not many words required
Discussion in 'UK Motorcycles' started by Simon Wilson, Apr 28, 2011.
  1. Simon Wilson
    Simon Wilson Guest
  2. Simon Wilson
    Simon Wilson Guest
    It may end up being so. Not sure how 'spensive they are.
    As someone else suggested (can't find the post right now, sorry) - I
    drilled it and tapped it with two 8mm holes and used a piece of 1/4" or
    so plate across the shaft. An M14 or so bolt in the middle. I did it up
    *really* tight and there was no sign of it moving. Kept turning and the
    plate bent. Tried again and one of the M8 threads stripped. I may try
    again with one of those nice thick plates that I now have.
    Ta. Angle grinder may well end up being the answer.
  3. Theres not a pin or key in the shaft is there , i had a similar
    problem on an old circular saw shaft , only found out after i cut the
    pully off
    steve robinson, Apr 28, 2011
  4. Simon Wilson
    Simon Wilson Guest
    Just a woodruff key. It's not that long (maybe 18 months) since I had it
    all apart, so I really don't know why it's stuck so fast.
  5. PipL alter ego, Apr 28, 2011
