Ogden paging
Discussion in 'UK Motorcycles' started by ogden, Aug 29, 2003.
  1. ogden
    A quick request for assistance and/or ideas
    On Sunday myself and a Mr Blaney of this parish are shipping an
    unhealthy Bandit 12 to Essex and, as expected, the comedy of
    errors has begun before the bike has moved so much as an inch.
    The van we were going to use has broken down and won't be
    available. I can get use of another one if it comes to it, but
    we're a bit stuck for a way of getting something as effin'
    heavy as a b12 a couple of feet up into the back of the van,
    lacking a ramp, a winch, a crane or some kind of trebuchet.
    Can anyone help? We're a bit stuck thus far.
    Thanks in advance.
    ogden, Aug 29, 2003
  2. ogden
    JackH Guest
    You want a nice scaffolders plank, you do.
    JackH, Aug 29, 2003
  3. ogden
    Cane Guest
    Cane, Aug 29, 2003
  4. I missed this. How unhealthy is it?
    This is a moderately serious suggestion. Get a
    rope. tie it to the headstock of the B12, and the
    other end to some point, preferably a tow-bar, of
    the van. Put Blaney on the B12, yourself in the van,
    and off you jolly well toddle.
    (When I crashed my CX500Euro, this was how it was
    collected by the buyers. But the front brake had
    seized and the forks were bent. Oh, and instead of
    a van, they used another bike.)
    Or, nick a piece of wood to use as a ramp.
    William Grainger, Aug 29, 2003
  5. ogden
    Mark Trotman Guest
    One wheelie, one stoppie. What is it with you lot? :-D
    Mark Trotman, Aug 29, 2003
  6. ogden
    Oh, should note, we may also be lacking straps to keep the bike still
    while in the back of the van, so an alternative to using the van at
    all may be better...
    ogden, Aug 29, 2003
  7. ogden
    JackH Guest
    I said a nice one... not one littered with nasty shards of Kawasaki and
    scraps of our token Geordie.
    Don't want to soil / puncture the tyres, after all.
    JackH, Aug 29, 2003
  8. It's like the blind leading the blind.
    U all drive safely, now ;-)
  9. ogden
    take the front end off, rear wheel and seat unit off, and put it in
    the back of an estate car?
    darsy, Aug 29, 2003
  10. ogden
    Alan.T.Gower Guest
    Fair point.
    Alan.T.Gower, Aug 29, 2003
  11. In uk.rec.motorcycles, ogden said:
    Don't you have any neighbours? Make a lot of noise and then ask for some
    help when they come to investigate.
    Whinging Courier, Aug 29, 2003
  12. ogden
    Sean Doherty Guest
    Remembering to drain the petrol tank first.
    Sean Doherty, Aug 29, 2003
  13. ogden
    fucking spoil sport!
    darsy, Aug 29, 2003
  14. ogden
    Salad Dodger Guest
    Why not lift the fucking thing in?
    Weggy and I managed to get a CBR1000 into the back of a Transit with
    no ramp, in about a minute and a half.
    | ___ Salad Dodger
    |/ \ GL1500SEV/CBR1100XXX/KH500A8/TS250C/exTS185C
    _/_____\_ ..57146../..13615.../..3157./.19406/.fecked.
    |_\_____/_| IMC#4 TPPFATUICG#7 YTC#4 DIAABTCOD#9 PM#5
    (>|_|_|<) BOTAFOT #70 two#11 Ignoramus #0001
    |__|_|__| BOTAFOF #09 IbW#0 & KotIbW# OSOS#07
    \ |^| / WG* BotTOS #6 GP#4 ANORAK#17
    \|^|/ 2003 RBR landmarks:81 points:1740 miles:6835
    Salad Dodger, Aug 29, 2003
  15. Use some adrenaline. Got us a R1100GS into the van, hoiks the front up
    with two man, drop it on the floor, then the back wheel. Get a third
    person to hold it steady at the opposite end where you are lifting.
    Surprisingly easy and explains why you should always lock your bike to a
    solid object. If the rear wheel is siezed, bring a skateboard.
    Cheers,
    Merijn Broeren, Aug 29, 2003
  16. A few possibilities...
    1. Steal/beg/borrow/buy a plank of wood.
    2. Put a good size stick through each wheel and use them to carry the bike
    (one chap at each end). Hard work but you should be able to lift it a couple
    of feet if you're reasonably fit.
    3. Search your house for a team of weight-lifting pixies and ask them to do
    it. Be nice though, the last time somebody tried this they got turned into
    John Prescott. :-(
    Mr. Fantastic, Aug 29, 2003
  17. ogden
    That is the most sensible suggestion, involving the minimum labour and
    outlay. That is, if either of you pair of cunts could G enough of AF
    to take out some cover in the first place.
    Failing that - shove the Bandit up a plank into the van. Push the
    bike as far as it will go into the front left corner - front wheel
    against the end, like. Stop it in gear (so it cannot roll back) and
    put the sidestand down, leaning the left bar hard against the side of
    the van. Then lash a bit of rope from the side of the van to the
    frame, pulling leftwards and down (Blaney's yer man for straining rope
    and tying knots, Shirley). It can't go anywhere then. This is how I
    moved three, or was it four of Loz's bikes from Worksop to Dover using
    only one strap - they never shifted. Double insurance, cabletie the
    front brake lever back to lock the front wheel.
    Failing all that, rent a van with a tail lift. Or ask me nicely and
    I'll come down with my trailer, but you'll have to cover my petrol
    'cos I'm skint as usual.
    Good luck ;-)
    Pip, Aug 29, 2003
  18. ogden
    yes, but this case the people weigh less than the bike.
    darsy, Aug 29, 2003
  19. ogden
    Salad Dodger Guest
    Ah, yes. Good point.
    | ___ Salad Dodger
  20. ogden
    Ben Blaney Guest
    It's a non-runner.
    Ben Blaney, Aug 29, 2003
