Oh Bollox...an endoscopy
Discussion in 'UK Motorcycles' started by Blotto, Mar 7, 2005.
  1. Blotto
    Leo Guest
    Aren't all Endoscopes shoved down your throat?
    If it's up the arse it's a Proctoscope
    DAMHIKIJDOK
    Leo, Mar 11, 2005
    #61
  2. Blotto
    Sphinctervision. :)
    Muck, Mar 11, 2005
    #62
  3. Blotto
    Donegal Paul Guest
    "Lord Frag" said to Donegal Paul barfed:
    Not that you have shite veins, but that iv's are the root cause of
    collapsing veins.
    There is that, some people are difficult to cannulate, no doubt, and these
    are the people that any nurse with a brain wont let a doctor have more than
    one or two gos, we generally then call one of the anaesthetists to do it and
    they /almost/ always get it first time every time. But cannula's really
    should last more than a day, if not it's down to technique, or position, or
    poor care.
    yup, better veins but a bit more difficult to get at certainly, of course,
    these (due to their position) are actually more likely to only last a day
    Nope. I regularly have patients on our wards that are on loads of IV
    antibiotics and if all conditions are met as mentioned, ie position, care,
    etc, they last more than a day.
    the 250ml bag will more than likely be clarithromycin I suspect. I dunno
    what the 50 ml 3 times a day is, ive never heard of that sort of dilution
    for any antibiotic.
    Was this put through a pump or manually given?
    LOL, don't be daft man. I never denied you have shit veins, or that you
    imagined any of the cannulas, all im saying is that they should last longer
    than a day and if not , its not down to just having antibiotics through
    them.
    Donegal Paul - On the mend
    Maico Letta 247cc - We have the technology.
    Zundapp Bella r203 - Watch out for ze Germans!
    Bajaj Chetak 125 - Wannabe Vespa
    Lambretta Li186 - stripped.
    Vespa T5 Millenium - intact
    www.thepilgrimssc.co.uk
    www.iowcaravans.co.uk
    Donegal Paul, Mar 11, 2005
    #63
  4. Blotto
    Donegal Paul Guest
    "Bear" said to Lord Frag says...
    There is no way in hell that you should have been subjected to that amount
    of cannulas, thats fucking ridiculous to be quite frank.
    If your veins closed (and hence the cannula failed) due to inflammation from
    the ABs, then they were not being administered correctly, either incorrect
    dilution, technique, lack of flushing etc etc.
    #64
  5. Blotto
    Donegal Paul Guest
    "Leo" said to mb
    Nope, endoscopy actually covers all scopes.
    Throat could be either airways or stomach and is bronchoscopy or gastroscopy
    respectively.
    arse could be proctoscopy, colonoscopy or sigmoidoscopy.
    there is also, laryngoscopy and auroscopy.
    Girly specific could of course be colposcopy
    Then youve got arthroscopy, or laparoscopy too but they involve a degree of
    minor surgery for access:)
    #65
  6. Blotto
    Technically, an endoscope would be for any inspection of an internal
    cavity (etymology being endo, inside, and scope, visual display)
    So a "proctoscope" is merely a form of (or, rather, method of using an)
    endoscope.
    ogden, Mar 11, 2005
    #66
  7. Why don't you take this to alt.fan.cannula where your sort are
    tolerated?
    Simon Atkinson, Mar 11, 2005
    #67
  8. Blotto
    I got a collapsed vein on my arm from having lots of antibiotics put in
    iv. One of the nurses didn't even get rid of the gas bubble in the
    syringe, and shoved the liquid in so fast that my vein went sort of pop.
    Muck, Mar 11, 2005
    #68
  9. Blotto
    Donegal Paul Guest
    I did try that but they couldn't see my point?
    #69
  10. Blotto
    Donegal Paul Guest
    Ah, that would **** 'em right up, but that's due to shite technique and
    really does piss me orf
    #70
  11. Blotto
    Pissed me _right_ off at the time. Can you imagine my panic at the sight
    of a bubble of gas going into may arm? Come in with a strep eaten
    finger, go out with gas bubbles causing problems god know where.
    Muck, Mar 11, 2005
    #71
  12. Blotto
    Eiron Guest
    A little bubble won't do any harm.
    At least that's what nursey told me when she couldn't be bothered
    to clear it.
    Eiron, Mar 11, 2005
    #72
  13. Blotto
    Yeh, I know that now, but at the time she didn't explain anything. Maybe
    she was having a bad day or something.
    Muck, Mar 11, 2005
    #73
  14. Blotto
    Donegal Paul Guest
    It's not really acceptable practice, mainly as it can be a factor in
    cannulation failure, but other than that a small bubble wont do you harm
    like kill ya.
    they will easily dissolve into the bloodstream / tissues.
    #74
  15. Blotto
    Donegal Paul Guest
    One thing though, this is ok(ish) in cannulae in arms and legs, but strictly
    not acceptable in big lines such as hickmans and central lines.
    Basically, the same principle applies however, in some cases where these are
    being used frequently, it is possible, rare but possible, for several
    smaller bubbles to accumulate and before dissapating will / can "burp" from
    their resting place and cause an embolus that lodges in your heart and kills
    ya!
    #75
  16. It was somewhere around Barstow, on the edge of the desert, when the
    Jeez; I recall some hash-bash merchant of a nurse doing that and
    thought, "****! I'm gonna die!", as it went in my arm.
    In fairness to nurses everywhere; I've had my fair share of needles in
    orspitals and she was an exception.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Mar 11, 2005
    #76
  17. Blotto
    Hash-bash, I like that term.
    This is true in my experience. They have to deal with some really bad
    stuff, and be expected to do it day in, day out.
    Muck, Mar 11, 2005
    #77
  18. Blotto
    Crumbs. Embolus sounds bad.. <fx: googles> Ahh.. that is bad. A clotted
    bit of blood that goes somewhere and blocks something up.
    I guess that being on the deoxygenated bit of the plumbing, a bubble
    would dissipate quicker.
    Muck, Mar 11, 2005
    #78
  19. Blotto
    Owen Guest
    And if its down your willy...?
    O
    1 Black, shortly to undergo extensive surgery.
    1 Red, undergoing lightweight surgery. -----
    1 Blue, for Power-Ranger baiting. | o |
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Mar 11, 2005
    #79
  20. Blotto
    Owen Guest
    snip
    Wot no vaginascope?
    O
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Mar 11, 2005
    #80
