Notchy Front Brake
Discussion in 'Australian Motorcycles' started by Aaron, Jun 9, 2004.
  1. Aaron
    Aaron Guest
    Evening all. Seems my bike has developed a small issue. When pulling in the front brake it isn't
    smooth like it should be but feels a bit 'notchy'. I can't really describe it any other way... The
    lever seems to jump in little bits at a time. Makes stopping in a hurry kinda interesting...
    Does anyone have any (useful) suggestions of things I should look at?
    Thanks
    Aaron
    '02 ZX6R
    Aaron, Jun 9, 2004
  2. Aaron
    smack Guest
    warped disk
    smack, Jun 9, 2004
  3. In aus.motorcycles on Wed, 09 Jun 2004 20:13:12 +1000
    Try greasing your brake lever pivot, and make sure that everything is
    straight and moves freely and isn't binding.
    Another possiblity is a problem with the master cylinder seal, although
    that's not all that likely.
    Zebee
    Zebee Johnstone, Jun 9, 2004
  4. Aaron
    Wocka Guest
    Gidday,
    I had the same thing when I bought the CBR600 second hand.
    SCM Lane Cove told me it was the front disks warped. $350 we'll take em off,
    send em to Melbourne and be back in a week.
    Took the bike to Freedom M/C in Brookvale, It's your chain, dead dry. It has
    a tight spot in it.
    He lubed it for free, got a little better, but still not good.
    I went back to Brookvale and had a new chain fitted. $160. Problem fixed.
    I could only feel the jerky braking on the front brake not the rear, and
    only at slower speeds. Like pulling up the lights.
    Wocka, Jun 9, 2004
  5. Aaron
    Aaron Guest
    I should mention it also happens when pulling the lever in when the bike is stopped. I can't imagine
    it is warped disks or a dodgy chain. :)
    Gunna check it's all straight (should be, hasn't been dropped) and chuck a bit of lube around and
    hope for the best. Worst case there is a service mob who have moved in right behind work, might see
    how good they are...
    BTW bike is a late '02 with about 13k on the clock.
    Aaron
    ZX6R
    Aaron, Jun 9, 2004
  6. Aaron
    Nev.. Guest
    Well there's your problem... probably seized up from lack of use.
    Nev..
    '03 ZX12R
    Nev.., Jun 9, 2004
  7. Aaron
    JustAL Guest
    Well Nev, not everyone requests the factory option 17 digit odometer when
    they order their bikes.
    JustAL, Jun 10, 2004
  8. Aaron
    Aaron Guest
    Fixdit.
    A bit o lube on the lever pivot and she's just like new again. Zebee strikes again.
    It might be an idea for me to go over the bike and lube any bits that require lubing. What do people
    suggest for a general purpose lube (aside from KY)?
    Aaron
    ZX6R
    Aaron, Jun 10, 2004
  9. Aaron
    Aaron, I wasn't going to mention it because our bikes are so totally
    different but I had EXACTLY this same problem on my XJ.
    It got quite dangerous sometimes as the suspension's so soft on the Yam
    that it would really upset the attitude of the bike if you crossed that
    "notch" while easing on the brakes while changing direction.
    I tried greasing the pivots etc. but I think there was something in the
    bore of the master cylinder causing the problem.
    It would go away for a while if I bled the crap out of the system or left
    it overnight with the lever tied in to the grip but it always came back.
    I put in new pads and I even put new cups and seals into the
    master-cylinder but all fixes were only ever temporary.
    My eventual fix (so far still holding) was to get braided steel lines.
    Now the braking system is so stiff that the lever never gets in far enough
    to encounter the "notch". (But my old lines were 18yo and would visibly
    swell when you squeezed them [like most 18yos I know...] so I was happy to
    change the lines anyway and the "fix" was just a bonus).
    I think I need a new master-cylinder or, at the least, the old one honed.
    Clem
    Knobdoodle, Jun 10, 2004
  10. Aaron
    I just wrote a whole epistle about how it wasn't the lever pivot!
    Clem
  11. Don't you just hate it when that happens? :)
    Cheers
    PeterC [aka MildThing]
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
    Peter Cremasco, Jun 10, 2004
  12. Aaron
    conehead Guest
    Heh. This is getting to be a habit, Clem.
    conehead, Jun 10, 2004
  13. In aus.motorcycles on Thu, 10 Jun 2004 18:24:59 +1000
    Depends....
    For things like cable nipples I use moly grease, because I had to buy a
    tub of it for something years ago, and you don't go through that stuff
    very quickly!
    I also have a can of graphite spray which I use on things I can't get
    the grease to, or for cables.
    I don't use WD40, it's not a lube it's a water displacer.
    Zebee
    Zebee Johnstone, Jun 10, 2004
  14. *THREE!* ah ah ah, *THREE MISTAKES ON USENET!*
    big (I _love_ to count...)
    Iain Chalmers, Jun 11, 2004
  15. Aaron
    Aaron Guest
    How about chain lube? I have tins of the stuff.
    Aaron
    ZX6R
    Aaron, Jun 12, 2004
  16. In aus.motorcycles on Sat, 12 Jun 2004 10:06:32 +1000
    I don't, so have no idea!
    I think it's probably too runny to stick around, so not much use for
    cable nipples and lever pivots, but probably fine for lubing cables.
    Zebee
    Zebee Johnstone, Jun 12, 2004
  17. Aaron
    R1100Smee Guest
    WD40 is also a lube albeit a light one but still lubicates.
    R1100Smee, Jun 12, 2004
  18. Aaron
    Rusty Guest
    That's what I use on the lever pivots. Works well. Also works well in
    the bonnet catch of the Fairlane, but that's another story ...
    Rusty
    Rusty, Jun 13, 2004
  19. Aaron
    Gary Woodman Guest
    Interesting. Is that liquid, or powder?
    Gary
    Wealth without Work
    Pleasure without Conscience
    Science without Humanity
    Knowledge without Character
    Politics without Principle
    Commerce without Morality
    Worship without Sacrifice
    The Seven Deadly Sins of M.K. Gandhi
    Gary Woodman, Jun 18, 2004
  20. In aus.motorcycles on 18 Jun 2004 19:55:37 +1000
    Aerosol, liquid. (I dunno you have have a powder spray)
    Got it years ago at a bike shop, never seen another can.
    Zebee
    Zebee Johnstone, Jun 18, 2004
