No Spark - HELP!
Discussion in 'Motorbike Technical Discussion' started by Patti, Nov 13, 2005.
  1. Patti
    Patti Guest
    I can't get a spark on my 85 XL600R - I replaced the pulser, CD unit,
    coil, sparkplug, and everything else (except the voltage regulator) in
    the ingition circuit. What the heck?? I wonder if the ignition on/off
    switch could be faulty? What should I look for? I have the sparkplug
    out and clipped with big bulldog clips to the frame and there's no spark
    when I kick it.
    PattiMichelle
    Patti, Nov 13, 2005
  2. Patti
    Pale Fire Guest
    Disconnect the connector coming from the alternator stator and kick the
    engine over as fast as you can while observing the output voltage
    across the red and black wires.
    I suppose you would need an analog voltmeter to see the voltage jump up
    and fall back down. A digital voltmeter might be too slow to respond.
    I dunno for sure what it will be, but I would expect at least 50 volts.
    That's the supply voltage for the CDI. When the pulser coils fire, the
    ignition control unit suddenly hits the ignition coil with voltage, the
    coil multiplies the voltage to a higher level (maybe 20KV?) and the
    spark plug fires.
    You'll probably get around 2 volts across the pulser coils. They send
    their signal to the ignition control unit too, telling it when to send
    the voltage to the coil.
    If you don't get any voltage out of the alternator, maybe the stator is
    burned out or maybe it's the wiring connections. An oddball possibility
    is that the alternator rotor isn't turning because the bolt holding it
    onto the crankshaft has loosened up. I've actually seen this happen.
    Pale Fire, Nov 14, 2005
  3. On mine at least, I'd look at the electronic tach. If the ignition
    module's
    working OK, the tach will show some RPMs when the engine's
    cranking. If the tach is dead, this means a problem in the trigger
    or control circuit. If the tach registers a few RPMs, then the
    problem's
    most likely in either the positive feed to the coil or in the high
    voltage
    side of the ignition.
    You did check the kill switch, right ?
    Rob Kleinschmidt, Nov 14, 2005
  4. Patti
    Jim Ingram Guest
    Are you sure? I thought the primary circuit was connected to +12V
    except when the signal from the pulser coil is used to break the
    primary circuit causing the electromagnetic field to collapse
    inducing a high voltage in the secondary windings. In my (not that
    extensive experience) I would expect 12V on the positive coil
    terminal (the negative is usually green IME) as soon as the ignition
    is turned on. It should be apparent from the wiring diagram.
    Jim
    Jim Ingram, Nov 16, 2005
  5. Patti
    fweddybear Guest
    I am thinking maybe there are a set of ignition modules on the
    bike....have you tried replacing those???
    Fwed
    fweddybear, Nov 16, 2005
  6. Patti
    Pale Fire Guest
    CDI ignitions work opposite from what Kettering type ignitions work.
    Honda installed CDI's instead of electronic ignitions on a lot of
    motorbikes.
    Anywhere from 50 to 500 volts is generated by a separate winding in the
    alternator stator. The primary winding of the ignition coil will be a
    lot higher than the typical 3.5 to 5.0 ohms found in battery and coil
    ignitions. And the XL600R *has* a separate winding, according to
    Electrosport's web site. The owner of the motorbike has the option of
    using a battery and lights or not.
    Pale Fire, Nov 16, 2005
  7. Patti
    Pale Fire Guest
    motorbikes.
  8. Patti
    Jim Ingram Guest
    Ah I see. I'd never really appreciated the difference before. The
    only problems I've ever had with motorcycle ignitions are fouled
    plugs or corroded plug caps (poor contact between resistor etc). If
    anyone's interested I found a page giving a good introduction to
    ignition systems .
    http://www.jetav8r.com/Vision/Ignition/CDI.html
    Thanks
    Jim
    Jim Ingram, Nov 17, 2005
