No Power to Headlight, 1996 Magna
Discussion in 'Motorbike Technical Discussion' started by brentusbrutus, Sep 30, 2005.
  1. Hello there Folks..
    I’m in the process of putting a 1996 Honda 750 Magna back on the road.
    The headlight doesn’t work..
    Everything else does seem to work (signal lights, brake lights, etc)
    I put a Volt meter on the Headlight connector, and found no power
    Checked the fuse, and it was good..
    Removed the fuse, checked for power and found none..
    What’s next?
    I am sure the volt meter is working, as i tested the signal lights
    from
    the fuses, as well as the battery.
    Thanks for your help...
    Brent
