Not quite cutting edge GPS, but darn good deal (I think)
Discussion in 'UK Motorcycles' started by dwb, Apr 27, 2006.
  1. dwb
    dwb Guest
    http://www.gpsw.co.uk/details/prod3167.html
    Refurb'd Street Pilot III GPS with power cable, motorcycle mount, car
    mount and City Navigator software along with some other stuff.
    £150.
    That's quite a good deal I think.
    dwb, Apr 27, 2006
  2. dwb
    SteveH Guest
    I'd entered all my card details, then was *just* about to click to buy
    it, when I realised that, although it's a cracking unit, the mapping is
    out of date and 128mb isn't really enough memory for a Garmin unit -
    you'd have to selectively pick the detailed maps you want to download.
    (Not to mention the criminal cost of Garmin data cards).
    I think I'll stick with TomTom and spend my money on a decent case and
    mounting kit for my PDA.
    SteveH, Apr 27, 2006
  3. dwb
    Gyp Guest
    Proper GPS, sensible money.
    Gyp, Apr 27, 2006
  4. dwb
    SteveH scribbled on the back of a napkin:
    AFAIK (these things have been discussed on ukgser recently) these are
    refurbished units. No idea if the usual Garmin customer service of
    'latest maps for free the first time round' applies to these but it may
    well. Even then the yearly Garmin tax isn't exactly excessive...
    A quick google suggests that 128MB is the max size card this can take,
    plus it seems to receive the mapping data by *shudder* a serial cable.
    ISTR that you can get 2610s for 300-something quid somewhere and they
    are the far better unit. Plus they take bog-standard CF cards for map
    storage. Still takes ages to download the map data (this time via USB)
    but hey...
    Timo Geusch, Apr 27, 2006
  5. dwb
    Gyp Guest
    Good point, I'd forgotten the cost of Garmin memory cards. £140 for 256
    megs is a touch pricey...
    Gyp, Apr 27, 2006
  6. dwb
    SteveH Guest
    Surely if it's a standard card they can be written to using a USB2 card
    reader?
  7. dwb
    Gyp Guest
    My Garmin has led me down roads that really needed a 4x4 four times.
    Once just down the road on the outskirts of Cheltenham, twice in one
    journey in Nottinghamshire and only once in France, and with the one in
    France was where a road had been recently closed off.
    Without it, I've been lost a lot more than 4 times!
    Gyp, Apr 27, 2006
  8. dwb
    Gyp Guest
    No.
    You need mapsource to build a map for your GPS, which mapsource does
    once the GPS is connected via the USB cable, then it downloads it.
    It would be great to do it via a USB2 reader, but there's nothing wrong
    with wandering downstairs to get a coffee while it downloads is there?
    I've got a 1Gb card with all of the UK and most of France and Spain on
    so I don't have to go for coffee very often
    Gyp, Apr 27, 2006
  9. dwb
    Greybeard Guest
    I have an SP3. Had it for >4 years and Very happy.
    You can program the maps into the datacard, which incidentally, comes in
    various sizes up to 256 Mb, through the USB cradle that comes with the
    beast. Routes, waypoints etc does have to be sent via the serial port to the
    unit. Maps are only stored on the datacard.
    This unit IS waterproof, and great on the bike. It _eats_ batteries, so make
    sure you set up a 12v supply for it!.
    If there is any questions I can answer for you then drop me a line or post
    here.
    HATH.
    Greybeard
    FLHRCI -01 UK ( 95 cu-in Stag 2. Big Boy!)
    Trumpet Trophy 1200 -96, (The Barge) for rainy days
    ukrm@foxtails[dot]co[dot]uk
    *** Posted via a free Usenet account from http://www.teranews.com ***
    Greybeard, Apr 27, 2006
  10. dwb
    dwb Guest
    Heh - I've had a GPS since 2001 - still have it in fact - early model
    grayscale E-Trex Vista. No routing, serial connection, low memory.
    Still works though.
    Simian can relate a tale of the day we came back from Snetterton via
    some gravel strewn tracks thanks to the GPS - him on a 7R ,me on the
    GSX-R.
    dwb, Apr 27, 2006
  11. dwb
    Greybeard Guest
    Have a squint on ebay. I got mine for less than 60 squid!
    128 covers a good junk of southern England, with fantastic POI info.
    Greybeard
    FLHRCI -01 UK ( 95 cu-in Stg 2. Big Boy!)
  12. dwb
    SteveH Guest
    Not much use if you're planning on using it abroad, though. I was very
    tempted 'cos we're doing a long trip to Spain and Portugal in October -
    but the Garmin just couldn't hold enough map data to make it worth
    having over a PDA with TomTom.
  13. dwb
    FooBar Guest
    (SteveH) wrote in :
    Unfortunately there's absolutely nothing standard about Garmin's
    (insanely expensive) memorycards and they will fit nothing but Garmin-
    products.
    The only possible way of transporting data is therefore the dreaded
    serial connection and (owning an ancient eMap) I can confirm that it is
    indeed *VERY* slow!
    GPS-Warehouse does have a USB-cable that for power/data, but this is just
    a convenient way of connecting (and charging at the same time!) a slow
    serial device (which the navigator of course still is!) to a modern
    computer, some of which are without the classic serial connector...
    /claus (who just bought a Garmin Quest and is absolutely thrilled)
    FooBar, Apr 27, 2006
  14. dwb
    FooBar Guest
    (SteveH) wrote in :
    Ooops! Didn't see the "USB Data Card Programmer" - which presumably will
    speed things up considerably..!? :-/
    /claus
  15. dwb
    SteveH Guest
    Aye, I've had an eMap for years. Still gets a fair bit of use as some of
    the mapping detail is superb, *if* you plan in advance where you're
    going.
  16. dwb
    Paging Big Tony.
    platypus, Apr 27, 2006
  17. dwb
    Gyp Guest
    Are you out of work at the moment?
    Gyp, Apr 27, 2006
  18. dwb
    Mark Guest
    I've had both the SP3 and the 2610 and this sort of thing can happen. By the recent newspaper articles it seems it can affect all GPS units.
    When I had the SP3 I thought it was the dogs danglies but the speed of redrawing alone makes the 2610 worthwhile. When on the bike, invariably at higher average speeds, the SP3 can have trouble recalculating if the new turnoff is close to the one you have missed (you miss the turnoff as the unit hasn't calculated the error quick enough).
    I know you can slow down BUT you need to realise that sometimes you can be going straight ahead on a road that the GPS has told you to go down and then it may tell you that you are of route. At these times the 2610 is streets ahead (excuse the pun).
    Of course the other big difference is the touch screen which can be operated with gloves on............
    Considering the OP's post I suppose it's a question of whether you can accept the lower speeds and no touch screen but probably save £200 on price.
    Mark
    Mark, Apr 28, 2006
  19. dwb
    dwb Guest
    It's not the GPS. It's the maps.
    There are only a limited number of suppliers of mapping information
    (and some of them buy from each other :) ) so an error somewhere is
    likely to appear on almost every GPS unit.
    dwb, Apr 28, 2006
  20. dwb
    dwb Guest
    Well my E-Trex Vista has less than 128, also uses the serial cable and
    is perfectly usable - it just takes a bit longer to do, but isn't
    exactly tough.
    £300 is still 2x £150 and you wouldn't get the the other stuff.
    I'm not saying you SHOULD buy it, but that unit was cutting edge only a
    few years ago and for that price I think it's still a good buy - 128mb,
    serial and all.
    The only reason I'm not buying one is that I need the £150 for
    something else and I already have a Vista :)
    dwb, Apr 28, 2006
