Notchy Front Brake
Discussion in 'Australian Motorcycles' started by Aaron, Jun 9, 2004.
  1. Aaron
    Nev.. Guest
    Dry powder fire extinguishers?
    Nev..
    '03 ZX12R
    Nev.., Jun 18, 2004
  2. Aaron
    R1100Smee Guest
    I think they are under compressed air not in aerosol format.
    (Maybe wrong here)
    R1100Smee, Jun 18, 2004
  3. Aaron
    Johnnie5 Guest
    sikolene do a graphite 'penetrating' spray , maybe good for booth work ;)
    perfect for cable lubeing , think there is even a picture of a luber on the
    can
    bout $10-$15 , can i have still has maybe 10% left in it after 3-4 years
    Johnnie5, Jun 19, 2004
  4. Look up what an aerosol is......
    Hammo
    Hamish Alker-Jones, Jun 19, 2004
  5. Aaron
    R1100Smee Guest
    which part of "maybe wrong here" did you not understand?
    R1100Smee, Jun 19, 2004
  6. Aaron
    Nev.. Guest
    Are aeroplanes powered by compressed air too?
    Nev..
    '03 ZX12R
    Nev.., Jun 19, 2004
  7. Aaron
    R1100Smee Guest
    They are powered by jet fuel
    but in all technicality isn't the air sucked in by the jet shot out the
    back in a sense being compressed?
    R1100Smee, Jun 20, 2004
  8. Aaron
    Mark Hammond Guest
    I know you fixed it, but this topic came up on another list I am on. My
    ST4s has "semi-floating" disks, and someone reported a shudder
    that sounded alot like warped disks. Then someone came in with this
    advice (in response to someone else suggesting certain pads will cause it):
    I have experienced this problem on more than one Ducati, with a variety
    of brake pads. Converting the rotors from semi-float to full-float has
    been the most effective cure. I believe the problem is that brake dust
    and other dirt becomes impacted in the rivet that holds the rotor to the
    carrier in an uneven pattern causing the rotors to be slightly warped.
    By taking a rubber mallet and or even a solid hammer and squarely
    hitting each of the rivets you will likely find that each give a bit
    allowing the rotor to re-float evenly. Generously spray brake cleaner
    before and after the beating and grasp the rotor and wiggle it. It
    should move slight and evenly around the circumference. Do this on a
    regular basis and you will rid your self of most of this
    pulsing/shuddering. Converting to full-floating rotors elimnates the
    need to re-clean regularly and provides other benefits as well.
    That was certainly something I didn't know. Upon closer inspection of
    my front disks, I do indeed find that the rivets (that don't look much
    like rivets!) are indeed not fixed, and have a little play or movement
    in them.
    Can anyone summarise quickly the difference between semi and fully
    floating rotors? I have always had fixed rotors before (and indeed
    still do on the rear). Now I see the "rivets" do indeed move, I'm not
    at all sure what is holding the disk on :)
    Thanks,
    Mark.
    Mark Hammond, Jun 20, 2004
  9. Aaron
    Nev.. Guest
    which part of the propellor is the jet, and how does it compress the air?
    Nev..
    '03 ZX12R
    Nev.., Jun 20, 2004
  10. Aaron
    John Guest
    John, Jun 20, 2004
  11. Which part of look up what an aerosol is, did you not understand?
    Should I use "harsh week" everytime, or is there something that is really
    getting up your nose?
    Hammo
    Hamish Alker-Jones, Jun 20, 2004
  12. Provided they aren't looking for deodorant.
    Hammo
  13. Aaron
    Nev.. Guest
    Nev.., Jun 20, 2004
  14. Aaron
    smack Guest
    It's that thing you put in your helmet before you ride
    smack, Jun 20, 2004
  15. Aaron
    R1100Smee Guest
    Nev.. wrote:
    an aeroplane flies
    it is mostly powered by either a jet rocket or propellor
    when I think of planes I automatically think of jet engines.
  16. Aaron
    R1100Smee Guest
    He wears it on his cap
  17. Aaron
    Gary Woodman Guest
    I have a soft plastic bottle at home with powdered graphite, it's a
    squeeze pack with a sort of nozzle tip. I've seen similar in locksmiths.
    I got mine in Darwin at least 15 years ago; graphite goes a looong way...
    Which bike shop?
    Gary (probably closed now :)
    Wealth without Work
    Pleasure without Conscience
    Science without Humanity
    Knowledge without Character
    Politics without Principle
    Commerce without Morality
    Worship without Sacrifice
    The Seven Deadly Sins of M.K. Gandhi
    Gary Woodman, Jun 21, 2004
  18. Aaron
    conehead Guest
    ....if you squeeze it hard enough
    conehead, Jun 21, 2004
