Norway assault vehicle 95% ready...
Discussion in 'UK Motorcycles' started by stephen.packer, Jan 23, 2011.
  1. stephen.packer
    SIRPip Guest
    It deep ends (hah!) how much ground clearance the plate actually costs,
    Shirley. I'd rather drag a plate along the deck than frame, or exhaust
    headers, or other fragile bits. If the thing is standing off by a
    couple of inches, otoh, I'd lose it - or the standoffs.
    I'd go along with this, though. I can't see a problem with leaving it
    on for civilisation, but being prepared to remove it when conditions
    suggest it (ie before they dictate it).
    SIRPip, Jan 24, 2011
  2. stephen.packer
    SIRPip Guest
    Titanium these days, old boy.
    The Russians, of course, use oak.
  3. stephen.packer
    SIRPip Guest
    I thought you were hitting the trackless wastes, North of the Arctic
    Circle. It was the width of Steve's panniers that struck me really:
    whereas you lads riding stuff that's narrower than a Nissan Micra might
    be OK, even when the soft snow is coming up over your feet on the pegs,
    he's going to be dragging those things through the snow. Perhaps.
    Dragging them both might even be OK, but if one was to hit and drag,
    that's an off waiting to happen.
    By your description of snow clogging around the motor with a potential
    for overheating with thin oils, I'd assumed you'd be in snow of spindle
    depth or greater.
  4. stephen.packer
    mark Guest
    I don't think we've got time to check out any bikes on Ebay Nige....
    mark, Jan 24, 2011
  5. stephen.packer
    Thomas Guest
    I've been as far north as Bodo (sorry, I cba to find the right
    character map,) and there are some looong stretches between
    civilization when you get north of Trondheim. A "couple of hours" may
    be a bit optimistic.
    Thomas, Jan 24, 2011
  6. stephen.packer
    SIRPip Guest
    They move even fewer than telegraph poles, you know.
  7. stephen.packer
    We're going a long way north of the Arctic Circle but not beyond the
    outer reaches of civilisation. The panniers on my Tenere are bigger
    than the ones Steve's fitted and I've no worries about them dragging
    in the snow, have a look at one of the sites with webcams showing the
    roads through Norway and you'll get a better idea of what we're going
    to be dealing with.
    When have I suggested we'd have snow clogging the engines or being
    over spindle deep? It'll be cold in the mornings but the actual depth
    of snow will only be an issue when we drag the bikes off the E6 to
    camp overnight. We're not planning on going along little lanes that
    are feet deep in snow, we've got a lot of miles to cover in low
    temperatures but it's a main arterial route through the country.
    Andy Bonwick, Jan 24, 2011
  8. stephen.packer
    Scraggy Guest
    What's the ferry up north of Bodo cost these days Andy? Sheer idle
    curiosity on my part you understand.
    Scraggy, Jan 24, 2011
  9. stephen.packer
    SIRPip Guest
    Well, in the "Cold Climate Oil Grades" thread, you said:
    "One other thing that was pointed out to me was that we could end up
    fucking about in deep snow in which case the engine will be getting
    very hot because there'll be no airflow going over it and it could be
    too much for thinner oils."
    Which I took to mean that you could end up fucking about in deep snow
    and that you could be doing it for long enough to be concerned about
    cooking the engine oil. Deep, to my mind, would be perhaps spindle
    deep.
    Apols for the formatting, it won't fix.
    You've ruined my mental picture of the brave adventurers battling
    through nipple-deep drifts, dragging bikes on sleds bashed out of Volvo
    bonnets behind them now. Studding it up the main drag doesn't have the
    same cachet, you know?
  10. stephen.packer
    Steve Guest
    You must console yourself with an image of brave adventurers
    sitting in the shed hacksawing off the blackened stumps of
    fingers some months afterwards.
    Steve, Jan 24, 2011
  11. stephen.packer
    SIRPip Guest
    You cruel fucker.
    Well done.
  12. stephen.packer
    It only takes 6" of snow to make you slow down enough for things to
    get a bit hot and bothered and I've got a 21" front wheel so the
    spindle is 10.5" off the floor. Miles away from it.
    Sorry.
  13. stephen.packer
    I neither know nor care. It's bikes or bust as far as I'm concerned.
  14. Using the patented Mavis Beacon "Hunt&Peck" Technique, Steve
    That's going to make masturbation a tad tricky.
    Lucky their nobs will have fallen off, eh?
    Wicked Uncle Nigel, Jan 24, 2011
  15. "I'm just going out for a dump; I may be some time."
    Grimly Curmudgeon, Jan 24, 2011
  16. Or, if you're Steve Loukes, you don't go outside, but use a Sainsbury's
    carrier bag as en-suite facilities :)
    The Older Gentleman, Jan 24, 2011
  17. stephen.packer
    boots Guest
    Every cloud...
    boots, Jan 25, 2011
  18. stephen.packer
    Scraggy Guest
    You misunderstand, when you get to <googles> Bognes the E6 becomes a
    ferry to Skarberget. So, unless your journey is going to stop 100k north
    of the Arctic Circle, you'll be needing to pay a paltry 55 krone fare
    and get the (correct) ferry.
    Timetable/price list;
    http://ruteinfo.thn.no/no/default.aspx?rnr=33
    It's a good opportunity to warm up, get a coffee and buy a scandalously
    expensive open sandwich.
    Scraggy, Jan 25, 2011
  19. stephen.packer
    If it drags on something hard enough to damage the headers, something's
    gone very wrong indeed. And if they are daft enough to try & battle
    through snow that deep, narrow & hot headers that will probably fit in
    the front wheel's rut anyway will cause far less drag than a wide
    flat-bottomed bashplate.
    Bashplates are great if you're riding over big rocks & logs, but
    they're also great at collecting large amounts of mud/snow & adding a
    surprising amount of extra weight. Hence the reason people usually use
    something like
    http://www.missionmx.co.uk/acatalog/DRC_Skid_Plate_Foam.html
    Krusty, Jan 25, 2011
  20. stephen.packer
    SIRPip Guest
    I was thinking of rutted ice in that respect, rather than soft snow,
    but there you go. I obviously unleashed my fevered imagination in
    directions it shouldn't have gone.
    Every day's a schoolday, and I've learned something today. Having said
    that, we often used to wedge a lump of high-density foam or even a lump
    of wood between bashplate and sump on rally cars, but that was as much
    to reduce rattles and/or drumming as much as to keep the mud (or worse,
    little sharp stones) out. As long as it didn't take away that
    wonderful smell of toasting mud that always made me feel hungry.
    SIRPip, Jan 25, 2011
