Not a good day
Discussion in 'UK Motorcycles' started by Lozzo, Apr 22, 2004.
  1. Lozzo
    Ben Guest
    Harsh. Condolences mate.
    Ben, Apr 23, 2004
  2. Lozzo
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Ginge
    They can't find anyone who'll volunteer to get close enough to tell you?
    Nigel Eaton, Apr 23, 2004
  3. Lozzo
    Ginge Guest
    Sensible lot.
    Ginge, Apr 23, 2004
  4. Lozzo
    Eddie Guest
    Real men don't eat... oh, it's you. Well, that explains that, then.
    I tried to save a whale once, but I couldn't find a jar big enough to
    pickle it in.
    Eddie, Apr 23, 2004
  5. Do you program in Pascal as well?
    William Grainger, Apr 23, 2004
  6. I think you mean
    Uses crt;
    Begin
    clrscr();
    Writeln('**** off Grainger!');
    if Grainger := 'Fucked Off' then
    ShutDoor();
    else
    writeln('I told you to **** off!');
    end;
    end.
    but I could be wrong.
    Whilst we are here, does do (or anyone else) want
    a big box of manuals and disks for Borland's Object Orientated
    Pascal before I stick the lot on ebay?
  7. Lozzo
    AndrewR Guest
    No, I think you're more correct than I, but it has been a long long time
    since I programmed in Pascal.
    However, I made one mistake you didn't correct, but which I spotted after
    I'd posted ...
    The IF statement should use = rather :=, as the former is used for comparing
    values, whereas the latter is used for assigning values.
    Oh, you also corrected two mistakes that I didn't make ... neither the
    ShutDoor() nor the 2nd writeln need semi-colons after them, because they are
    not the end of the statement.
    If you think about it, the entire statement could be written as a single
    line, thus :
    If Grainger='Fucked Off' then ShutDoor() else Writeln('I told you to ****
    off!');
    So while it is good practice to use the semi-colons it is not neccessary.
    Hell no.
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1
    BotToS#5,SBS#25,IbW#34, TEAR#3 (and KotL), DS#5, COSOC#9, KotTFSTR#
    The speccy Geordie twat.
    AndrewR, Apr 23, 2004
  8. Lozzo
    HedgeHog Guest
    Indeed. I'm sorry to hear that mate. Sympathies to you and your mate from
    both of us.
    HedgeHog, Apr 24, 2004
  9. Lozzo
    Salad Dodger Guest
    Is that the correct plural?
    | ___ Salad Dodger
    |_\_____/_| ..64299../..15196.../..3157./.19406
    \|^|/ ANORAK#17
    '^' RBR-Visited:13 Pts: 250 Miles:1237
    Salad Dodger, Apr 24, 2004
  10. Lozzo
    Wik Guest
    Mallairrea?
    | Wik -UKRMHRC#10- 2003 R1150GSA -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12
    |# You don't believe me | "Experience is the worst teacher.
    |That the scenery | It always gives the test first
    |Could be a cold-blooded killer. | and the instruction afterward."
    ***** human response from wik at blueyonder dot co dot uk *****
    Wik, Apr 30, 2004
