Oh bugger.
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Jun 5, 2005.
  1. Hog's derision has shamed me into hoiking the cam cover off the
    BlingMobile and waving feeler gauges at what was revealed[1].
    #4 and #6 inlet valves are completely (as in < 0.0015") closed up
    (should be 0.002 - 0.006").
    So now I have to make a special tool to get the existing shims out, then
    go shim and gasket shopping tomorrow.
    Then I have to worry about *why* they've closed up.
    I knew I should have paid some twat to do this for me.
    [1] BTW Champ, the Californian emissions crap did have to come off to
    get the cover out.
    and Ducati Race Engineer.
  2. It's a piece of piss to do the shims on that.
    Shim tool.
    http://www.mandp.co.uk/productInfo.aspx?catRef=500599
    Or you could grind something up.
    eric the brave, Jun 5, 2005
  3. Wicked Uncle Nigel
    Simes Guest
    Wicked said:
    Hah... Can you sleep well thinking about all the valve seat regression?
    Worth taking the head off while it's in so many bits - what's the
    compression like?
    Californian? Means it's been running lean as a lean thing and there's
    probably a good bit of valve overheating and burning to think about...
    Simes, Jun 5, 2005
  4. Wicked Uncle Nigel
    Give them a little extra clearance from standard and check them in
    another 1000 miles after they've settled back down... or not.. as the
    case may be.
    Muck, Jun 5, 2005
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, Simes
    Fuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckf
    uckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfuckfu
    ckfuckfuckfuckfuckfuckfuckfuck. ****.
    I had the camchain tunnel blocked. Nearly well enough to stop the
    fucking cunting fucking bastard fucking cunting shim falling into it.
    The non-magnetic fucking cunting fucking bastard fucking cunting shim.
    I feel physically sick.
    It would appear I am about to learn how to remove an engine from a
    Z1300.
    Now please do excuse me, I'm going to cry.
  6. Wicked Uncle Nigel
    SP Guest
    <Backs away very slowly from the very angry animal whilst maintaining
    eye contact>
    <phew>
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Jun 5, 2005
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, SP
    Angry? Angry? I am so pissed off at myself that for a few seconds after
    it happened turning the bike upside down and shaking it would have been
    a feasible solution.
    Unfortunately, that passed.
    I will now investigate the possibilities of dropping the sump with the
    engine in the bike.
    I bet it won't. I just bet.
  8. Wicked Uncle Nigel
    Simes Guest
    Wicked said:
    Using rags to block off things 101 - OU course for beginners.
    Bad one. Non-magnetic? Are you sure you're sure?
    Torch, mirror on a stick and a bit of luck...
    Otherwise an oil drain and inspect waste oil hoping it's come out
    bringing the shim with it...
    You big girl - it's things like this that are sent to test the stiff
    upper lip...
    Simes, Jun 5, 2005
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Simes
    Don't make me come over there and kill you. Just don't, OK? There was
    one small, unnoticed gap. The **** homed in on it like an Exocet.
    Yep. Checked and double checked with another one of the wily little
    fuckers.
    Nope. Can't see it at all. And it's big enough not to miss (see below).
    Unlikely. These are hairy-chested man-sized shims, 29mm in diameter.
    <bottom lip starts wobbling again>
  10. Wicked Uncle Nigel
    I had to drop the sump off my Bandit to look for a little bit of metal,
    had to remove the exhaust too. In the end, I found the offending bit of
    metal behind an inlet valve spring. :)
    Muck, Jun 5, 2005
  11. One useless statistic I remember is that a Z1300 engine weighs about
    340lbs, or the same as a Suzuki X7.
    The Older Gentleman, Jun 5, 2005
  12. Is there a way of getting one of those really sticky sort of Sellotape
    squares on the end of a stick[1], poking it down, and hoping you can
    catch the thing on the sticky bit?
    [1] Obviously you want to make sure the sticky thing is well attached to
    its stick unless you want to start a collection of foreign objects
    inside the engine.
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    <clutches groin>
    *Whimper*...
  14. Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    Maybe worth a try. I think there's enough oil kicking around to make
    that a non-starter. But worth a try.
  15. Wicked Uncle Nigel
    Simes Guest
    Wicked said:
    Small - but larger than 29mm... Has sir been to
    http://tinyurl.com/ccwww lately?
    They do that to taunt you...
    Looking on the bright side, you can spend the long summer evenings
    enjoying the inside of your engine. Perfect time for that expensive
    rebuild...
    Snap out of it man.
    Best bet is to knock a hole in the sump with a hammer, fish out the
    shim then fix the hole with some form of magic.
    Simes, Jun 5, 2005
  16. Wicked Uncle Nigel
    SP Guest
    What about one of those grabber things that open up when you press the
    top? Dunno what they're called, I've had one in my toolbox for years.
    Ever since a 'helpful soul' managed to drop a screw inside my engine.
    Lesley
    CBR600FW
    BONY#54P BOB#18
    SP, Jun 5, 2005
  17. Wicked Uncle Nigel
    That's 8kg heavier than my FZR.
    Muck, Jun 5, 2005
  18. Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear
    He said it wouldn't.
  19. Wicked Uncle Nigel
    Lady Nina Guest
    Amazing visual conjured up there.
    It might.
    Lady Nina, Jun 5, 2005
  20. Wicked Uncle Nigel
    Gyp Guest
    Don't rule that out; surely the lower frame rails would take the weight.
    Anyway, I'm surprised it doesn't have hydraulic adjusters like proper
    American motorcycles to avoid all this fannying about.
    Gyp, Jun 5, 2005
