Noise
Discussion in 'Classic Motorbikes' started by Ian, Jun 14, 2004.
  1. Ian
    Ian Guest
    Just had one of the best days you can have without taking your clothes
    off...
    Got the Z650 out and went for a spin with the fair Jane on her 750 Virago.
    We live not too far from Newport, S Wales and went north via Builth Wells to
    the Elan Valley, very nice. Went to Aberystwyth and headed back, all again,
    very nice. Superb roads and scenery.
    However...
    The old Z is misbehaving... Under load (i.e. lowish revs and biggish
    throttle opening) it kinda jumps, sounds for all the world like a chain is
    jumping off a sprocket (not so, all new and started doing it with the old
    set) It's almost like it jumps out of gear and back in, it never jumps out
    and stays out, and as I said only does it under those conditions. If I give
    the motor its head and gun it from scratch it behaves fine and goes like
    shit off a shovel. Does it in all gears, Any ideas??? Worn gear selector
    forks maybe??
    TIA
    Ian
    Ian, Jun 14, 2004
  2. Ian
    Sounds like you're lugging it, too low revs for too high a gear. If you're
    used to it being smooth in this condition, check timing, mixture, carb
    balance, air filter etc. I seriously doubt there's anything wrong with your
    gearbox.
    platypus, Jun 14, 2004
  3. Ian
    Gear selector forks select gears (duh), so they affect gear changing.
    If it does it in more than one gear, it's not a particular gear,
    either.
    My best guess would be that the primary drive chain could be jumping,
    but I've never heard of that happening before. Usually, they just
    rattle a bit.
    As Platy says, don't make it lug high gears at low revs with wide
    throttle openings. To quote the old doctor gag :
    Patient : Dr, it hurts when I do this
    Dr : Well, don't do that, then.
    Champ, Jun 14, 2004
  4. Ian
    Ian Guest
    Yeah, OK, it was late when I posted...
    Yeah, I'd worked that out...
    I'd been thinking on those lines but it would have to have a hell of a
    stretch to jump teeth, wouldn't it? I'd have thought enough to mash the
    motor into a pulp! It rattles like buggery at tickover unless I twiddle the
    knob to get it to idle at 1250 plus and I assume that it's the primary chain
    that's doing the rattling, but it's done that since I had the bike. This
    jumpy thing is really weird though, never used to happen and it's definitely
    getting worse. (Like these things ever get better...)
    I don't over 'lug' the engine, I mean this is like pulling away from a
    roundabout in 2nd or 3rd at about 3-4k rpm with half or a bit more throttle.
    I feel a strip down coming on, JUST what you don't want with this superb
    weather :-(
    Anybody got a pristine Z650 motor for a packet of peanuts????
    Ian
    Ian, Jun 14, 2004
  5. Ian
    Ian says...
    Just a thought, but have you had the carbs balanced yet since you
    stripped them right down? Unbalanced carbs will make an engine sound
    like a bag of nails on tick over and make it feel a bit lacking in the
    performance department when the throttle is blipped.
    Lozzo, Jun 15, 2004
  6. Ian
    Ian Guest
    No I haven't, but since when did unbalanced carbs make a bike feel like it's
    jumping in and out of gear?
    Have been out again on it this evening and it goes just fine, performance,
    gear changes etc are no problem... Just if I let the revs drop below about
    4K and open the throttle wide it sounds for all the world like a chain is
    jumping a sprocket or gears are missing each other. You can feel it too!
    **** it... I'll ride it into the ground till it won't go any more and then
    I'll maybe have an answer
    Ian
    Ian, Jun 15, 2004
  7. Ian
    Ian says...
    Fair point, but it could account for the slappy chain noise you have at
    tickover. Unbalanced carbs will cause snatching of the camchain.
    Have you checked the condition of the front final drive chain sprocket,
    the one that always gets neglected cos it's a pain in the arse to get to
    and replace?
    Lozzo, Jun 15, 2004
  8. Ian
    Primary chains do rattle on those motors, you're right. And I agree,
    that if it was loose enough to jump then it's worryingly loose!
    BTW, 1250 is about the right tickover speed, so if the carbs are
    balanced (see Lozzo's post) and it still rattles like a bastard then
    the primary chain probably is knackered
    You pull away in 2nd or 3rd? You don't mean that, do you?
    Champ, Jun 15, 2004
  9. Ian
    "from a roundabout" "at about 3-4k"
    Ace, Jun 15, 2004
  10. Ian
    Ian Guest
    Brand new chain and sprox, only done about 300 miles...
    Ian, Jun 16, 2004
  11. Ian
    Ian Guest
    God no! I mean I haven't stopped at the roundabout, just gone round it
    slowish and accelerating the other side!
    Ian, Jun 16, 2004
  12. Ian
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Ian
    Front sprocket nut still nice and tight, is it?
    Nigel Eaton, Jun 16, 2004
  13. Ian
    Ian Guest
    Certainly is, it was doing it before the change anyway, was part of the
    reason for changing chain and sprox. Had it in my mind that the front
    sprocket was knackered and the chain was slipping round it. chain was fucked
    anyway, had tight and loose spots and the sprox were well on their way.
    Ian, Jun 16, 2004
  14. Ian
    Evidently.
    Ace, Jun 16, 2004
