oddball problem
Discussion in 'Motorbike Technical Discussion' started by Larry Blanchard, Aug 7, 2011.
  1. I've written here before about various problems with my old (and beloved)
    '78 SR500. Lately it's developed an odd habit. If I let it sit for a
    few days, it still starts up fine, but dies in about the time it takes to
    empty the float bowl - about a 1/2 mile or less. Kicking it over several
    times gets it restarted and no more problems stopping and restarting on
    that day. If I run it every day, or even every other day, I never see
    the problem.
    It would seem to be the floats sticking in the up position, being jarred
    loose by kicking it with an empty float bowl. But why wouldn't the
    vibration (it *is* a thumper, after all) of running jar it loose? Why
    only after sitting for a few days?
    I use Star Foam every time I fill it up, and when the problem started I
    ran some B12 through it. The B12 seemed to help for a week or two, but
    then it reverted back to the problem.
    Initially the bike had a vacuum petcock, but that was replaced some time
    back with a non-vacuum one from an XS650. So no need for solutions
    involving that.
    Am I mis-diagnosing the problem? Is there something else it could be?
    I'm not adverse to replacing the floats and hinge if necessary, but since
    it's a PITA to remove/replace the carb I don't want to do that unless I
    have to.
  2. That is *really* odd.
    I'd be tempted to pull the carb and check the float operation all the
    same, since I don't see what else it could be. B12 is a waste of time:
    leave that to Krusty and the newbie idiots who believe him when he touts
    it as the cure-all from a stuck throttle to herpes.
    I'd also lay off the Star Foam - or do you mean Seafoam? If Yamaha
    wanted something added to the fuel on every fill-up, they'd have told
    you. It's quite possible that whatever it is in the Seafoam/Star Foam is
    causing the problem
    I'm guessing that the float is sticking. Ordinary running sees it
    working fine. Lay it up, and whatever is impeding it has time to set in.
    Suggestion: try it without the additive, for a tankful or two. And then
    pull the carb and check the float operation.
    The Older Gentleman, Aug 7, 2011
  3. Larry Blanchard
    Beryl Guest
    Krustacean has suggested B12 so many times here, that I had to try it.
    The non-aerosol liguid, a magnifying lens, and individual fine bristles
    pulled from a paint brush worked well in cleaning nearly invisible holes
    in jets. B12 was inexpensive too.
    Vibration almost HAS to shake the floats down. They're weighty, and hang
    out on a limb.
    I'll guess that the little tab on the float assembly that pushes up on
    the needle valve plunger isn't *hooked* to the valve, as it should be.
    It pushes up, but can't pull back down. Floats go up, plunger goes up.
    Floats fall down, valve plunger stays up.
    Beryl, Aug 7, 2011
  4. Yeah, but he just says to pour it into the tank and let it do its stuff.
    Anything more critical than pouring gunk into a tank, and he hasn't a
    clue. Anyway, it isn't the issue here.
    Sounds plausible. I think it's a float problem too. Shouldn't be hard to
    fix. Shouldn't be expensive either.
  5. Larry Blanchard
    Beryl Guest
    And Gordon Jennings' carb tuning articles are excellent, as he's
    claimed. I recently rediscovered two in my mid-'70s Cycle magazines.
    Explicit, detailed knowledge there, like you'd find in technical papers.
    Better than what Mikuni was able to offer in their technical manuals.
    Beryl, Aug 8, 2011
  6. They are indeed. Very rare, tech journalism of that standard.
    The Older Gentleman, Aug 8, 2011
  7. That's pretty much what I'd thought. But I had to ask in case I was
    entirely missing something else. That seems to be more common as I get
    older :). Thanks.
    Larry Blanchard, Aug 8, 2011
  8. Larry Blanchard
    blackholesun Guest
    Is the float shut off valve *round* in cross section, or is it triangular or
    four-cornered?
    A round float valve will stick very easily from gum and varnish buildup,
    while the other two types are less prone with sticking for that reason.
    blackholesun, Aug 8, 2011
  9. Larry Blanchard
    blackholesun Guest
    You're as full of shit as a constipated Donald.
    I tell newbies to pour 4 ounces of B12 into a full tank of gasoline and
    trying to flush out the gum and varnish that way so they can avoid hours of
    disassembly and re-assembly work.
    If you have a single cylinder Honda with everything exposed and you can
    snatch the carb off and strip it down to the essentials in 20 minutes,
    that's one thing.
    But if you have a plastic wrapped sportbike that has the carbs absolutely
    buried underneath tha gas tank and airbox, you're looking at 6 to 8 hours of
    work to get at the idle adjustment screws or the float valves and get the
    bike back on the road.
    In a situation like that, who wouldn't want to *ride* the bike until the B12
    cleaned out the gum and varnish?
  10. Larry Blanchard
    blackholesun Guest
    B12 makes an *excellent* martini, too. Stir it gently, don't shake it, as
    you don't want to *bruise* the acetone.
  11. Larry Blanchard
    WaIIy Guest
    Don't forget "Sea Foam", it's a great product.
    WaIIy, Aug 9, 2011
  12. You are? Wow. Care to give us an example of a sports bike that takes so
    long to access, based on your extensive experience?
    Thought not.
    The Older Gentleman, Aug 9, 2011
  13. Who cares? It's sticking.
    It's so *funny* watching you trying desperately to claw back what
    reputation you thought you once had,
    Others will soon find it funny, too.
  14. Larry Blanchard
    It might take 6 hours to get the fucking carbs right out. Some of them
    look to me like the engine has to be removed first ;o)
    Hog
    Remember the 4 "F" rule:
    If you're not Fucking me, Feeding me or Financing me
    ....your opinions really don't matter, so you can **** off
    Hog, Aug 9, 2011
  15. Larry Blanchard
    It's a prize moron whatever it is. Now safely in the KF
    Hog
    Hog, Aug 9, 2011
  16. Larry Blanchard
    Ian Field Guest
    This is only a theory that I'd try out of desperation if I CBA stripping the
    carbs down; maybe a generous dash of Slic50 in a tank of petrol in the hope
    that the PTFE particles adhere to the bits that are sticking.
    It wouldn't harm anything and there's always the option of doing the job
    properly in the long run.
    Ian Field, Aug 9, 2011
  17. Larry Blanchard
    Ged loves an optimist. And a tryer!
    Hog
    Hog, Aug 9, 2011
  18. Larry Blanchard
    blackholesun Guest
    Larry Blanchard cares, so my remarks were addressed to *him*, not you.
    Limey faggots like you are amused by many strange things...
    blackholesun, Aug 9, 2011
  19. Larry Blanchard
    blackholesun Guest
    You still haven't told us whether Neil Murray is the top and you're the
    bottom, or if you flip ****...
  20. Larry Blanchard
    blackholesun Guest
    You're either trolling or you're crazy.
