Note to self 1232
Discussion in 'UK Motorcycles' started by dwb, Mar 25, 2005.
  1. dwb
    dwb Guest
    When chasing after a Subura down a favourite B-road it pays to remember that
    one is no longer on a GSX-R and is instead on a barge-like motorcycle with
    rather different characteristics. *parp*
    Strangely (to me), the DL seems to require *more* skill (ie planning) to
    ride swiftly than the GSX-R did - it doesn't change direction anywhere as
    fast, nor does it steer quickly - and the suspension does make things
    interesting.
    But boy, when you get it right, it's just as fast as the GSX-R and a hoot to
    throw around. And it's pain-free.
    Overtakes are instant too - none of the 'wind up' time of the 600.
    Speed bumps are now highlights rather than irritations.
    dwb, Mar 25, 2005
  2. dwb
    dwb emerged from their own little world to say
    You need a different mindset on big traillies. It will steer more
    quickly if you reduce the amount you load the front wheel - you get a
    lot more fork dive than you are used to on the GSXR. Have you realised
    that it has a rear brake yet? Use it and you'll be able to reduce the
    fork dive. Having ABS[1] on the BM helps, especially into downhill
    bends, as it eliminates the possibility of locking the wheel. Although,
    on my TDM I found chirping the rear tyre became fun after a while :)
    [1] and the funny front end, but you still get a bit of dive
    wessie, Mar 25, 2005
  3. dwb
    dwb Guest
    Yes - though to be fair (and what I was saying to myself earlier) I've just
    come off 2.5 years and 15 000 miles on an in-line 4 600.... to having now
    done 250 miles on a 996 V-twin - of course it's going to be a bit
    interesting - managing to still poodle around at similar speeds is handy
    though. Much less time being spent >100mph though, which is good (IMO!).
    Yes, and also a shed load of engine braking - however as I mentioned the
    main thing is the planning - "in slow, out fast" applies much more to this
    bike than the previous one - experience will help me on this one - and to be
    honest, my road reading skills are rusty anyway which doesn't help.
    dwb, Mar 25, 2005
  4. dwb
    Give it time. You can see more for a start, so have more information to
    process. Once you get used to looking further ahead you'll find it is much
    easier to ride than a sports bike.
    On most road I can ride my GS faster than I ever rode my CBR600, especially
    on the B roads around Hay on Wye/Brecon where I was today.
  5. dwb
    Preston Kemp Guest
    Big trailies tend to be setup towards the stable rather than flickable
    end of the spectrum. Sliding the forks up through the yokes 20mm works
    wonders on Tigers - give it a go.
    It's quite important to set the sag up properly with squishy
    long-travel suspension, if you haven't done so. A lot of it's just
    getting used to the feeling though. It may well wallow around a bit on
    fast sweepers, but that's all just part of the fun.
    Preston Kemp, Mar 26, 2005
  6. dwb
    Stritchy Guest
    This is why it's much more fun to ride a non-sports bike fast.
    Almost any muppet can ride a sports bike fast - because that's what
    they are designed to do.
    Stritchy, Mar 26, 2005
  7. dwb
    dwb Guest
    Stupidity - HTH. :)
    dwb, Mar 26, 2005
  8. dwb
    Stritchy says...
    Really? When was the last time you tried to ride a proper sportsbike
    fast?
    Lozzo, Mar 26, 2005
  9. dwb
    Preston Kemp Guest
    I think you need to define "fast". To stick to the original context of
    the thread, I agree with Stritchy in that it's easier for any muppet to
    ride a sportsbike faster than a big trailie over a given stretch of
    road, assuming that road isn't pot-holed to buggery & riddled with
    ultra-tight hairpins. But that's just physics - more power, less
    weight, better brakes, fatter tyres, more lean clearance.
    However it's easier to ride a big trailie to *its* limits, because they
    do tend to be more forgiving at the limit, and those limits are fairly
    easily found, particularly with respect to lean angle.
    For example I can happily drag the pegs on the Tiger, safe in the
    knowledge it (probably) won't spit me off if I hit a bump or wind open
    the throttle whilst at a daft angle-of-dangle. However dragging the
    pegs on the MV requires a far greater lean angle, especially as it
    hasn't got any hero blobs. And I know from experience that if I touch
    the throttle while the pegs are down, the back will step out, & I'll
    shit myself.
    So if "fast" means the time taken for a given stretch of road compared
    to a trailie, the sportsbike wins, and any muppet probably could ride
    fast. If "fast" means close to the bike's limits, any muppet could
    possibly do that on a big trailie, but not on a sportsbike imho.
  10. dwb
    Stritchy Guest
    E/BOSM (can't remember which) a few years back on a Gixxer. It scared
    the crap outa me, because I was't used to the power delivery, riding
    position it's capabilities.
  11. dwb
    Stritchy says...
    So basically you're saying that a sportsbike isn't easy to ride fast,
    which contradicts your earlier statement.
    Lozzo, Mar 26, 2005
  12. dwb
    Stritchy Guest
    But there's a big difference between riding fast and riding well.
    I'm referring to muppets who ride fast down the straights and toddle
    round corners, can't overtake or anticipate the road ahead.
    The big sports bike, matching leathers and sparkly helmet makes them
    feel like riding gods but they can't ride for toffee. Thankfully there
    are lots of them on the road for the likes of Tuppy and I to
    humiliate. :eek:)
  13. dwb
    Stritchy Guest
    No, I'm not saying that at all.
    It scared me because it was so easy to go soooo very fast. It was well
    planted on the road and went round corners far faster than I was used
    to.
  14. dwb
    Stritchy Guest
    I never said I was any good! ;o)
    <hissssssss>
  15. dwb
    Monz Guest
    Don't forget the TL mate... on second thoughts maybe it's best.
    Monz, Mar 26, 2005
  16. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    *Waves*
    Wicked Uncle Nigel, Mar 26, 2005
