Now that's bloody odd...
Discussion in 'UK Motorcycles' started by Nigel Eaton, Sep 27, 2003.
  1. Nigel Eaton
    Nigel Eaton Guest
    A quick inspection of the rear tyre on the ZZR today revealed a bit of a
    lack in the tread department. So off to my good friends at Colin Collins
    I trot and a new 020 is fitted.
    "Your rear brake pads are fucked" they say, which I thought was odd,
    'cos I did them not too long ago. Anyway, new set of pads is bought and
    a new set of seals to go with it, since they're well overdue.
    I removed the rear caliper and noted that one of the pads was worn much
    more than t'other.
    When I split the caliper I found that the 'insert' bit for the piston on
    the less worn side was missing...
    Now, I *must* have done that when I last played with the rear brake. But
    I'm fucked if I can figure out how I missed it out and where the
    bastard's gone.
    *Sigh*
    Looks like I'm going to have to order a new one. I *really* hope they'll
    supply it as a separate part.
    Nigel
    WS* GHPOTHUF#24 APOSTLE#14 DLC#1 COFF#20
    ZZR1100 and Enfield 500 Curry House Racer "The Basmati Rice Burner" (No , I'm
    not sure how that happened either).
