Of commuting and possible winter hacks
Discussion in 'UK Motorcycles' started by Pip Luscher, Dec 11, 2004.
  1. Pip Luscher
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip Luscher
    This would be "soul searching" in the sense of "running away as fast as
    you can; no, faster than that" would it?
    Nigel Eaton, Dec 13, 2004
  2. Ok, rang up and asked. Apparently, the engine runs OK. It needs a
    battery but the main problem is that the clutch bellhousing emits a
    nasty noise when the engine's running unless the clutch is depressed -
    they reckon it isn't rideable at present.
    So the swingarm & gearbox would have to come off in order to look at
    the clutch. If recent car experience is anything to go by, I suspect
    that it could be the gearbox.
    Looking at my various Guzzi books, it's not entirely stock, but that
    doesn't bother me.
    Ho hum. Not quite what I was looking for, but bags of character. Time
    for some soul searching.[/QUOTE]
    Sounds like output shaft bearing to me. Anyway, leave well alone.
    The Older Gentleman, Dec 13, 2004
  3. Pip Luscher
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    <looks in garage>
    A compressor?
    The Hippo's still on its holidays.
  4. Pip Luscher
    On Mon, 13 Dec 2004 22:53:52 +0000,
    I hadn't thought of that.
    The Quota did once start producing the most unbelievable grinding
    noises from the clutch housing, which turned out to be the starter
    motor drive contacting the flywheel, but I'm not about to gamble 750
    quid to find out!
    Well, I had an attack of Lust, but I'm better now.
    -Pip
    TL1000R The Quietly Booming Banana
    Guzzi Quota 1000: The Black Tractor
    YZ250: Rough 'n' Tumble
    Mongrel DT125: The Rust(ic) Garden Ornament
    Pip Luscher, Dec 14, 2004
  5. Pip Luscher
    I am most certainly a disciple of the Way of the Gentle Art of
    Bodging. In fact, I was actually doing some official bodging as part
    of my work today, which made a pleasant change.
    Unfortunately the headlight connector blocks are fine, it's the actual
    bulbs themselves that're the wrong shape.
    I have tried 35W halogens (they don't seem to do a higher wattage in
    this fitting), and they do help a bit. In fact, there's still one in
    there now, but for some reason, the filaments are set too far back in
    the bulb and a certain amount of modification to the bulb is needed to
    get a remotely decent beam pattern.
    The other problem is the size of the lamps: they're only 13cm (about
    five inches) in diameter. Apparently there are a number of Jap 400s
    with lamps this size, so that might be a source.
    I ddi see one Quota whose owner had fitted spotlights: I'm not sure
    that these can be used with dip beam, though.
    -Pip
  6. Pip Luscher
    Pretty close. Picture the scene: blondish woman with recently-bought
    car decides to top up the screenwash. Unfortunately, it's dark, the
    car is unfamiliar and the screenwash and power steering reservoir are
    very close to each other. Quite understandable circumstances, really.
    As the liquid overflows almost instantly, she realizes her mistake.
    Now the silly part: she can't get hold of me on the phone, so decides
    to drive round anyway, rather than walk or cycle, thus thoroughly
    pumping the liquid round the steering system.
    -Pip
  7. Ouch. Permanent damage or simply a flush-and-replace job?
    The Older Gentleman, Dec 14, 2004
  8. Pip Luscher
    tallbloke Guest
    I have a T3 and a Quota.
    I put cibie lamps in the quota and can now see where I'm going.
    The T3 is a good bet at that price if it has wire wheels.
    tallbloke, Dec 15, 2004
  9. But not if it has a fucked gearbox.....
    The Older Gentleman, Dec 15, 2004
  10. Pip Luscher
    It's not a bad price as a breaker anyway but if it has wire wheels;
    bearing carriers and cush drive (which it most certainly has) then that's
    ~£350 alone.
    sweller, Dec 15, 2004
  11. Pip Luscher
    ....and if it hasn't? Working geraboxes are fairly common and not /that/
    expensive.
  12. Fairy nuff.
    But 750 quid plus maybe 250/300 for a decent box....
    Assume another 250 quid for whatever else needs doing to it. Invoke
    TOG's Law (for every fault you see, there's one you've missed) and call
    it 500 quid. You might as well go out and buy a decent T3 straight off.
    OTOH, if it isn't the box, then this one's a bargain. Expert assessment
    is necessary.
  13. Pip Luscher
    Yours is a 1000, then? Did you have to mod the fairing in any way? I'd
    like to leave mine as stock-lookig as possible.
    It does.
    -Pip
    Pip Luscher, Dec 15, 2004
  14. Pip Luscher
    Ouch. Permanent damage or simply a flush-and-replace job?[/QUOTE]
    No noticeable damage - yet. Unless the seals don't like the mixture, I
    suspect that the most likely outcome will be a shortened pump life. I
    will give it a couple more "flushings".
    You can't just flush the entire system, unfortunately, there's no
    drain plug as such. I suppose I could've disconnacted the steering
    rack at one of its hose connections, but that wouldn't drain the rack
    itself.
    Instead, I've been extracting contaminated fluid from the reservoir,
    re-filling with fresh, then running the engine while wiggling the
    steering, then repeat ad nauseum.
    -Pip
  15. Pip Luscher
    tallbloke Guest
    I didn't have to hack the fairing, But modified and beefed up the carrying
    bracketry. Unbelieveable difference, the cibies are just superb.
    If the wheels are nice - buy it! The reg-rectifiers are rebuildable using
    bits from maplins, I have a mate who is an expert with Guzzi elecs if you
    get stuck.
