NX650 Dominator
Discussion in 'UK Motorcycles' started by John Munro, Jul 21, 2004.
  1. John Munro
    John Munro Guest
    So I took the oil pipe that feeds the cams off because
    it had a slight oil seepage and I'm gonna replace the copper washers.
    But, now both banjo bolts are off I now realise they are different.
    And obviously I Don't know which is which now <thud>
    They are both exactly the same except one has a _larger_ diameter oil
    hole on the side..
    The pipe goes from the oil filter housing to the top end.
    The Honda workshop manual does not differentiate between the 2 bolts.
    I reckon the smaller holed one goes to the top. Anyone?
  2. John Munro
    OH- Guest
    1+2 = 2+1
    Or maybe a little more clear - the oil does not care where you
    restrict the flow, the pressure drop will be the same.
    OH-, Jul 21, 2004
