Of HTPCs, Graphics Cards and Windows MCE...
Discussion in 'UK Motorcycles' started by antonye, Feb 23, 2007.
  1. antonye
    antonye Guest
    I've got a bit of a problem with my HTPC. Basically I was
    given an Epia M10000 mini-itx motherboard that I put in
    a Cubid 3688 case, DVDRW, 80Gb drive, etc etc. [1]
    Now this has made a really nice little PC when I got it
    all running, but the problem came with Windows Media
    Center - this uses video overlay to accelerate the
    graphics but the TV-out on the Epia doesn't work with
    the overlay, so you end up with a black screen.
    I've fished around for a low-profile (PCI) graphics
    card but this doesn't fit into the case either, so
    I'm a bit stuck. I've tried GBPVR, which works fine
    through the TV-out, but the video output is so slow
    that it is unwatchable... a better graphics card would
    help but they don't fit in the case ... and round
    we go again.
    So any recommendations? I really don't want to junk
    all this kit, but an XBox360 is looking more and more
    tempting as I stumble through this!
    I guess I could change the motherboard for a better
    one, and hopefully one that works with MCE, so has
    anyone got any recommendations?
    TIA.
    [1] http://mini-itx.com/store/
  2. antonye
    antonye Guest
    The built-in graphics processor is not good enough
    and I cannot add an additional graphics card due
    to the form size.
  3. antonye
    antonye Guest
    The case is only 65mm high, so not much space inside
    once the mb is mounted; standard height cards don't
    fit, and neither do low profile (half height) ones.
    I think it'll be a mb upgrade to something more
    beefy that will support MCE.
  4. antonye
    Or...does the current set up actually have an internal TV capture
    card? If so he could (cheaply) have my Hauppauge PVR-350 card (the
    same as yours) which includes the TV-OUT that works well with GBPVR.
    darsy, Feb 23, 2007
  5. antonye
    antonye Guest
    See above ... cards don't fit :-(
    I might just buy a 42" lcd tv with pc input instead...
  6. http://linitx.com/product_info.php?products_id=1366
    (or a left-handed one, depeneding on the motherboard layout).
    Slower Than You, Feb 23, 2007
  7. antonye
    antonye Guest
  8. antonye
    FooBar Guest
    At the very same establishment they have something called a "PCI riser
    card". These basically translates into something like "an angled extension
    card", that allows you to use a PCI-card mounted parallel to the
    motherboard (http://mini-itx.com/store/?c=8).
    For all (but the very slimmest/"vertically challenged"!) of cases, that
    should solve the problem. (I even think they have some sort of table
    listing which cases will allow PCI-cards etc...)
    FooBar, Feb 23, 2007
  9. antonye
    no cards whatsoever? That's some crappy case...the Hauppauge is PCI,
    if that helps.
    what, you mean you haven't got one already?
    Pikey!
    darsy, Feb 23, 2007
  10. antonye
    antonye Guest
    The case is 65mm high - that's the whole point.
    This thing is tiny and that's the way I want it.
    Meh. We've still got our £399 28" widescreen telly
    we bought with gift vouchers from when we got married;
    a Matsui branded box from Dixons/Currys that everyone
    said wouldn't last more than a year. It has been pulled
    off the stand by the kids twice (a drop of about 2 feet)
    and is still going strong with just a couple of minor
    dents in the speaker covers. We got married 8 years ago,
    so it certainly has lasted well.
    I'm still waiting for the technology to settle down,
    as I don't want to shell out on old stuff or screw
    myself within a couple of years. Plus prices are coming
    down all the time. And I'm not allowed to watch much
    on the thing as it is!
