Hi all, Just started having this sound on my 73 Commando 750. In 3rd gear, upon accelration, there is a highpitched whine, increasing with revs. If the rev level out (steady throttle), I hear a pulsating grinding sound (like a disc rubbing which is not true). With decreasing throttle, the sound stops. Only happens in third gear. In second gear I can hear a bit of the aforementioned whine, but no grinding 'shu-shu-shu-shu'. I suspect a clutch problem. Any help here? Thanks in advance. -David Garvin dgarvin AT ti dot com
