'O' ring in the oil filter cover
Discussion in 'Motorbike Technical Discussion' started by NewBie, Mar 2, 2005.
  1. NewBie
    NewBie Guest
    Hi,
    I replaced the 'O' ring in the oil filter cover (Suzuki GZ125) with a brand
    new one but found the groove (holding the 'O' ring) is wider than the
    thickness of the 'O' ring. This has resulted the engine oil leaks when the
    bike travels. Any idea how to solve this problem?
    Thanks in advance,
    YC
    NewBie, Mar 2, 2005
  2. NewBie
    Mark Hickey Guest
    Get the right O-ring. That'd be the best way to do it.
    Also, make sure that the cover is tightened properly - tighten the
    bolts loosely at first, in a "star pattern" as you bring up the torque
    in several steps. If you just honk down on the first one, you'll
    probably have a gap by the time you get to the last one.
    Mark Hickey
    Habanero Cycles
    http://www.habcycles.com
    Home of the $695 ti frame
    Mark Hickey, Mar 2, 2005
