Oh, bother.
Discussion in 'UK Motorcycles' started by SD, Feb 12, 2008.
  1. SD
    I'd thought it was some sort of management-speak overrun.
    platypus, Feb 13, 2008
  2. SD
    SaladDodger Guest
    It did. A bit reluctantly, but then, it hadn't moved since July.
    I'd forgotten quite how rubbish the brakes were, too.
    SaladDodger, Feb 13, 2008
  3. SD
    Never going to be that simple though, is it?
    One hose gone will inevitably be an indicator of others on the way,
    then during dismantling Dodger will discover that the clutch
    hydraulics are linked to the power steering pump and the air
    conditioning, requiring at least 220 lines to explain the intricacies
    of dissasembly and why he's once again managed to lay his bike across
    three acres of prime Docklands real estate in a thin layer of assorted
    componentry.
    Probably.
    Pip, Feb 13, 2008
  4. SD
    SaladDodger Guest
    ;-p',',',',',', to you, matey.
  5. SD
    I walk (at least) 50-60 minutes per day - that's got to be healthy,
    right?
    In the "town" area where I live within Greater London, it'd be a rare
    day that I didn't walk to where I needed to be.
    darsy, Feb 13, 2008
  6. SD
    Steve Parry Guest
    http://shop.wemoto.com/index.dyn?oid=5834019
    Shows clutch hose as £29.50
    Steve Parry, Feb 13, 2008
  7. SD
    Eiron Guest
    An excellent way for a poodlefaker to meet the ladies. :)
    Eiron, Feb 13, 2008
  8. SD
    V (for it is she) wants to move to Pinner. The commute from there to my
    office, using the Met line, is actually longer than the trek from the
    arse end of Berkshire. What's up with that?
    ogden, Feb 13, 2008
  9. SD
    Or Embankment to Covent Garden via Leicester Square.
    Insanity.
    ogden, Feb 13, 2008
  10. SD
    dog Guest
    it's god telling you to get out on your bike more.
    dog, Feb 13, 2008
  11. SD
    Well yes - apart from the length of your legs, obviously. Keep that
    up and you'll be 3'6" in ten years.
    And the air quality in The Smoke. You /do/ wear a Tokyo-approved
    filter mask, don't you? That would benefit the people around you as
    well, so perhaps not.
    Pip, Feb 13, 2008
  12. SD
    You know it's da troof though, dontcha? It ain't just the Wing, you
    know.
    Pip, Feb 13, 2008
  13. SD
    SaladDodger Guest
    <raises hand>
    When I first started at the Pru - I used to go Cannon St to Chancery
    Lane, via Monument and Bank.
    Well, I did it twice, before catching on.
  14. SD
    First Great Western in "not the worst train operator" shocka!
    CT, Feb 13, 2008
  15. SD
    I walk from Liverpool St. or Moorgate along the length of London Wall
    - there's remarkably little traffic (and sometimes I go along the
    Highwalks where the air's even cleaner) and then cut through Gresham
    St. to St.Pauls - there's really not much traffic - much less than
    there is where I live, actually.
    heh.
    darsy, Feb 13, 2008
  16. SD
    you daft/lazy sod.
    heh.
    darsy, Feb 13, 2008
  17. SD
    it's not all in one chunk - my commute each way is: 10 minutes walk ->
    30 minutes on the train -> 15 minutes walk. But as you say, I'm
    walking as fast as I can do comfortably.
    since I started doing it every day, I have noticed that the back aches
    I used to be susceptible to are much rarer.
    darsy, Feb 13, 2008
  18. SD
    SaladDodger Guest
    Oh, I do. Mined ewe, the Blackbird has been very well behaved for the
    last eight years.
    If you're interested, there's a new GL1500 maintenance blockbuster in
    the pipeline at the moment.
    Swing-arms, clutches, electricals, brakes - it's got the lot.
    Perhaps I could go for a LOTR-esque Trilogy:
    Fettleship of the 'bird; the Two Hondas; and Return of the Wing.
    I could cast Brad Pitt as me. You could be played by Andy Serkis.
  19. SD
    Lady Nina Guest
    You, coat, now.
    Lady Nina, Feb 13, 2008
  20. SD
    SD Guest
    I'll claim daft, in this instance.
    SD, Feb 13, 2008
