jun 6, 2005
  5. Wicked Uncle Nigel
    TMack Guest
    Just a thought - do you know anyone who has access to a fibre optic camera?
    It might help locate the thing if it is lodged inside instead of at the
    bottom of the sump. If you are VERY lucky then, you might be able to hoick
    it out with one of those flexible claw-ended thingies.
    Tony
    TMack, Jun 6, 2005
  6. Any room to get a four pronged grabby flexy tool down there? If you can
    peer down the camchain tunnel and see it, you stand a good chance of
    getting it.
    Grimly Curmudgeon, Jun 6, 2005
  7. Wicked Uncle Nigel
    Oh, cheer up, you miserable bugger. If you look at the pictures here:
    http://tech.zn1300.com/z1300-deep-sump-pan-comparison.html
    you'll see that the sump pan can be unbolted, although you'll have to remove
    the exhaust first. Drop the oil through a sieve first, mind - the little
    bugger might just come out on its own.
    platypus, Jun 6, 2005
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    MWAAAAAH! MWAAAAAAAAAAH! MWAAAAAAAAAAH! MWAAAAAAAAAAH! MWAAAAAAAAAAH!
    MWAAAAAAAAAAH!
    I love you, little monotreme,
    I love you full and well,
    I love your little turned up beak,
    I love your special smell.
    I want to kiss you, monotreme,
    I want to kiss your face,
    I want to plant a smacking snog,
    On your most secret place.
    You are a very, very, very nice man; I don't care what everyone else
    says.
    It's 29mm diameter. It's still in there, trust me.
    Wicked Uncle Nigel, Jun 6, 2005
  9. Wicked Uncle Nigel
    Wicked Uncle Nigel says...
    That's not a shim, that's a fucking manhole cover.
    Lozzo, Jun 6, 2005
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    I wish it was. Then it wouldn't have fallen through the
    29.000000000000000000000000000000000000001mm gap in the
    cloff-wot-blocked-the-camchain-tunnel.
  11. Wicked Uncle Nigel
    29mm? KHI and no mistake.
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    If it's not attached to the Dnepr, it's not a big enough chair.
    Indeed. I was a little surprised myself. The cam acts directly on the
    shim, so I guess it has to be a reasonable size.
  13. Wicked Uncle Nigel
    muddycat Guest
    That shit fell of my SV somehow.
    Mike
    SV650
    UKRMMA#22
    Skype: muddycat
    muddycat, Jun 6, 2005
  14. Drain the oil first. That might bring it out - if it's big enough to get
    through the drain hole. Then take the sump off. Then, if it's not in
    there (it probably is). just ride the bike.
    I mean, the chances are the shim's lodged somewhere where it can't do
    any harm. If it does escape and cause carnage in the engin, it's
    probably less carnage than you'd cause trying to strip the lump down.
    The Older Gentleman, Jun 6, 2005
  15. Wicked Uncle Nigel
    'Hog Guest
    You silly silly silly sod. I refuse to feel even the slightest twinge of
    a guilt trip.....
    My solution would deffo involve a flexi dentist mirror and flexible
    retractable claw. Failing that a little fibre endoscope. I might do this
    before messing about with the sump and encouraging the blighter to bed
    deeper. A good engineering come non destructive testing shop should have
    one, quite common now for bore examination, you can probably hire the
    things.
    'Hog
    'Hog, Jun 6, 2005
  16. Wicked Uncle Nigel
    <intrigued>
    Did you make this all up? I assumed you'd adapted an existing pome,
    but I can't find any trace on the web.
    Champ, Jun 6, 2005
  17. Wicked Uncle Nigel
    Ho hum. It *looked* like it would go. You never know until you try,
    tho.
    Champ, Jun 6, 2005
  18. The Older Gentleman wrote
    Or a bindit with me piloting and my clone as pillion.
    steve auvache, Jun 6, 2005
  19. Wicked Uncle Nigel wrote
    <snigger>
  20. 'Hog wrote
    I have a pair of long handled locking Arterial Forceps wot I sometimes
    use as a lightweight mole grip or to pick up stuff that has fallen to a
    difficult place. Dead handy locking Arterial Forceps are.
