Now Serving Nitrogen At SuperTireGuy
Discussion in 'Bay Area Bikers' started by Supertireguy, Feb 19, 2005.
  1. Supertireguy
    Supertireguy Guest
    Lots of advantages to inflating your moto tires with nitrogen gas.
    http://www.mtdealer.com/t_inside.cfm?action=art_det&storyID=1207
    Using nitrogen instead of compressed air has distinct advantages, which lead
    to immediate benefits for the vehicle owner.
    1. It has more mass, so it migrates through the tire three to four times
    slower. The result: Tires hold their psi longer.
    2. It runs about 20% cooler. Less heat results in less tire degradation.
    3. Less tire pressure increase as the tire heats up.
    4. It drastically reduces oxidation on the rim and inner-liner (nitrogen
    systems almost totally eliminate oxygen -- the cause of oxidation -- from
    the mix).
    5. Another important factor in using nitrogen gas for tires is that
    compressed nitrogen has virtually no moisture content.
    Ever notice how much moisture comes out of a typical compressed air hose?
    Lots. Ever drain your compressor tank and see the goop that comes out? Yuk.
    If I need to fill my tires, auto or moto, and don't have a nitrogen source
    available then ok, regular compressed air will be suffice. But when given a
    choice nitrogen is clearly the better option.
    Discount Motorcycle Tires & Service In Downtown San Francisco
    http://supertireguy.com
  2. Supertireguy
    JB Guest
    WTF? The molecular weight of pure N2 is ~28 grams per mole. O2 (which
    is 20% of the atm) is 32 gm/mole
    I'd say that the mass per mole of air is higher than that of N2
    How so?
    So Nitrogen has its very own gas law instead of the ol' PV = nRT
    I'll grant you this .. but since the outside of the tire (the one which
    suffers the most wear and tear) is
    exopsed to an oxygen rich atmosphere - does this really matter?
    OK. But since I ride through puddles of water, is keeping the inside of
    my tires dry that important?
    JB, Feb 24, 2005
  3. Supertireguy
    Supertireguy Guest
    Just following progress in the tire biz and this Nitrogen inflation option
    offers benefits without any drawbacks. If the reasons for using Nitrogen
    don't make sense to you that's ok, just use regular compressed air and check
    your pressures on a regular basis.
    Why Use Nitrogen?
    Nitrogen is a dry, inert gas used to inflate airplane tires, off-road truck
    tires, military vehicle tires, and race car tires for improved performance.
    Oxygen in compressed air permeates through the wall of the tire, thus
    reducing the tire's inflation pressure. During its journey through the tire
    wall, oxygen oxidizes the rubber compounds in the tire, causing
    under-inflation and deterioration of the rubber. Dry nitrogen will maintain
    proper inflation pressure and will prevent auto-ignition, will not corrode
    rims, and will help the tire to run cooler.
    Improved Tire Life: Nitrogen will help to extend tire life by reducing
    premature failure of the
    tire. The causes of premature tire failure which are affected by nitrogen
    include: Rubber deterioration by oxidation, Rim corrosion, Under-inflation,
    Overheating, Pressure increase due to heat build up, Uneven wear due to
    improper inflation.
    Supertireguy, Feb 24, 2005
  4. Nitrogen is not inert -- its oxides are a major preoccupation of the
    CARB. As to dry, neither nitrogen nor oxygen are wet -- the question
    (to which I don't know the answer) is whether a pure nitrogen atmosphere
    would hold water vapor better or worse than the nitrogen-oxygen one we
    ordinarily breathe.
    As to benefits without drawbacks, that would assume a zero cost of
    extracting oxygen from the atmosphere. Not likely.
    I don't know enough to say for sure that you're wrong, but what little I
    know seems to suggest that nitrogen in your tires may be the 21st
    century equivalent of St. Christopher on your dashboard.
    Rich, Urban Biker
    Rich, Urban Biker, Feb 25, 2005
  5. Supertireguy
    jim stinnett Guest
    When you could use Helium.
    Bike's weight is lowered due to lighter than air gas in tires, enhancing
    acceleration to various locations where bikers can gather and talk
    like chipmunks.
    Sounds like a better deal to me.
    Jim Stinnett
    R1100RS
    VTR1000
    YZF R1
    http://moto-rama.com
    jim stinnett, Feb 25, 2005
  6. Nitrogen is not inert -- it is colorless, odorless, and non-flammable --
    but not inert.
    Reference please. I'm skeptical about there being a significant difference
    between O2 and N2 tunneling through the various synthetic rubbers used
    in tubeless tires.
    Michael Sierchio, Feb 25, 2005
  7. How many surrealists does it take to fill a motorcycle's tires?
    Two -- one to operate the valve on the Helium tank, the other
    to hold the giraffe.
  8. Supertireguy
    Alan Moore Guest
    Actually, nitrogen is, by a slight margin, the smaller of the two
    molecules and can be expected to sneak out slightly faster than
    Oxygen. Jim Stinnett's suggestion of helium is not to be considered --
    it leaks out very fast indeed.
    Nitrogen is fairly inert, but I've never heard of a tire lasting long
    enough for oxidation of the interior surfaces to have any effect
    anyway.
    Al Moore
    DoD 734
    Alan Moore, Feb 25, 2005
  9. Supertireguy
    cstatman Guest
    Well, it IS what all the Moto-GP guys run. Why? apparently it does not
    change much pressure at high temp. so if you like a 32 rear on the
    track, its supposed to stay 32 the whole time. warm up lap, full tilt
    boogie on the straights, and cooling down.
    However, for the average rider, on the street, plain old air works
    great.
    I really like the St. Christopher analogy.
    If you FEEL spending extra pennies helps, knowck yourself out. While
    you are at it, send me $3, and I will say a special biker prayer for
    you every night for 2 months.
    :p
    Assuring you of my best intentions at all times,
    Charles Statman
    Rocket Scientist/Wonderboy/Women's Legs Shaven
    DoD the Un-Numbered One
    cstatman, Feb 25, 2005
  10. Supertireguy
    bob prohaska Guest
    Numbers, dammit, we need numbers! :cool:
    Alas, I don't have any.
    It _is_ true that the techniques used to make industrial nitrogen tend
    to be relatively good at excluding water and oil, neither of which is
    helpful in a tire. But diffusion rates and heat generation? I don't think
    those depend enough on gas composition to matter. Rubber gaskets seal
    helium well enough for practical purposes, tires can't be much different.
    Leaks are usually a bigger issue than diffusion through polymers.
    A badly maintained air compressor can deliver visible water and oil with
    the air, which surely will be avoided by using nitrogen, even if it's of
    only commercial grade. For somebody at a racetrack a cylinder of nitrogen
    might be a better choice than an unknown compressor and not much more
    expensive.
    Personally, I wouldn't _pay_ to put nitrogen in my tires. If I were in a
    jam, and had a choice between a cylinder of industrial nitrogen and a
    compressor with wet or oily air coming out, the bottled gas would be
    worth considering.
    bob prohaska
    bob prohaska, Feb 25, 2005
  11. Nitrogen is a gas, and all gasses pretty much behave the same
    with respect to pressure and temperature. Nitrogen is no different
    from air in the respect.
  12. Supertireguy
    muddycat Guest
    Air is 78% nitrogen anyway.
    muddycat, Feb 25, 2005
  13. A+ !
    HardWorkingDog, Feb 25, 2005
  14. If that's really true, then you'd need to use a higher pressure in your
    tires to start with, instead of what you're used to setting them at for
    the track. The pressures the tire vendors normally recommend for the
    track are based on the idea that once the tires and (consequently the
    air inside them) have heated up they will _then_ be at optimal pressure
    for the track.
    Denise Howard, Feb 25, 2005
  15. Supertireguy
    JB Guest
    Hear hear!
    JB, Feb 26, 2005
  16. Supertireguy
    cstatman Guest
    yay Denise!
    correct. the vendors make suggestions at the track.
    using nitrogen on the street is just like the squidlets burning race gas
    and having bikes covered in sponsor stickers.
    we need to sell them power bands, muffler bearings, and helmet grease.
    Charles Statman
    EMAIL: cstatman @ yahoo.com
    BLOGGER: http://cstatman.blogspot.com/
    WEB PAGE: http://home.comcast.net/~cstatman/
    cstatman, Feb 26, 2005
  17. Here?
    But the deal with nitrogen vs. air is that air contains water vapor
    and nitrogen does not. Water vapor can condense out of air at lower
    temperatures under pressure. Then the tyre heats up, and vaporizes the
    condensed water, and... more pressure!
    I had to drain the water out of my commercial air compressor at least
    once a day whilst operating it (sandblasting auto body parts) because
    water condensed out under pressure. I also had a drier loop on the
    output to cool the air coming out of the compressor and then collect
    the remaining water because otherwise my sandblaster nozzle would
    occasionally spit water.
    This is not of particular concern at the pressures that motorcycle
    tyres operate, of course, unless you must regulate pressure within the
    millibar in order to get the exact handling that you wish to get the
    millisecond of advantage over a competitor on the race track. And it
    is more of concern if you are in a swamp like Louisiana or Florida
    where the ambient air contains enough water vapor that you can give
    yourself a sponge bath by simply swatting your sponge at the air then
    sponge yourself off with the now-wet sponge. (Okay, I exaggerate, but
    only barely). But there is a reason other than fad that racers use
    nitrogen to inflate their tyres -- it insures that they have no
    condensate-caused issues.
    - Elron
    L. Ron Waddle, Feb 26, 2005
  18. Supertireguy
    glabber Guest
    And of course they'll need the nitrogen tire-pressure gauges.
    They look just like ordinary gauges, but they're much more expensive:
    That's how you know they're for nitrogen.
    glabber, Feb 26, 2005
  19. Sounds like the problem is water vapor, not oxygen, in the tires
    (tyres?). I would expect there are cheaper ways to remove the water
    vapor from the air than to remove the oxygen -- perhaps a quicklime or
    silica gel cartridge on the intake of your compressor?
    Rich, Urban Biker
    Rich, Urban Biker, Feb 26, 2005
  20. Supertireguy
    Andy Burnett Guest
    A compressor sucks in much more air than a desiccant pack could dry on the
    intake. The usual approach is to place a dryer on the line on the tank
    output; the previous poster also had a dryer loop between the compressor
    head discharge and the tank. As air pressure decreases, water precipitates
    out. Simple line dryers have an impeller in a polycarbonate jar that spins
    and helps to flick the precipitation against the sides of the jar. This by
    itself does a reasonable job of getting water out of the air. It's not as
    dry as commercial grade bottled nitrogen, but it's certainly good enough
    for tires...
    ab
    Andy Burnett, Feb 26, 2005
