NSW: noise regs
Discussion in 'Australian Motorcycles' started by Zebee Johnstone, Mar 5, 2008.
  1. This just came through on the MCC list.
    The following is a select motorcycle centric summary from the new
    regulations.
    * From March 1, 2008 enforcement agencies are to be held more accountable
    when issuing fines under the POEO. Authorised officers who intend to use
    certain sections of clause 5 and 18, must now have substantial reasoning
    to do so. In the previous regulations no reasoning was required and as
    such alternate agendas could be readily serviced by the POEO. Further
    information on this issue may be found in attachment "0871infomv.pdf"
    and also in the definition of "defective noise control equipment"
    in attachment "Protection Of The Environment Operations Noise Control
    Regulation 2008.pdf"
    [Basically they've added the word "reasonable" which may or may not be
    helpful - ZJ]
    * Provisions where made in the regs that take into account that motorcycle
    exhaust systems, including mufflers are substantially different from those
    of other vehicles and as such shall be exempt from certain construction
    requirements, see clause 5 and 18 in the attachments.
    [from the pdf: A defence is provided for:
    any motorcycle that has baffles that are bolted or otherwise
    securely fastened in place rather than substantially welded or riveted
    into place.
    The defence for removable baffles for all motorcycles has been
    provided because a significant number of standard original and standard
    aftermarket exhaust systems have baffles that are bolted or otherwise
    securely fastened in place. However all motorcycles are still subject
    to the provisions of clause 18 which makes it an offence to remove noise
    control equipment from a vehicle and not replace it.]
    * There are other implications, these may be found in the attachments.
    With the introduction of these regs a more equitable system has been
    created for all. It is also worth noting that the MCCofNSW were taken
    seriously by DECC law makers and credit must be given to all those in
    DECC who understood us and took onboard our concerns. A thank you is in
    order to the Policy Section at DECC.
    * exemptions on motorcycle muffler contruction were achieved.
    * some issues remain to be dealt with
    The two attached documents may be found at this URL
    http://www.environment.nsw.gov.au/noise/poeonoisereg08.htm
    Overall, we as riders remain responsible for the noise level from our
    vehicles, but now there is also very limited scope for opportunistic
    mis-use of legislation.
  2. Zebee Johnstone
    CrazyCam Guest
    Zebee Johnstone wrote:
    <snip>
    Thanks for that Zebee.
    Does this mean that the classic business of having the "spud" in the
    tool kit, being stopped and then fitting it won't actually get someone
    out of a ticket?
    regards,
    CrazyCam
    CrazyCam, Mar 5, 2008
  3. In aus.motorcycles on Thu, 06 Mar 2008 08:07:11 +1100
    No idea - want to be a test case? :)
    Zebee
  4. Zebee Johnstone
    CrazyCam Guest
    No.
    I was getting quite pissed off with the business where folk were stopped
    for being noisy and then they refitted either the standard exhaust or
    the "spud" to go to be tested and effectively got away with being noisy.
    regards,
    CrazyCam
  5. Zebee Johnstone
    Snapper Guest
    Zebee Johnstone wrote...
    Excellent result. Hopefully we can do something similar here in Victoria
    with respect to muffler labelling etc., to reduce the disparity between
    motorcycles and other vehicles that don't require specific labelling, but
    instead have to pass the basic noise level test.
    Currently, an EPA officer or a Victoria Police member can order you to
    have your vehicle tested at an approved testing station. This can occur if
    say you pass the officer who may either be travelling or be on the
    footpath, side of road etc. Often when this happens you get a letter in
    the mail with the "informant" making the accusation regarding your noise
    levels. And that's the first you've heard of it.
    This is open to abuse, too. And of course there are many bikes out there
    that clearly push the limits, too.
    But, if we can strike a balance such as what you guys have achieved then
    this would be a start.
    I'll forward this note of yours onto the MRA for its info.
    Snapper, Mar 7, 2008
  6. Zebee Johnstone
    Nev.. Guest
    Do we have a problem in Victoria with noise regs? It sounds like the
    NSW solution to their unique problem is to implement a system very
    similar to that which has been in force in Victoria for a very long time
    without any problem. What are you proposing the MRA do with this 'new'
    information?
    Nev..
    '07 XB12X
    Nev.., Mar 8, 2008
  7. Zebee Johnstone
    Snapper Guest
    Nev.. wrote...
    The MRA is seeking views from riders as to what outdated, inappropriate
    and "draconian" rules that apply to motorcyclists should be reviewed. The
    noise issues that the MCCofNSW may not be totally applicable to what we
    have in Victoria, but some of it does apply.
    If nothing else, it will be a "FYI" thing that the MRA may or may not be
    able to use when it next meets with Tim Pallas, the minister responsible
    for this sort of thing.
    Or do you see a problem with such exchanges of information?
    Snapper, Mar 9, 2008
  8. Zebee Johnstone
    Nev.. Guest
    The current Victorian EPA noise reporting rules are neither outdated,
    inappropriate nor "draconian".
    Tim Pappas isn't responsible for "that sort of thing". EPA regulations
    fall under Gavin Jennings' ministerial portfolio.
    Nev..
    '07 XB12X
    Nev.., Mar 9, 2008
  9. Zebee Johnstone
    Snapper Guest
    Nev.. wrote...
    Maybe, maybe not. But this is but a part of a range of road rules that the
    MRA is seeking to have reviewed.
    That's so, but Pallas is currently the MRA's first point of contact.
    Anyway, given what you ride now I would have thought your views on noise
    emissions reporting would be considered to be "draconian"....
    Snapper, Mar 10, 2008
  10. Zebee Johnstone
    Nev.. Guest
    EPA noise regulations are not road rules.
    I don't understand what you mean. Are you saying my bike with it's
    factory fitted silencer which complies to Victorian EPA regulations is a
    problem for me? I have owned much noisier bikes than this, such as a
    GSXR1100 with a Tingate can which was so loud I couldn't ride it without
    earplugs. I have never had any problem with police or EPA officials
    reporting me for breaches of noise regulations on a bike. I only know a
    handful of people who have ever been issued notices to get a vehicle
    tested for noise levels, and of those who have (myself included), none
    of the vehicles reported were ever _not_ noisy... borderline yes, but
    quiet, no.
    Nev..
    '07 XB12X
    Nev.., Mar 10, 2008
  11. Zebee Johnstone
    G-S Guest
    We were issued with a noise notice for a detroit diesel coach with a
    stock exhaust.
    It was subsequently tested (without being altered in any way) and found
    to be within limits.
    We were unable to claim back the loss of income or the cost to send the
    vehicle to Melbourne.
    Now that does not seem reasonable.
    If a vehicle is in breach then fine... but if the roadside droids stuff
    up then costs should be available.
    G-S
    G-S, Mar 10, 2008
  12. Zebee Johnstone
    Yeebers Guest
    Costs *were* available .. you got some didn't you ;)
    Yeebers, Mar 10, 2008
  13. Zebee Johnstone
    G-S Guest
    Bloody Top Posters LOL
    G-S
    G-S, Mar 10, 2008
  14. Zebee Johnstone
    Nev.. Guest
    That's not necessarily true. If the vehicle was being driven in a
    manner which caused it to make excessive noise at the time that it was
    reported, then it is totally reasonable that you should be requested to
    have it tested. You would know that due to the way that noise testing
    is performed, it is absolutely possible for any vehicles which is
    excessively noisy under certain driving conditions to pass the noise
    tests.
    Nev..
    '07 XB12X
    Nev.., Mar 10, 2008
  15. Zebee Johnstone
    Snapper Guest
    Nev.. wrote...
    I was having a dig at you given that it's got a Harley donk in it..
  16. Zebee Johnstone
    Nev.. Guest
    Maybe you should just stick to copypasting work that other people have
    done and posting it to the MRA. :)
    Nev..
    '07 XB12X
    Nev.., Mar 10, 2008
  17. Zebee Johnstone
    Snapper Guest
    Nev.. wrote...
    No, but the road rules do cover noise and visible emissions.
  18. Zebee Johnstone
    Nev.. Guest
    Victorian road rule # 291 "Making unnecessary noise or smoke" is the
    only mention of noise or emissions in the Victorian Road Rules. That
    has nothing to do with EPA noise regulations, or with the reporting or
    testing of noisy vehicles. It appears to be neither outdated nor
    inappropriate nor "draconian". The example given for the application of
    the rule deals with a vehicle doing a burnout.
    Nev..
    '07 XB12X
    Nev.., Mar 11, 2008
  19. Zebee Johnstone
    Snapper Guest
    Nev.. wrote...
    Maybe. Except that I didn't "copypaste" it. I forwarded Zebee's message by
    email to the board.
    Snapper, Mar 11, 2008
  20. Zebee Johnstone
    Snapper Guest
    Nev.. wrote...
    I was wondering how long it was gonna take you to dig that one out. Not
    long at all, it seemed. What, you bored at work or something?
