No plate light required? Oh, and exhaust plates.
Discussion in 'UK Motorcycles' started by Dave Jennings, Nov 16, 2004.
  1. Dave Jennings
    I now care...
    Taken from VCA type approval documentation:
    "Rear registration plate lamp - on motorcycles first used from 1 April
    1986 must be approved and marked to ECE Regulation 50 or 4 or to EEC
    Directive 76/760; "
    http://www.vca.gov.uk/downloads/files/vca005.pdf
    My Guzzi is 1979 so obviously predates this bit of the C&U.
    sweller, Nov 17, 2004
    #41
  2. Dave Jennings
    Stu Guest
    To reply to you and Mr Eaton -
    I'm fine. Life has been incredibly busy this year, both workwise and at
    home, hence I haven't been around much. I've popped in here now & again to
    read through the posts, but haven't contributed.
    I now have a newer Diversion - the old XJ was getting too unreliable, and
    is now sitting under a cover in my back garden, waiting for me to do
    something with it.
    Anyhting really exciting happened in UKRM at all?
    Stu
    XJ900 Diversion & Tatty old XJ900 thing
    <A couple of numbers go here>
    Pull my plonker to reply.
    Don't believe the hype"
    Stu, Nov 17, 2004
    #42
  3. Dave Jennings
    Stu Guest
    if a copper's following you at night on an unlit road, his headlights will
    illuminate your plate so
    Now that made me laugh. A lot. Do you really believe that?
    Stu, Nov 17, 2004
    #43
  4. Dave Jennings
    Preston Kemp Guest
    Really? What a strange sense of humour you have!
    That post was generated by my Random Bullshit Bot. I was hoping it
    would add a DB9 to my sig, but it came up with that crap instead.
    But yes, I do believe it, kinda. I'm sure they'd notice if they were
    looking for it, but it's not something that would jump out & shout
    "pull me" like having a dead taillight. Like I said, my Tiger hasn't
    had a white light pointing at it for years, & I've never been stopped
    for it. This must be because following plod doesn't notice, or doesn't
    care. Either way it's the same result.
    Preston Kemp, Nov 17, 2004
    #44
  5. Sounds perfectly reasonable to me. You wouldn't be driving at night with
    no lights on would you?
    Whinging Courier, Nov 17, 2004
    #45
  6. Stu yik-yakked:
    Bad form re-posting and all, but just in case you missed it I asked
    earlier re the tailight thing:
    Aha, see that's what I thought, although a lot of posts say it isn't
    required.
    You're Trafpol, aren't you? Now, I'd expect therefore that your view
    would be the most definitive one.
    Assuming I used the light as is, and that it passed the MoT like that,
    what's the likelihood of me:
    1 - being pulled for an unlit plate
    2 - pointing out it pased the MoT like that
    3 - getting a rectifier or would it more likely be a FP of some sort
    Or is it best just to lube up before I go out? ;-)
    Dave Jennings, Nov 17, 2004
    #46
  7. In uk.rec.motorcycles, Dave Jennings wrote:
    [Rear lights]
    You don't know the meaning of the word.
    #47
  8. Whinging Courier yik-yakked:
    Arf.Well done.
    #48
  9. Bear yik-yakked:
    We were all twiddling our thumbs[1], watching the tumbleweed until you
    two fellas came back.
    [1] Euphemism for self-pleasuring,obviously [2]
    [2] Although not with either of you as our impetus[3]
    [3] Speaking personally, anyway
    #49
  10. Whinging Courier yik-yakked:
    In fact, I don't know the meaning of a *lot* of words, e.g.
    shy
    it's my round
    I'm sorry miss, should I have pulled out and discreetly sprayed over
    your tits instead of blowing a big thick wad over your face?
    etc etc
    I just need the finer points polished [1]
    [1] And my knob, obviously
    #50
  11. Bear yik-yakked:
    [Note to self. Must do better.] [1]
    [1] Or worse, obviously.
    #51
  12. Bear yik-yakked:
    In fact, reading this again..............
    what's most worrying? The fact that I wasn't, or that by inference some
    regulars of UKRM were? [1]
    [1] Less a clique, more a wanque?
    Dave Jennings, Nov 18, 2004
    #52
  13. Dave Jennings
    Stu Guest
    Err probably - The Con & Use Regs I quoted were of a very recent version, so
    should be right.
    For everyone else's info, it's bloody obvious when a plate is unlit, even
    from some distance. If that was the only problem with your bike, I
    personally couldn't give a toss.
    Stu
    <sig goes here, when I fix it>
    Stu, Nov 20, 2004
    #53
