Oh bollocks . . . .
Discussion in 'UK Motorcycles' started by Buzby, May 22, 2005.
  1. Buzby
    Simes Guest
    The said:
    Shag their wife and ride their bike within 12 hours of death being
    confirmed.
    Simes, May 22, 2005
  2. Buzby
    AndrewR Guest
    Heh, I know the answer to this one because SWMBO has just done her advanced
    training on this subject.
    Amazingly a bit of a run-up to give them an almighty punch in the chest is
    the order of the day.
    The trick, apparently, is in telling when somebody has gone down because of
    heart attack and when they've just fainted :)
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1, Fiat Coupe 20v Turbo
    The speccy Geordie twat.
    AndrewR, May 22, 2005
  3. Buzby
    dwb Guest
    Is it the A4030, or the B4030? As looking at the map, I can see a B4030 near
    Bicester, not not an A...
    dwb, May 22, 2005
  4. Buzby
    Simes Guest
    Bear said:
    You're not trying to sort it - you are merely preserving life until the
    experts arrive. So, you can reduce the bleeding, elevate a limb etc,
    apply heart massage if the heart has stopped, artificial respiration if
    breathing has stopped etc etc.
    Simes, May 22, 2005
  5. Please read my other posting.
    The Good Samaritan defence was specifically coined so that people
    *wouldn't* refuse to give first aid help for fear of being sued.
    The Older Gentleman, May 22, 2005
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear
    Bollocks. Firm pressure will certainly help.
    Once again, bollocks. A sucking lung wound can be greatly helped with a
    credit card. (Really).
    Use CPR to keep blood moving and oxygenated. Keep it going until the
    ambulance turns up. They can then take over. It's a small chance that
    you'll save the person. But it *is* a chance (as a neighbour once proved
    with my dear old mum).
    I'd suggest you're wrong.
    and Ducati Race Engineer.
    Wicked Uncle Nigel, May 22, 2005
  7. Buzby
    tallbloke Guest
    Wrong. there are simple things which can be done by someone who has had a
    couple of hours training which could save a life whether the injuries to
    the victim are serious or not.
    For example,
    1 preventing the tongue of an unconscious person from blocking their
    windpipe.
    2 Applying a torniquet to a profusely bleeding limb.
    Any more?
    tallbloke, May 22, 2005
  8. Buzby
    Simes Guest
    Bear said:
    If you happen upon the accident or injured person and are disinterested
    (i.e. not there as part of your employment) you are protected as you
    are acting as a Good Samaritan.
    If you are in a work situation your employer will (usually) indemnify
    you if you are an official first-aider.
    Simes, May 22, 2005
  9. Fascinating. I can see that being of great help in a pub brawl.
    "I was helping him recover from a heart attack, ossifer...."
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, tallbloke
    No longer recommended, I'm afraid. Direct very firm pressure to the
    wound is yer man here.
  11. Buzby
    tallbloke Guest
    There isn't one. Leave it on until the paramedics take over.
    Loosen the chinstrap if you can without jarring the neck of the victim.
  12. Buzby
    Buzby Guest
    Could well be - good road though and doesn't suffer fools gladly
    Buzby, May 22, 2005
  13. Buzby
    tallbloke Guest
    Loosen clothing around neck
    clear airways
    look for drugs in the car/bike luggage
    Cover with a coat if cold
  14. Buzby
    Simes Guest
    tallbloke said:
    How old are you? It hasn't been called a tourniquet since the Crimean
    war...
    It's still the same thing mind.
    Simes, May 22, 2005
  15. Buzby
    Kevin Stone Guest
    Nicely worded.
    Kevin Stone, May 22, 2005
  16. Buzby
    MattG Guest
    Bear said...
    There's a fairly substantial difference between sorting, and keeping
    them alive long enough for someone else to sort them. Knowing how and
    where to press on an arterial bleed can keep someone alive long enough
    for paramedics to arrive.
    That too. Being able to asses the injury and deal with the casualty
    appropriately can keep them alive, positioning them so that they don't
    drown in their own blood, for one.
    Far too many, really. And I CBA.
    Patient management, positioning, reassurance. Positioning being
    important. CPR is less about restarting the heart, more about keeping
    the brain oxygenated. Out of all the people I know who have had to
    perform CRP (and that's a lot of people) only 2 have ever restored
    rhythm, but that doesn't mean the others wasted their time. Them doing
    CPR mean that when someone arrived with the appropriate equipment the
    patient hadn't been sitting there suffering from oxygen starvation for
    the last x minutes.
    IME, very useful and effective, going way beyond commonsense. Someone
    has had something heavy fall across their leg? What you going to do?
    Move it? Most people would, commonsense, that. However, by doing that
    you could kill them. Renal failure as a result of reperfusion injury
    following a crush injury is common in this situation. Would you know how
    long after the crush injury it is safe to remove the object? Those who
    have had first aid training should know. That is just *one* of many
    possible examples.
    MattG, May 22, 2005
  17. Buzby
    tallbloke Guest
    The nurse stood more chance of being sued than you. She has professional
    training and may be liable for fuckups.
    If you have ornery first aid training you are in the clear.
  18. LOL! That's *exactly* what I thought he meant, until I read your
    posting.
  19. Buzby
    mb Guest
    AOL. Tourniquets are now generally regarded as not much use. Pressure
    required to stop bleeding will prolly stop useful blood flow (unless
    your leg has already fallen off).
    They may be of some use with snake bite victims thobut.
    mb, May 22, 2005
  20. Buzby
    Simes Guest
    Iain said:
    When you work for an ISP that doesn't give two fucks about Usenet, I
    suppose you tend to get sloppy yourself.
    Simes, May 22, 2005
