Oh Arse. Heeeeeelp! Paging Mechanics
Discussion in 'UK Motorcycles' started by Nigel Eaton, Apr 6, 2004.
  1. Nigel Eaton
    Nigel Eaton Guest
    I *knew* doing a service on the ZZR was going to end in tears.
    Pulling the cylinder head cover off has revealed nasty looking pitting
    on one of the inlet cams. Piccies at:
    http://www.eaton.me.uk/zzrcam/
    All the others look OK. So, assembled wisdom, what do I do:
    A) Do the shims, bung it all back together and pretend nothing ever
    happened[1].
    B) Get a second hand camshaft from somewhere.
    C) See if I can get this one built up and reground.
    D) Go and sit in the corner of the garage and cry.
    Audience, vote on your keypads now!
    [1] Well, it was running quietly before, how bad can it be? <sob>
  2. Nigel Eaton
    petrolcan Guest
    E) Sell it?
    petrolcan, Apr 6, 2004
  3. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, petrolcan
    Not my style, I'm afraid. Unless I've fixed it first, or told the lucky
    punter about the problem. I'm my own worst enemy at times.
  4. Nigel Eaton
    Slider Guest
    *Cough*
    Slider, Apr 6, 2004
  5. Nigel Eaton
    petrolcan Guest
    You are just *too* fucking nice :)
  6. Nigel Eaton
    Ginge Guest
    You may want to talk to:
    http://www.sep-kegworth.co.uk/
    It's a small firm with 3 blokes in an old fashioned workshop, seem to
    have a decent reputation, they did a decent job on the SZR bottom end
    rebuild for me.
    Ginge, Apr 6, 2004
  7. Nigel Eaton
    Gyp Guest
    That'll be metal transference mate ;-)
    What gets me it that it's divots rather than plain wear, which suggests
    lumps of something somewhere.
    Does anyone do a high lift long duration alternative, whilst they are
    out, like?
    Gyp, Apr 6, 2004
  8. Nigel Eaton
    Andy Hewitt Guest
    I was thinking that too. Unfortunately if you look closely at the oil
    that's sitting on the seals it looks like there's some swarf content in
    the oil too.
    I think I'd start looking for a cause of this, and what might have sent
    bits around the engine. It might even suggest a blocked oil filter if
    this is using a by-pass type - the oil doesn't look too cool either.
    Andy Hewitt, Apr 6, 2004
  9. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Andy Hewitt
    I think that's just some crud that fell in when I removed the head
    cover. The seals are partially exposed when the cover's on which is
    where most of the crud came from. I *did* try to clean it up before
    removing the cover, honest. ;^)
    There's no swarf or other unpleasantness in the filter or the oil I
    drained as part of this job. The oil was due a change anyway, which
    explains the appearance.
    I'm hoping it's the 'known problem' that Champ refers to.
  10. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    That appeals.
    I'll have a sniff around and get some prices.
    Hmm... I'm pretty sure that mine (an "R" plate) would be well out of any
    sort of warranty, but it can't hurt to ask. And the mods question is a
    good 'un, ta.
  11. Nigel Eaton
    That's oil? I thought it was teriyaki...
    Platypus - (surreal)
    Triumph Trophy 1200 (The Incredible Hulk)
    VN800 Drifter (still for sale)
    R80RT (for sale - spares or repairs)
    Z200 (Fear the Distance Monster!)
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    platypus, Apr 7, 2004
  12. Nigel Eaton
    Andy Hewitt Guest
    Yes, that'd be good. I was just seeing it as it was at face value.
    Andy Hewitt, Apr 7, 2004
  13. Nigel Eaton
    Andy Hewitt Guest
    LOL.
  14. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    <dips finger>
    <licks finger>
    No, no, it's oil. Phew! You had me worried there.
    Nigel Eaton, Apr 7, 2004
  15. Nigel Eaton
    <sucks air through teeth> Well, there's your problem. Now, if you'd been
    running it on yer actual teriyaki - or even nam pla, at a pinch - then you
    wouldn't be having these problems, would you?
  16. Nigel Eaton
    Nigel Eaton Guest
    The plot thickens...
    I've just been out and checked the measurements I took earlier. *All* of
    the exhaust valves are way out of spec (gap too small).
    Inlets are OK, except for No 1, which is too small (by about 0.05mm). No
    1 is not the one with the cam problem.
    Now, it's been about 20,000 miles since they were last checked[1] (I
    know, I know...) but it's surprising me a bit that all of the exhaust
    valves are so far out.
    Any theories on why, or is this just "one of those things"?
    [1] By a proper, professional, grease monkey.
  17. Nigel Eaton
    DangerScouse Guest
    Nigel Eaton says...
    D'you know, I've always wondered what pitting looked like, never seen it
    before.
    On a bad point [1], as the picture loaded I could smell the oil out of
    the engine...
    Well, as it's a cam problem and not a shim problem, replacing the cam
    seems the easiest option. But I've never been in this position, and
    being a burd wtf do I know anyway?
    [1] For you, not me
    Lesley
    ZXR400SP
    SBS#11[with oak-leaf cluster]
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    Un-cork me to reply
    DangerScouse, Apr 7, 2004
  18. Nigel Eaton wrote
    They look like they have been hot sometime in their life.
    Check your available credit balance.
    steve auvache, Apr 7, 2004
  19. Nigel Eaton said:
    He charged you, but actually did nothing?
    Simon Atkinson, Apr 7, 2004
  20. Nigel Eaton
    prawn Guest
    Indeed. I had a lay shaft go[1] an my BMW R100T gearbox many years
    ago. It was years after any warranty, but BMW 'went halves' with me,
    which was nice.
    [1] Fantastic screecing sounds.
    prawn, Apr 7, 2004
