O.T. Networking Problem.
Discussion in 'Australian Motorcycles' started by Aido, Jan 11, 2005.
  1. Aido
    Aido Guest
    Hiya Peoples.
    I know this is probaly not the place for this question, But I know
    there's alot of knowledgeable people in here.
    I've just setup a router for network sharing & file sharing. I have a
    problem in that my wifes pc running XP can see & acces my pc & files, but I
    can't access her pc or files, My pc is running ME. When I open "My Network
    Places" on the ME machine, I get a Scripting error with the option asking
    if
    I want to proceed Yes or No. It doesn't matter what I pick, All I get is a
    "My Network Places" window with nothing in it.
    I thought it might be a compatability issue between XP & ME, Or a
    security setting on the XP machine.
    The access to the Internet works fine on both PCs.
    Any Ideas?
    Aido.
    Bikeless.
    Aido, Jan 11, 2005
  2. Aido
    Peter Wyzl Guest
    : Hiya Peoples.
    : I know this is probaly not the place for this question, But I know
    : there's alot of knowledgeable people in here.
    : I've just setup a router for network sharing & file sharing. I have a
    : problem in that my wifes pc running XP can see & acces my pc & files, but
    I
    : can't access her pc or files, My pc is running ME. When I open "My Network
    : Places" on the ME machine, I get a Scripting error with the option asking
    : if
    : I want to proceed Yes or No. It doesn't matter what I pick, All I get is a
    : "My Network Places" window with nothing in it.
    : I thought it might be a compatability issue between XP & ME, Or a
    : security setting on the XP machine.
    : The access to the Internet works fine on both PCs.
    : Any Ideas?
    ME sucks big kahuna as a network client of anything (and yet I have seen
    people using it as a server....)
    However, sound like something wrong rather than incompatibility. Can you
    uninstall and reinstall your LAN adapter and networking software? (sounds
    like an OS software problem, not hardware).
    If you can do that, try the adapter in a different slot. That can fool the
    OS into thinking it's a new adapter and reinstalling the networking
    components.
    Also a few runs of windows update installing all the critical updates can
    work wonders for all sorts of issues.
    P
    Peter Wyzl, Jan 11, 2005
  3. Aido
    Aido Guest
    Thanks Peter, Will give your ideas a go.
    Aido.
    Bikeless.
    Aido, Jan 11, 2005
  4. Aido
    Peter Wyzl Guest
    : Hiya Peoples.
    I
    : if
    : Any Ideas?
    Coupla things to check:
    Both PC's are members of the same workgroup name (usually 'WORKGROUP' for XP
    and 'MSHOME' for ME). They should both the same.
    Are both PC's getting DHCP from the router or are there any manual IP
    addresses?
    Are you using any other protocols? (IPX NETBEUI)
    For local PC's installation of a 'non routeable' protocol like IPX or
    NETBEUI can simply the connection between PC's.
    Just some ideas...
    P
  5. XP has encrypted passwords, and I don't think ME does, just run network
    setup on the XP box, when you get to create network setup disk, do it
    and run the executable created on the ME box, that might fix your problems.
    Mark.
    Mark Hutchison, Jan 11, 2005
  6. Aido
    Peter Wyzl Guest
    : Aido wrote:
    <snip>
    : XP has encrypted passwords, and I don't think ME does, just run network
    : setup on the XP box, when you get to create network setup disk, do it
    : and run the executable created on the ME box, that might fix your
    problems.
    The encrypted passwords wouldn't stop you being able to browse in network
    neighbourhood.
    P
  7. Aido
    Nev.. Guest
    Why not just try comp.something.something.networking. You can probably tell
    your story about the Tarago on the GOR without shit getting heaped on you
    there too :p
    Nev..
    '03 ZX12R
    Nev.., Jan 11, 2005
  8. Aido
    GB Guest
    Windows Me is Windows 98 with eye candy. 95/98/Me don't offer
    an opportunity to 'log on' except at startup, and they don't
    allow you to make SMB/CIFS connections as anyone other than the
    'logged on' username.
    Win NT/2K/XP requires a username/arseword to let you browse
    stuff, sometimes even the IPC$ share (which enumerates a bunch
    of other stuff, shares, etc) requires a username/password.
    You must make sure that the username/password pair that you
    'logged on' to 95/98/Me with exists and is enabled on the
    NT/2K/XP box.
    A potentially more rewarding approach might be to drop the
    lemon that is WinMe in favour of a Win2K install. Don't bother
    going to WinXP unless you have the time to strip all the crud
    out of it using nLite (http://nuhi.msfn.org/) or similar
    (a non-trivial but rewarding task IME).
    HTH,
    G
    GB, Jan 11, 2005
  9. Aido
    Uncle Bully Guest
    ME is the worst OS ever. If you can't even open My Network Places then there
    is something wrong with that PC. I'd fix that before trying to get a Network
    working.
    Uncle Bully, Jan 12, 2005
  10. Aido
    Aido Guest
    I've worked out a way to access the PC running XP from the machine
    running ME.
    I right click on "My Network Places" & then on "Search for Computers",
    Type in the XP michines name & the ME machine finds it, I can then access
    the XP machine. I know it's a round about way, but it works for me.
    Thanks everybody for your help.
    BTW, I've never had a problem with running ME until I've tried networking.
    And very few give ME praise.
    Aido.
    Bikeless.
    Aido, Jan 12, 2005
  11. turn off xp's firewall.
    T.J. & L.K.Dunster, Jan 12, 2005
  12. Aido
    Aido Guest
    Nup, Turning the firewall off didn't help. Thanks for the idea anyway.
    Aido.
    Bikeless.
    Aido, Jan 12, 2005
  13. Aido
    Peter Wyzl Guest
    : I've worked out a way to access the PC running XP from the machine
    : running ME.
    : I right click on "My Network Places" & then on "Search for Computers",
    : Type in the XP michines name & the ME machine finds it, I can then access
    : the XP machine. I know it's a round about way, but it works for me.
    : Thanks everybody for your help.
    : BTW, I've never had a problem with running ME until I've tried networking.
    : And very few give ME praise.
    That sounds like a netbios browse master problem. The simplest way around
    that is to install IPX on both PC's. That will make local LAN stuff work
    without dependencies on TCP/IP which can be flaky from time to time in ME.
    P
    Peter Wyzl, Jan 12, 2005
  14. Aido
    Aido Guest
    I do plan on installing XP on the ME machine as soon as I change the
    VooDoo Banshee 3DFX video card, which XP doesn't like.
    I found this out when I did install XP on the ME machine some time ago &
    had no end of video driver problems, I come back to ME after I read that XP
    & VooDoo 3DFX cards aren't compatable. A mate had the same problem with a
    VooDoo3 3DFX card. He went baught another video card & it fixed his problem.
    Aido.
    Bikeless.
    in message
    Aido, Jan 12, 2005
  15. Aido
    Toosmoky Guest
    Only slightly worse than Windows 1.0...
    Toosmoky, Jan 12, 2005
  16. Aido
    John Littler Guest
    Que ?
    JL
    I can remember Win 2.0(which was basically a task switcher) and Win3.0
    as well as 3.1, but I didn't think there was an actual release of Win 1.0
    John Littler, Jan 12, 2005
  17. Aido
    atec Guest
    can you ping her ip in dos ?
    that's run/command/ ping her ip
    find your be config /all in dos
    if you cant ping her machine then close the firewall on her machine and
    try again.
    you need tcpip on both machines set up the same ...
    atec, Jan 13, 2005
  18. Aido
    atec Guest
    there was. then 1.2 , which was crap as well
    atec, Jan 13, 2005
  19. Aido
    Toosmoky Guest
    http://tinyurl.com/7xylp
    Toosmoky, Jan 13, 2005
  20. Aido
    Aido Guest
    Hiya Atec.
    If you read one of my earlier posts, You'll see that i've worked it out.
    Thanks for your idea anyway, I'll try it anyway.
    Aido.
    Bikeless,
    "atec" wrote in message :
    Aido, Jan 13, 2005
