Norton Jubilee faults: factual please
Discussion in 'Classic Motorbikes' started by brafield, Feb 9, 2006.
  1. brafield
    brafield Guest
    I've not ridden a m'cycle in almost 40 years, but my last was a
    Jubilee, and ever since I've heard every kind of criticism directed at
    that model. I'd love to hear the specifics of what was wrong. I had
    (and have) zero mechanical knowledge, but rode the thing in London for
    two years until it burned itself out. I recall two garages where the
    mechanic walked out and actually said "get that thing out of here" as I
    paddled it off the road.
    When I bought it, the rogue who took 40 pounds from me said it had to
    run in the "emergency ignition" mode (which I guess overhated it?)
    This was in 1967, but the thing had been a police bike in
    Buckinghamshire for several years before he bought it.
    Anyway, I loved the sound, and hated the weak brakes. It was also kind
    of heavy for a 250, but a beautiful bike to look at.
    Please tell me what the engineering problems were with the Jubilee. No
    abuse or sarcasm please.
  2. brafield
    platypus, Feb 9, 2006
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    I rather think that's for us to decide, don't you?
    Wicked Uncle Nigel, Feb 9, 2006
  4. brafield
    Tim Guest
    I have a 350 Navigator, so I am not about to hurl mud at you :)
    The Jubilee had 2 individual bores, rather than a common one like the
    Navigator, so one of it's habits was to vibrate laterally and snap the
    head stay. It had tiny brakes borrowed from another AMC model that we're
    not up to much (Navigator has Road Holder forks and full side hubs). The
    both of them "suffer" from 6v electrics that would make Joe Lucas "The
    Price of Darkness" impressed.
    Tim, Feb 9, 2006
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, Tim
    Ooh, that brings up a question I've been meaning to ask.
    Head stays.
    How do you adjust them, then? The Oilfield's got one and when I dropped
    the new lump in I looked at it and thought "That's interesting..." and
    sort of tightened it up. A bit.
    I expect there's something *much* more scientific I should have done.
    Isn't there?
  6. brafield
    Tim Guest
    The Navigator and CB250K4 which I once had both have the stay as the
    last item to tighten in the sequence. Other than that I can't remember
    anything extra.
    Tim, Feb 10, 2006
  7. brafield
    brafield Guest
    **** I'd like to thank the posters who replied to my original Jubilee
    query. Now I feel safe enough to ask the truly embarrassing question:
    the seller told me to keep the ignition switched to some kind of
    "emergency" or "for starting only" position. 40 years on I cannot
    remember, but I feel sure this was burning the plugs etc. What
    ignition setting or component did/does the Jubilee have, that
    corresponds to my description, and what damage was I doing. I know I
    was uninformed and suckered when I bought it.....! ****
    brafield, Feb 10, 2006
  8. brafield
    Tim Guest
    Firstly it stop you from forgetting to trim sigs when replying.
    Secondly, from the Norton service manual;
    "The emergency position is intended for starting when the battery is
    discharged. This position is marked 'EMG' on the ignition switch. In
    this position the two groups of alternator coils are connected in
    parallel and if the lights switch is in the 'OFF' position the full
    output of the alternator goes into the battery. This will raise the
    voltage of a discharged battery to a level sufficient to start the
    engine. In the EMG position the charge rate is high - the engine should
    not be run in EMG for too long. The boost charge thus provided may be
    used to restore a discharged battery. Switch over to IGN after ten
    minutes."
    Tim, Feb 10, 2006
  9. Blimey.
    reminds me of the CB100N - 6 coils on the alternator stator, 4 of which are
    only connected if the headlight's turned on, and no voltage regulator.
    Having discovered this, I modified mine by the addition of an extra 2V
    cyclon cell to make the battery nominally 8V, and thereby got about 60W from
    the 36W headlamp bulb; used to need a new bulb about once a month though.
    Austin Shackles, Feb 11, 2006
  10. brafield
    Tim Guest
    Aye it's a handy feature. However I am very interested in going 12V
    because the 6V kit hardly even illuminates the front wheel.
    Tim, Feb 11, 2006
  11. brafield
    Ken Guest
    Ahh the most clueless poster on the group has been googling for the
    OP...............Being able to do a simple search on google, and cut
    and paste the results here, doesnt make you look anything less of a
    twat you know!
    k
    Ken, Feb 12, 2006
  12. That was the point about the 8V system. The maximum output of the honda
    alternator was only 76W though, so that limited the overload of the bulb as
    well - If I'd been able to get a higher wattage bulb (say about 42W) it'd
    have lasted longer. Once put a 24W one in, and it only lasted a week.
    Austin Shackles, Feb 13, 2006
