Note to self...
Discussion in 'UK Motorcycles' started by Dan White, Feb 9, 2004.
  1. Dan White
    Dan White Guest
    When living with three neurotic cats, do *not* use the Microsoft office
    "links the Cat" as your assistant. Particularly not with a cat on your lap
    and one at your feet. *Especially* not if you want your legs intact when the
    sodding thing meows at you.
    <Goes off to find some antiseptic...>
  2. Dan White
    Ginge Guest
    Anyone that leaves the microsoft office assistant enabled doesn't
    deserve legs.
    Ginge, Feb 9, 2004
  3. Dan White
    Dan White Guest
  4. Dan White
    Ginge Guest
    Uninstall it.
    With the installer.
    It won't come back then.
    Ginge, Feb 9, 2004
  5. Dan White
    Dan White Guest
    Can I do that and still keep the help files? I'm trying a few things out in
    Excel and it's handy to refer to syntax occasionally.
  6. Dan White
    Ginge Guest
    Yes.
    I think it's under
    "Shared components" "Office assistant"
    Check the never install option for just that component and job's a good
    un.
    Ginge, Feb 9, 2004
  7. In uk.rec.motorcycles, Dan White said:
    Why not copy the help files to another location before you uninstall?
    I know bugger all about spreadsheets it has to be said *and* I'm pissed
    but copying the files is what I'd try first :)
    Whinging Courier, Feb 9, 2004
  8. Dan White
    Dan White Guest
    Because knowing Microsoft, they'll probably be in 165 different locations,
    buried 12 directory levels down.
  9. Dan White
    Slider Guest
    Slider, Feb 9, 2004
  10. In uk.rec.motorcycles, Dan White said:
    Oh, so you can't be arsed to look for them then ;-)
    Blimey, sometimes I get so piss bored that I deliberately **** something
    up just because it takes hours, if not days to fix it :)
  11. Dan White
    Dan White Guest
    I wish I had that kind of spare time!
  12. In uk.rec.motorcycles, Dan White said:
    lol
  13. Dan White
    but you don't - you have Office Assitant installed.
    darsy, Feb 11, 2004
