Oh arse - Computer down
Discussion in 'UK Motorcycles' started by Nigel Eaton, Oct 17, 2004.
  1. Nigel Eaton
    tallbloke Guest
    Oops. Need any help with data recovery?
    tallbloke, Oct 17, 2004
  2. Nigel Eaton
    John Higgins Guest
    <twitch>
    Dell order? What you looking at?
    The hint is in the .sig :)
    John Higgins, Oct 17, 2004
  3. Nigel Eaton
    John Higgins Guest
    There's no flap on the Dimensions but the connectors are recessed and
    a bugger to see unless level with them.
  4. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, tallbloke
    No, thanks. The machine appears to be well on the way to recovery. I
    seem to have lost audio at the moment, but I'm going to get the 4lb lump
    hammer in a minute.
  5. Nigel Eaton
    tallbloke Guest
    Take a backup of important files first if you have an unstable system.
  6. Nigel Eaton
    <fx: looks at watch>
    sweller, Oct 17, 2004
  7. Nigel Eaton
    John Higgins Guest
    Erm, you can't. I think that's the whole point. However in Dell's
    excellent design, it's very easy to *attempt* to stick the headphone
    jack in the USB socket since they are side by side and difficult to
    see unless on one's hands and knees (assuming that the PC is on the
    floor, of course)
  8. Nigel Eaton
    tallbloke Guest
    This is the usual posture for those running microsoft operating systems isn't
    it?
  9. Nigel Eaton
    John Higgins Guest
    Must not bite, must not bite!
  10. Nigel Eaton
    Christofire Guest
    That's not what this Nigerian fellow here says.
    Christofire, Oct 17, 2004
  11. Nigel Eaton
    tallbloke Guest
    Oh go on, the linux wars have degenerated into minor skirmishes recently.
  12. Nigel Eaton
    Andy Hewitt Guest
    <looks at Mac G5> Hmm, same here the headphone socket is just above the
    USB port on the front panel. Can't say I've had any problem
    distinguishing between the 3.5mm round hole, and the much larger oblong
    hole for the USB!
    That's a very close YTC# I would say. Certainly forgiveable once, but
    twice.....
    Andy Hewitt, Oct 17, 2004
  13. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Andy Hewitt
    Like I said, it's right at the bottom of the front panel, there's
    actually an overhang that completely obscures both sockets. So it's
    pretty easy to do.
    Stupid, but easy.
    The USB sockets are now disconnected from the motherboard.
  14. Nigel Eaton
    Andy Hewitt Guest
    Why not just plug an extension lead into one of them?
  15. Nigel Eaton
    Nigel Eaton Guest
    Because there's a USB hub plugged into one of the sockets on the back.
  16. A lot of Dells don't. The plug from the ATX power supply and the
    socket on the motherboard have a few pins swapped round. So,
    motherboard cannopt be replaced with an off the shelf one, and ditto
    case.
    Simpler to go to the PC fair and get something sensibly prioced.
    Steve Uzochukwu, Oct 18, 2004
  17. Nigel Eaton
    Catman Guest
    <postcard>
    I'm gonna go for 'no'
    </postcard>
    www.cuore-sportivo.co.uk
    Catman, Oct 18, 2004
  18. Nigel Eaton
    Steve Uzochukwu was seen penning the following ode to ... whatever:
    I had a vague idea that this may be the case.
    Another good reason not to buy Dell...
    Timo Geusch, Oct 18, 2004
  19. Nigel Eaton
    Catman Guest
    There are so many to chose from.
  20. Nigel Eaton
    Alex Ferrier Guest
    What? Not, 'come an' 'ave a go if you think you're hard enough'?
    You big gurls.
    Alex
    BMW R1150GS
    DIAABTCOD#3 MSWF#4 UKRMFBC#6 Ibw#35 BOB#8
    http://www.team-ukrm.co.uk
    Windy's "little soldier"
    Alex Ferrier, Oct 18, 2004
